Question about Sony BDP-S350 Blu-Ray Player
Screen goes black repeatedly during play of all DVD and Blue Ray discs and resumes a few seconds later.
  • 382 Answers
SOURCE: My Blu-ray keeps saying no disc.
This can be caused by a number of different things, some simple ones are:
- Unplug for 5 minutes then replug, this will reset the processor and it may smarten up (just like rebooting a computer)
- Take the unit apart and using a Q-tip and lens cleaner gently clean off the lens of the laser...only do this is you feel comfortable. If there is a hair or obstruction on the lens it will not read discs. If it is still under warranty, send it in first before you take it apart, it may void warranty.
- If the above two do not work then the transport mechanism may be defective and the repair would be around 100 -150 dollars, which is probably not worth repairing and it is best to look at a replacement machine.
Hope this helps!
Posted on Jan 20, 2010
ionfreek458
  • 52 Answers
SOURCE: my ps3 wont play blue ray discs or my games anymore
if your ps3 doesnt play ANY games or dvds, that may mean that the eye on the ps3(the thing that reads the disks and dvds) is malfunctioning, not moving efficiently enough to procces the disk, not recognizing the encrypted code on the disks, or the optical eye could even be scratched. the disk feed could also not be feeding the disk in far enough for the eye to read it. i would definitly suggest calling customer service and/or bringing the ps3 to an A+ certified technition to "diagnose" your problem.
Posted on Oct 14, 2008
  • 3 Answers
SOURCE: blue ray player wont play blue ray ''Kung Fu Panda'' disc.
Unable to play BD-R or BD-RE discs in the Blu-ray Disc® (BD) player. Solution
sp.gif sp.gif The Blu-ray Disc® (BD) player does not support BD-R and BD-RE discs right out of the box. However, a free firmware update is available that will provide compatibility with BD-R and BD-RE discs recorded in the BDMV format.
If your computer is equipped with a DVD burner and compatible burning software, you can download the update from the Drivers & Software section of the Sony® eSupport Web site and then burn your own update disc on a DVD-R or DVD-RW disc. If you do not have the capability of downloading and burning your own firmware update disc, you can register the BD player online at http://www.productregistration.sony.com/ and a firmware disc will be sent to you automatically; the shipping and receiving time for the disc is approximately 7-10 days via U.S. mail.
NOTES:
  • The firmware upgrade does not support BD-R and BD-RE discs recorded in the BDAV format.
  • Disc may not be played due to inadequate recording capability of the recording device.
  • Disc may not be played due to a disc being in poor condition.
Region
sp.gif sp.gif Canada
United States
Products
sp.gif sp.gif BDPS1
BDPS300
BDPS301
Last Modified Date:10-27-2008sp.gifID:C444112
Posted on Nov 29, 2008
  • 3 Answers
i fixed this exactly as previous posted solutions, however a couple of points.
a) recordable CDs work if you don't have a DVD burner.
b) I didn't have a CD burner that would do an "image burn", I downloaded a free copy of "Express Burn" and that worked fine. The disk needs to be "finalised" or "fixated", it should do this automatically, or it may be a tick box selection.
c) I got a "No DWLD 09" when I put the disk into the player. I found this was an incompatibility with the CD-R (Maxwell) I was using. I changed to JVC and it worked fine.
Posted on Dec 29, 2008
  • 3 Answers
SOURCE: ps3 wont read blue ray discs but will read dvd
sounds like the blue ray lens fried, u should be able to find one on ebay or craigs list not hard to put in
Posted on May 29, 2009
Need to know how to finalize recorded disc so that it can be played in regular dvd player
You can record and finalize DVD+Rs one time. After you fill a DVD+R or
complete all the recordings you want on a single DVD+R, finalize it.
Otherwise, the DVD+R will play only on this Recorder.To play the Disc on
other DVD Players, you must finalize it first.
Once you finalize a DVD+R, you cannot record on it anymore or make
editing changes.Therefore, make sure the Disc is as you want it before you
finalize it.
Press SYSTEM MENU. Press
; to select in the top left
corner of the menu bar at the top of the TV screen.
Press CH-
9 repeatedly to select in the second screen,
then press
Press CH-
9 repeatedly to select Finalize disc. Finalize disc
appears in the menu only when an unfinalized DVD+R is in the
Recorder.
Press OK.
"Finalizing" will appear in the menu.The process may
take a few minutes.
When finalization is complete, the Index
picture screen will reappear.
You cannot unfinalize a DVD+R, and you cannot record or
edit the DVD+R after you finalize it.
A DVD+R will play on other DVD Players only after the
Disc is finalized.
Mar 22, 2011 | Philips DVDR75 DVD Recorder
How to unlock my sony bdps300 blue ray player
Follow this procedure to lock and unlock the disc tray.
IMPORTANT: This procedure will only work while a disc is inserted in the player and when the disc is playing.
  • While a disc is playing in the Blu-ray Disc player, press the SYSTEM MENU button on the remote control.
  • After the System Menu screen appears, slowly press 0 0 0 0 7 6 6 9 using the number pad on the remote control.
NOTES:If the procedure has been performed correctly, the disc will stop playing and the player will go in the Resume mode.
Each time this procedure is performed the disc tray will either lock or unlock.
Hope this helps. If you need any assistance. Please get back to me. I will be more than happy to assist you.
Thanks for understanding.
Jan 19, 2011 | Sony BDP-S300 Blu-Ray Disc Player
Sony Blu Ray DVD won't open, but disc inside is playing
hold on to open boton but it might take a while to open or the rubber that open and close the door is little bit slack that why its giving that type of prob, try and change it .
May 30, 2010 | Sony Blu-ray/dvd player BDP-S1
Tried to get internet
hi...please verify:
  • your dvd disc region (must be region free or 1 - for USA)
  • playing blue-ray MOVIES disc, to check a possible problem with your reader .
if the blue ray movie doesn't work, you have got a possible problem with your blue ray dvd reader .
then, take it to an assistance center for hardware repair ..
thank u
rate me!!.
Jul 27, 2009 | Sony Playstation 3 (PS3) Console
Rise of the lycans won't play
This will be a firmware issue with the unit if this is the only disc that wont playback. If the unit already has the latest firwmare installed (this can be checked by connecting a LAN cable to the back of your unit and accessing the menu) you will need to wait for the next firmware update to be released to solve the issue.
I would advise contacting Samsung where you are residing to adivse them of the issue.
Jul 16, 2009 | Samsung BD-P1500 Blu-Ray Player
Will not play blue ray or dvd
It's a new system glitch you may need to send it in or ake it back and exchange.
Feb 03, 2009 | Sony Playstation 3 (PS3) Console
Picture will freeze.
Either the disc is scrathed or you have to remove the cover and take a q-tip with rubbing alcohol and clean the lens.
Jan 22, 2009 | Cyberhome CH-DVD 300 DVD Player
DVD stopped playing all DVDs
Reset you player by doing the following:
With the player on, hooked properly to your television, and on the correct station:
Open the tray
Close the tray (with no DVD inserted)
Hold the stop button down for a full 5 seconds
The CyberHome screen should appear. You should be able to play your dvd's now.
Feb 20, 2008 | Cyberhome CH-DVD 300 DVD Player
Sony BDP-S350 Blu-Ray Player Logo
275 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
