Question about Honeywell Programmable Thermostat Heater
Our Local Gas and Electric Company (BGE) Installed the Honeywell Peak rewards thermostat and it consistently blinks on and off. The screen stays illuminated green but it blinks on and off every 2-3 seconds. The thermostat works fine other wise changing tempatures and such only when it is (blinked on). Please help me fix
3 Suggested Answers
t1m130
  • 86 Answers
SOURCE: Same problem, backlight on all the time
http://www.ntsupply.com/files/products/VP8000TechData.pdf
check out this website
if this is the touch screen tstat you have to enter installer setup
touch the SYSTEM button once
hold down what is usually the HOLD and SCREEN keys touch both keys at the same time
(hold the two blank keys on either side of the center key at the bottom)
this will bring you into the setup
BE VERY CAREFUL WHAT YOU CHANGE THIS COULD EASILY SCREW UP YOUR SETTINGS
change where the numboer is 0120 to 0280 and change 1 to 0 then hit done this should fix it:)
Posted on Jul 26, 2009
  • 4134 Answers
SOURCE: How do I change the battery on Honeywell Thermostat T8001C?
According to the manual for the model series (see link), only the T8002 Model has batteries. They are accessed from the right side of the thermostat. See page 14.
https://customer.honeywell.com/resources/techlit/TechLitDocuments/69-0000s/69-1431.pdf
Posted on Jan 10, 2015
My unit is a Honeywell and not a Muirfield.97-4118/5-89 and it will not work on auto but works on manual.
If it's a new thermostat that you have recently installed, check your installer configuration. Make sure the tstat is set up for gas or electric heat, depending on what you have. Some t-stats also have a small switch on the back to switch from gas to elec. A gas furnace has components to control the fan, electric unit uses the tstat to control the fan. Hope this helps!
Mar 21, 2017 | Honeywell Heating & Cooling
My Honeywell Themostat is no longer controlling the systems after a battery change, but otherwise looks fine. Help!
The replacement batteries could be defective or installed incorrectly. Also, if the thermostat has to be removed from its mounting base for installation of replacement batteries, it may have been reinstalled incorrectly.
Nov 07, 2015 | Honeywell Heat/Cool Thermostat
I have Honeywell Pro TH4000 series. The fan wiil not come on what do i do
Depends on what type of heat you have...gas, oil , electric, heat pump? Make sure it is the right thermostat for your heat source. Some thermostats have a switch on the back for fuel or electric.
Dec 08, 2013 | Honeywell Programmable Thermostat Heater
Thermostat is reading FR Return what does this mean? It is a honeywell CT 3200.
My new blanket works great. Then I changed my sheets and would get the F2 problem. Very consistent after 5 tries with F2 blinking by unplugging at wall outlet and comes on with F2 blinking. Let it rest a night and still the same.
Then I unplug it at the blanket. Hmm, notice a pin was lower than the others. PUSH BACK IN FIRM and tried again. Perfect.
Apr 03, 2010 | Honeywell CT3200 5-2 Day Electronic...
I have a new York hybrid heat pump/gas furance
Did they check the sensor in the plenum. You are suppose to have bonnet sensor to switch from heat heat pump to gas whaen it is to cold for the heat pump. The bonnet sensor may be to bad. The unit is cycling ever five minutes because it may have five minute time delay.
Dec 15, 2009 | Honeywell Programmable Thermostat Heater
Just installed the honeywell thermostat. the ac turns on, but not the heat. what do we do?
Some of the thermostats from Honeywell require a jumper wire on the thermostat between the RC and the RH connection for the heating to operate. It is possible that your installation needs this jumper wire installed for the heating to work.Verify that this jumper wire is installed if your thermostat requires it. If it requires the jumper wire and you do not have one you can cut a small piece of existing wire on the connections to make a jumper wire. There are also some thermostats with a jumper switch for electric heat and gas heat...make sure that it is on the proper setting.
Dec 02, 2009 | Honeywell Electronic Programmable...
Jul 24, 2009 | Honeywell Electronic Programmable...
No heating
We had the same problem and then had to pay $60 to have the guys who installed our original system tell us we just had the settings wrong. We thought we had "electric heat/cool", which is what we set the thermostat for. Turns out we have "auxhilary heat pump" or something like that. We don't have gas heat, it's electric, but apparently its not basic "electric heat/cool". So try changing your settings. Good luck!
Oct 28, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
223 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
