Question about Denon AVR-4806 Receiver
While updating firmware 4806 stopped in the middle and unable to update firmware or turn on reciever
  • Orlando Oliveira
    Orlando Oliveira Aug 02, 2013
    I HAVE THE SAME PROBLEM NOW. to solve the ITS?
Error: clean unable to maintenance see user guide 50 Printer model: Brother dcp-165c Pls help me how to solve.
If the display screen is displaying an error message, press the STOP/EXIT key to change the LCD to the main screen.
2. Press the STOP/EXIT and the UP ARROW key at the same time. The first 2 characters on the top row will determine the ROM version.
  • If the ROM version is OH or greater (example: OI, OJ, OK, etc), the firmware does not require updating. Go to WARRANTY AND SERVICE OPTIONS listed below.
  • If the ROM version is OA - OG (example: OB, OC, OD, etc), continue to STEP 3 to update the firmware.
3. A utility is available that will allow you to update your Brother machine with the most recent version firmware, by downloading updates over the Internet.
4. Choose your country.
5. Choose your language.
6. Choose Inkjet FAX/MFC/DCP
7. Choose your model
8. Click on "Downloads"
9. Under Notes/Information select the option - Click here to view firmware version history.
10. Close the window to continue with the firmware update.
11. To update the firmware please follow the instructions listed below:
DO NOT interrupt the process or turn off the machine once it has begun. Doing so may corrupt the memory on the machine and may require the machine be serviced in order to correct the problem.
12. Select your OS and language in Steps 1 and 2 on the website and then click on "Search".
13. In the next window, scroll down to the bottom of the page to locate "Firmware Update Tool".
14. Click on "Information & Download"
15. Scroll down to the bottom of the next page and click the "Download" button
16. Accept the license agreement.
17. A dialog box appears with options for "Run", "Save" or "Cancel". Choose "Run".
You may also download the utility for later use by choosing "Save".
18. A dialog box appears informing you that some information from the machine will be collected and stored. Click "I Accept".
19. A dialog box appears informing you what will be deleted during the firmware update. Click "Next".
20. The program will now begin to update the firmware.
Dec 07, 2010 | Brother DCP 165C Compact Color Inkjet...
What is happening to me iDJ2? He can not find the songs that are on the stick. Atualziar tried the firmware but it crashes after the screen "LOOKING FOR FIRMWARE. How to solve this problem? Help me please.
this is definitely a firmware problem. It sounds like it may have gotten disconnected in the middle of updating firmware. If you are unable to update firmware you will have to send it in for repair.
Aug 18, 2010 | Numark iDJ2 - DJ iPOD Mixer Docking...
How I do the firmware update so my i pod will
http://www.kenwood.com/cs/ce/mm/firmware/2008/eng.html
If you hit up that link, download the ver2.4 firmware, and put it on a disc, you should be able to pop that disc into your deck and let it update automatically. Turn on your car to allow sufficient power so that it doesn't stop in the middle and brick your stereo. It should just eject when you're finished. I think that might solve your problem.
Jan 21, 2010 | Kenwood DDX-512 Car DVD Player
Remote stopped working
Hey!
I have found when you are not able to control devices, a firmware update will sometimes fix the issue. If you do not know how to do a firmware update, please look at the following link:
http://logitech-en-emea.custhelp.com/cgi-bin/logitech_en_emea.cfg/php/enduser/std_adp.php?p_faqid=10747
If the firmware update does not work, you may have to learn the power commands from the original remotes. The following link shows how this is done:
http://logitech-en-emea.custhelp.com/cgi-bin/logitech_en_emea.cfg/php/enduser/std_adp.php?p_faqid=9603
I hope this helps!!!
-Kennedy
Jan 01, 2010 | Logitech Harmony 890 LCD Remote Control
Firmware won't update; Player won't turn on or show up on PC
if you use vista, try with xp... another post about and it worked for me.
May 16, 2009 | Philips GoGear HDD1830 MP3 Player
well done XP! device repaired :)
I'm so happy I didn't sell my travel notebook,
good enough for running XP slowly... very slowly.
I will left more space now than last time. Why I didn't
thought that some kilobytes aren't enough for operating.
May 07, 2009 | Philips GoGear SA5285/37 Digital Media...
Harman/kardon avr 247 no audio or LED display on the reciever
I've had the exact problem. HK in the states is no help, you need to deal with a company in Montreal (Jan Industries). Regular techs are unable to fix it without schematics that only authorized dealers have and the manufacturer. This problem happened to me just after 2 years and outside warranty. I've bought a Yamaha today.
Apr 01, 2009 | Harman Multimedia AVR 247 7.1 Channels...
Update problem
dear nokia bussions marketing....delhi
Jul 06, 2008 | Nokia N95 Cellular Phone
Troubles Transferring, now power
You are describing a software and firmware update.
The software update should not have any effect on the camera start-up, but the firmware update could.
Please check to see if there were any instructions sent with the firmware files (like a Read Me file or release notes), which might give you special instructions for properly loading the firmware. Some manufacturers require that you hold down certain buttons on the device when power cycling to load the firmware.
Also ALWAYS be sure to have newly charged batteries of the right type, because a power failure in the middle of a firmware upgrade can ruin a device, requiring service.
Go to their web site to get details about the firmware update, if you are sure you did infact update firmware. Also, their tech support should be able to assist you with additional issues if their recent release is problematice for any reason.
Good luck.
DigiChick
Jun 20, 2008 | Olympus SP-350 Digital Camera
Denon AVR-4806 Receiver Logo
89 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
