Question about GE Spacemaker JVM1640SJ Microwave Oven
The keypad is not working - GE Spacemaker JVM1640SJ Microwave Oven
  • GE Master
  • 43,501 Answers
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Posted on Jan 03, 2011
How do i fix keypad
Keypads will flash when new oven or when disconnected and setting are lost. First try setting the clock
  • push CLOCK--enter numbers--push CLOCK to see if keypad becomes operational.
If not, unplug, replug and try again. As for "fixing" keypad ....that is not likely to be the problem and even it it were, keypads are not user repairable. For further info, dial the the factory customer support phone number.
Mar 14, 2015 | Microwave Ovens
Some buttons on microwave keypad won't work
Keypad/keypads once faulty cant be fix . Buy a nex keypad
Sep 01, 2014 | KitchenAid KCMS1555RSS Stainless Steel...
LED not working
see this causes and fix it. God bless you
If you have a stuck key or non-responsive key, most of the time you will have to replace the keypad for this microwave oven repair. If your keypad is connected to your control board by a flat ribbon wire, try disconnecting it and clean the silver contacts with an ordinary pencil eraser. After cleaning, plug it back in and try it. If it doesn't fix it, replace the keypad unit. Some units actually have keypad tests to confirm your diagnosis of a bad key.If your keypad and control is the same unit, replace that unit. Another note, unlike stove/oven keypads and controls, most microwaves do not have error codes or tests to distinguish whether it is truely the keypad or control. Most of the time, it is the keypad that needs replacing, but a small percentage of the time it can be the control. Check the tech sheet if they can point you to the right part.
Oct 10, 2012 | GE Advantium 120 Convection/Microwave Oven
LG touchpad doesn't work
use the common sense,logically, fix it. God bless you
Aug 02, 2012 | LG Microwave Ovens
Touchpad not working
please see the next step. and fix it. God bless you
Aug 02, 2012 | Microwave Ovens
Buttons on keypad not working
The keypad control board is the problem and the only solution is to replace, however! part will exceed cost of some microwave ovens.
Apr 22, 2012 | Microwave Ovens
Dead keypad
need to check keypad ribbon tail or connection. vibration from moving unit could have made it come loose. if connection are good then replace keypad.
Jun 21, 2009 | Westinghouse WST3501 Microwave Oven
Microwave Sharp carousel Model R3A36 keypad not working. We had a brown out due to a recent storm and the microwave keypad didn't work anymore after that. We unplugged and replugged and the light inside is...
Your keypad has failed.
It would need a new control panel frame, which comes with the keypad.
You simply remove the circuit board and plug it into the new frame.
It is part # FPNLCB070WRK0 and the best place to order Sharp parts is Tritronics.
Sep 03, 2008 | Sharp Microwave Ovens
Numbers 1,3, 4 and 6 no longer work
It's probably the keypad. The keypad is a thin plastic membrane type that is glued to the plastic control panel frame.
If none or only some of the pads are working, there may be some foreign substance on the circuit board, the keypad connection, or inside the layers of the keypad, the latter of which cannot be repaired.
Trouble is sometimes due to spray cleaner being sprayed directly onto the keypad. Cleaner should be sprayed on the cloth first, then use the cloth to wipe the keypad clean.
Never use an ammonia-based cleaner on plastic as the ammonia can attack and crack it.
A handy person can remove the control panel frame and see if there's any liquid inside on or behind the panel. If so, it is possible to dry it out, but often that does not work.
Another thing is to unlpug the power at the mains for several seconds. Plug it back in and see if it works. A reset may do it. At power-up, the display should flash or show a text
message. If not, a key may be stuck due to a foreign substance or a defective keypad.
We have critical safety, disassembly, and troubleshooting info at our site. You'll find a link to our site in our listing here on FixYa: http://tinyurl.com/yzjozk
If certain keys are not working, there may be some foreign substance at the point where the green or blue plastic strip from the keypad plugs into the circuit board. To check that:
1. Be sure the oven is disconnected from the power line while you are taking it apart.
2. The keypad connection is the green or blue translucent plastic strip that plugs into a connector near the edge of the board.
3. There are two tiny tabs (one on each side) of the connector that you can gently pull up on to unlock the connector.
4. Then the keypad strip will lift out. Clean both sides of the end of the strip with a pencil eraser or alcohol-based cleaner if you like, but do not use ammonia-based cleaner. Dry the end of the strip.
5. Put the keypad strip back in, making sure both sides are down fully.
6. While holding the strip down, push the connector back down to lock it.
7. Try the keys again with the door closed.
Also, you must have the door closed for the START button to work.
You can probably find an exploded view by entering your FULL model number here: http://www3.sears.com (the 3 is correct)
You can order Sharp parts from there or from Tritronics at http://www.wehaveparts.com
We're happy to help and we appreciate your thoughtful rating of our answer.
Jan 05, 2008 | Sharp R-320H Microwave Oven
Microwave Keypad not working
This model does have a child lock. If it's on, the display will say "LOCKED". It is turned on and off by holding dfown the "0" key for 4-5 seconds. You may also have a bad keypad, which in many cases can be replaced. A bad keypad may be worn out due to age, damaged, or it may have gotten wet or otherwise contaminated. Moisture and contamination can be caused by spraying of cleaners, by storing the microwave in an unheated garage or shed, or infestation. I warn my customers to never spray cleaner directly onto the microwave keypad, since the liquid can get inside and "lock up" or even ruin the keypad or controller. Apply an alcohol-based cleaner (such as the purple kind) to a cloth (paper towels can scratch) and gently wipe it off. I suggest to my customers that they NEVER use any ammonia-based cleaner (like the blue stuff) on a microwave, since the ammonia will crack and distort polycarbonate plastics. Repost if you need more help.
Nov 04, 2006 | LG LMVM1935 Convection/Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
358 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
