Can,t get sky to connect through our new tv, have sound and some features but no tv through sky
  • thewelshies1 Jan 03, 2011
    it,s a brand new tv,all connections and setup is right but the tv does not seem to recognise the hdmi through the sky digital,it keeps showing as no signal,the tv works with a scart plug from sky to tv but not with hdmi
  • 19,396 Answers
Hi.
I assume that just the TV has been replaced, and that there is no problem with the satellite connection, disk orientation, LNB and receiver box. Eventually test again the satellite signal using a spare TV.
To connect the new TV:
Turn off Sky receiver and TV.
Connect cable from box to TV (possibly HDMI, alternatively component or SCART).
Turn on box first.
Turn on TV.
If Sky signal is not displayed, try using the Source/Input button on TV remote to select source.
If there is still no raster, test using a different connection cable and ensure that box is working and tuned.
Regards.
Ginko.
Posted on Jan 03, 2011
  • Ginko
    Ginko Jan 04, 2011
    Hi.
    Do the following, you may have done some of the steps already.
    Check HD settings on Sky box. The TV should already be set to accept 1080i.
    Do complete power down by switching off TV and receiver and disconnecting the power cables for two minutes.
    Test HDMI port using different device (eg DVD player).
    Test using different port on TV.
    Test using different HDMI cable.
    If that does not work, call Sky and get an updated receiver (even if this works with older TV).
New toshiba tv connect to sky plus box and perfect picture but no sound
The first thing to do is check the connections between the Sky box and the TV. If you are using a SCART cable, it's possible that one of the pins in the SCART plugs has bent or become detached from the wire inside. If you have another SCART cable from a VCR or DVD player, try switching them over.
If this doesn't work, or if you are using another connection method between the Sky box and the TV, please post back and I will try to assist you further.
Regards,
BElectric
Nov 29, 2010 | Toshiba Televison & Video
Hissing and Humming when trying to use the speakers for the tv
The sony manual tells you how to connect to a TV however most of us now watch TV connected to a SKY box. The Scart lead needs to be connected to the Sky box for the sound to work correctly. Ignore the Manual and connect the Scart lead from the DVD Unit directly into you're sky box. It works fine.
Apr 04, 2010 | Sony Audio Players & Recorders
Just connected sky via hdmi through denon 3310 and no sound is coming through the tv. Also do i need to have amp on to view sky via hdmi?
ensure that HDMI is selected in your sky settings.
you would not need an amp at all just to view sky, only if you were routing sound to say a surround system.
Are you only getting no sound from the tv? or are you getting sound via the amp but not from the tv?
Nov 22, 2009 | Denon AVR-3805 Receiver
HOW TO CONNECT SAMSUNG 40 LCD TV TO SAMSUNG SURROUND TZ215 THRUGH SKY + HD BOX.
you will need the following = HDMI LEAD
Optical Audio Lead
Red and White phono Lead
Sky HD Box > connect to Tv via HDMI Lead.
Sky HD box > Connect the optical Audio, and the Phono Leads To your Surrounds sound.
The reason I am wanting you to connect the phono's as well as the optical audio out. Not all programs are transmitted with Dolby D so you will need these for normal sound to come through your surround sound.
One last thing I would like you to check is the sound settings on your Hd box.
OLD PROGRAM GUIDE:
On your sky remote. Press SERVICES, 4, 2, then ensure that Dolby D is displayed if not highlight and using the blue button change this to Dolby D. then arrow down to save.
NEW PROGRAM GUIDE:
On your sky remote. Press SERVICES, 0, Arrow along to SOUND then arrow down and change this to DOLBY D Then press the GREEN button.
Hope this Helps you out. IF so please leave a thumbs up
Little Dish Fitter
Aug 26, 2009 | Samsung LE40B650T2 40 in. Full HD Crystal...
Samsung HT Q 100 surround sound only works with DVD
Look on the subwoofer. Does it have an upmix switch? If not, you cannot upmix the stereo to all speakers. You can also check your TV menu options to see if it has the upmix feature (or similar).
Aug 01, 2009 | Samsung HT-Q100 System
No picture on TV through Sky, Home Cinema is on but have sound.
do have sound and picture at same time you will need a fibre optical cable, you connect that from your cinema system to your tv. then you need to set your cinema system to digital input or fibre optic or check by pressing aux on your remote and see which is the right one. i am not familier with panasonic as i have samasung.
Dec 10, 2008 | Panasonic SC-HT75 System
Souud delay on tv /amp
Instead of connecting each device (sky&dvd rec.) to the TV separately, I would simply hook up the sky to dvd recorder (connect the sky output and dvd recorder input), and then connect the dvd recorder output (must be called "play out") to one of the available recorder inputs (which could be a dvr, an empty tape input, etc)of your amp. However, you'll still have to establish a feedback between your dvd recorder and your amp. Therefore, if the dvd rec. supports it, you'll have to hook up the rec.out, which is on your amp.,to rec.in on your dvd recorder. After all these audio connections, you will only need to make a video connection among the sky, dvd rec., and tv. Get a video cable to hook up the sky video output to your dvd recorder's video input, then do the same thing between the dvd recorder's tv output and tv.
Apr 12, 2007 | Cambridge Audio Azur 540A Amplifier
Televison & Video Logo
49 people viewed this question
Top Televison & Video Experts
Electro Med Services...
