Question about Wurlitzer Jukebox CD Player
I have a rowe ami cd-100. When first turned on it works great. After a few songs, the volume fluctuates up and down. I cant seem to get the volume to stay put. Anyone know the cause? Bad amp? Thanks Dave
  • 6,771 Answers
You probably have bad solder points on the main board causing the intermittent operation after it warms up.
Posted on Jan 03, 2011
My AMI WP 100 plays the cds but no volume
For a manual, try Googling (AMI)(WP 100)(manual) without parens.
Oct 16, 2016 | Audio Players & Recorders
Rowe Ami Jukebox buttons do not unleash
Hello Pedro,
You need to unlock the top door of the jukebox so you can operate the catches to get to the keyboard. The open relays R1 & R5 which are normally under a plastic cover, the open contacts on these relays need cleaning. Do not use any form of switch cleaner, just make a paper taper and pull this through the contacts to clean the contact tips.
Regards
Alan
ami-man
UK
Feb 24, 2014 | Wurlitzer Jukebox 1015 One More Time...
I just purchased a Rowe AMI CD-100a. It was a barn find. Once I learned to initialize, I tried to play individual tacks or entire CDs. For each track, the unit picks the CD, places it down on the player...
Could be the power supply voltage is low, possibly due to a bad capacitor, it seems that when the counter advances it is pulling the voltage down enough to cause the problem you are experiencing. If you can select a disc in the service mode, the counter should be inactive, and you can see if the disc will play through.
Sep 29, 2013 | Wurlitzer Jukebox CD Player
I have a Rowe Ami cd 100 that we just got.The cd,s skip-music starts and stops, and it seems like the machine is not reading them [sometimes it picks a cd and returns it to rack].Anyone have any...
Did you lock down the jukebox mechanism (caurosel) during transportation?
Make sure that all the plugs that go to the all the circuit boards are fully seated, Unplug each in turn and plug back in MAKE SURE YOU UNPLUG THE JUKBOX FIRST if this does not sort out your problem look at the microswitches on the transfer motor (this is the mptor that tranfers the CD onto the deck) the spades on the microswitches are uninsulated so they can short out if pressed together.
The other main problem with Rowe Ami is that the boards are prone to the connection pins having dry joints (cold joints in the USA) on the soldinging to these connection pins.
It may be as well having all the boards tested by a Rowe Ami specialist.
In the USA the best guy is Bruce Wentworth (search for his details on Ebay by putting in Bruce Wentworth jukebox) or you could contact me in the UK.
Regards
Alan Hood
ami-man
UK
Apr 29, 2010 | Wurlitzer Jukebox CD Player
Record tracking problem
There is a switch, or lever to a switch, that detects the end of the arm travel. For some reason, it is being tripped early. Try to open it up, and see what you can see. It doesn't sound like a broken part, but a dislodged part, maybe. That's all I remember, only had this problem once, years ago.
Mar 14, 2010 | Audio Players & Recorders
Rowe Nostalgia jukebox will only play a few of the numbers of the 100 cd;s. Is there anyway to reset it so it will play all numbers?
You will need to go into the programming section on the menu.
I suggest that if you do not have a manual that you obtain one from Rowe Ami, Victory Glass or distribution.
Have you initalised all of the CD's on your jukebox? Every time you replace a CD you have to initalise it.
Regards
Alan Hood
ami-man
UK
Jan 31, 2010 | Wurlitzer Jukebox 1015 One More Time...
Rowe Jukebox CD-100E. When I turn it on the
AT THIS TIME YOU ARE NOT SURE IF THE PROBLEM IS IN THE LASER ASSEMBLY, OR THE AMPLIFIER?
BORROW OR RENT, AN AMPLIFIER HOOK IT UP TO THE OUT PUT ON THE LASER OUT PUT ON THE LASER CD OUT PUT. LOOK AT LASER UNIT IT HAS A MARKING ON IT THAT SAYS AUDIO OUT PUT. PUT CABLE TO A SECOND AMPLIFIER.
THAT WAY IF IT STILL FADES. THEN THE CD LASER IS THE PROBLEM . IF THE SOUND IS GOOD THEN THE AMPLIFIER IS AT FAULT
DOCTOR FIX IT
Oct 23, 2009 | Wurlitzer Jukebox 1015 One More Time...
Rowe CD 100 that will not play all Tracks
Are you initalizing the CD's in your jukebox after you install them?
If so it should play all of the tracks.
Regards
Alan Hood
ami-man
UK
Feb 01, 2009 | Wurlitzer Jukebox CD Player
Song Programming
With regards to your problem with the Rowe Ami 100 cd jukebox.
Do you have a manual, if not I suggest you buy a printer manual or one on CD and refer to the Programming and Installation section.
In order for the jukebox to know about the cd's that are installed in the jukebox it has to initialize all or the changed cd's that have been replaced within the jukebox.
Put the jukebox into the Service Mode (the service mode should appear on the display)
Type 3 to select the Initialize sub menu
Type 0 and full initialize will appear on the display
Press Popular to start the initialization
Place the jukebox service switch into the normal mode
Initiazation will take around 30 minutes to complete.
Regards
Alan Hood
ami-man
Jan 05, 2009 | Wurlitzer Jukebox CD Player
Open Questions:
See all Wurlitzer Jukebox CD Player Questions
Wurlitzer Jukebox CD Player Logo
149 people viewed this question
Top Wurlitzer Audio Players & Recorders Experts
John Robertson
John Robertson
Level 1 Expert
jasbo
jasbo
Donald Chadwick
Donald Chadwick
Level 1 Expert
Are you a Wurlitzer Audio Player and Recorder Expert? Answer questions, earn points and help others
