Question about Sylvania 6413TC 13" TV
Remote control stop working. Check batteries and tried new batteries, did not help. Once in awhile it may turn on or off, or turn on but not off or visa versa, other button very seldom works. Tried a programed satelite remote control does the same thing. All the buttons on the TV works alright, but it takes too long to change channel from single digit to double digits. What is wrong and what can I do, thank you.
  • Sylvania Master
  • 1,210 Answers
You have an aging TV and aging capacitors. There may be some bad grounds on the solder side of the main board. You need to first inspect the solder side of the board for bad solder connections. And find an ESR meter. (Capacitor Checker) No doubt you will find some weak capacitors. I would look for those almost anywhere on this TV. This TV is small and you should be able to test each and every electrolytic capacitor. The electrolytics are the caps that look like small cans with two legs. They are rated in Mfs. For example 35 volts @ 100 MF, 16 volts @47 Mf, 25 volts @ 4.7 MF, etc. Test all of them and replace as necessary. Good Luck and thanks for asking. Show a few hands of support.
Posted on Jan 03, 2011
RC-261 fails to turn on/off Insignia TV. Remote stopped working (batteries good)
Check the battery contacts inside its battery compartment for any rust or dust accumulated. Clean them well. If this too do not help you, check the remote control for its infrared emission. In some cases, cleaning the remote control may be necessary. If you wish to get more details about how to check, repair and clean a remote control, visit this site. Pull up older posts. One among the post has details.
Mar 24, 2013 | Insignia RC-261
Samsung LE32C450E1W TV remote control stopped working, changed batteries no luck, turned off at power source for 30 min which fixed prob temp but has happened again and now turn off doesn't help....
Check the remote control for its infrared emission. Check it with fresh batteries. Clean the battery contacts inside its battery compartment. If these do not help you, you remote control need cleaning. If you wish to know more about how to clean and repair a remote control check this site. Pull up older posts. One among it has details.
Mar 24, 2013 | Samsung TV Remote Control
Mx850 remote stopped working. replaced batterries no display still.
Remote control have any screws at all? All arond it frame?Yes.Can u take it parts?Tries a damp cloth soak with some rubbing alcahols.Clean the whole PCB board and the battery - + resolders the battery - + steal plate connections too if possible and have a soldering iron equipment.Wait awhile like 10 or 20 mins put it back togetther again,will have a 50/50 chances fo it to work again.
May 31, 2011 | Universal Remote Control MX-850 LCD Remote...
T.v. does not respond to remote control, but does work maually from side buttons
Turn tv on manually.Test the remote control all functions are dead or some functions work other don't?Tries take the remote control parts and clean the inner rubbers buttons between the rubbers insulater and the remote circuitries board and the battery connections + - connections with some rubbing alchahol.Then wait awhile like 20 mins and putting it back together again and putting in new battery in the remote,it might work again.If getting the same result than the remote CPU chip is probally dead,remote control devices are very depended on it CPU chip.Try website like Remotes.com to buy an original remote for the replacement.
Mar 24, 2011 | Vizio 42 in. LCD TV
My dynex remote control for 32 inch flat screen stopped working, tried new batteries-no fix, any help? Can I use another or do I have to contact the company for a new remote?
I just called Dynex because I had the same problem. Remove the batteries and press the power button and hold it down for 15-20 seconds, put the batteries back in and try to power on and power off, change channels, etc... if so the remote is fine. The guy told me that sometimes when you need to replace the batteries you also have to re-set the remote control.
Jan 09, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
Fujitsu air con unit. Remote wont work. has new batteries
Check the micro processor control whether it is in manual mode or not. If not check the sensor whether it is functioning or not. If everything is fine then remote control has to be changed.
Aug 15, 2009 | Heating & Cooling
I have a car fitted with a Clifford GS 470 alarm but I cant get the alarm to stop. The car that this alarm was fitted in has not been started in 5 months and so the battery ran flat. I replaced the battery...
you might have to replace the batteries in the remotes. The reason why the alarm is going off because once you plug power back to the alarm brain it sets the alarm off and the only way to make it stop is to hit the unlock button the remote. Make sure all connections on the alarm brain are good and try changing the batteries in the remotes. also might have to reprogram the remotes to the brain if it has been sitting for awhile.
Feb 16, 2009 | Vehicle Parts & Accessories
I have a Hampton Bay or Hunter?? Ceiling fan that is Remote Control. It all of the sudden started acting strange--ie. The light started going from Dim to Bright and none of the functions on the remote...
The canopy should turn either left or right to remove. I'm sure you've tried this, but if the fan's been there awhile, it may just be a little stuck and you need to work at it.
Nov 26, 2008 | Dryers
Remote problems?
Mine did the same thing for awhile... and for some reason if I hit the "DVD/VCR" button and the "input" button at the same time it would start working again... you could try that, but I am no expert!
Jan 21, 2008 | Sansui VRDVD4005 DVD Player/VCR
Problem programming remote
Leave batteries out for awhile. Reprogram & make sure batteries are good. Also here is link to latest manual.
http://www.remotecentral.com/cgi-bin/files/dl.cgi?file=others/radio_shack/152146-manual.zip&area=other
Jun 14, 2007 | Radio Shack 15-2146 Remote Control
Sylvania 6413TC 13" TV Logo
89 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
