Question about Whirlpool MH7140XF Microwave Oven
Error message f3h on the sensor menu and won't heat on any other setting. Not certain of the model # aside from what's given below.
  • 1,772 Answers
Sorry to read about your problem, I hope this helps you out.
Your error code means your humidity sensor is defective.
1. Hold the CANCEL pad down while opening the door.
2. Unplug the power supply cord from the wall outlet for two seconds and plug it back in.
3. Release the CANCEL pad then close the door.
4. By pressing each of the pads on the control panel, the numeral 8 will appear in the display to indicate that the circuits are complete and all relays are working.
5. The pads that control the oven and cooktop lights, in addition to the hood fan, will also turn these components on and off for a visual indication that the circuits are operating properly.
Microwaves must be serviced by technicians due to the inherent dangers involved in repairing these appliances. Internal capacitors can retain a lethal electrical charge even though the unit is completely unplugged. A microwave radiation leakage test must be performed on the unit following any internal component repair.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Posted on Jan 03, 2011
Testimonial: "Thank you so much! We're back in business! I appreciate your immediate attention even though I was not able to pay anything."
Kitchenaid microwave khhs179lss-0 has error F3H
Hi, F3H mean that Humidity Sensor Failure. You have to refer to the Tech Sheet and test the sensor.
Mar 23, 2011 | KitchenAid KHMS155L Microwave Oven
Whirlpool Microwave error F3H
F3H Humidity sensor failure 1. Unplug microwave oven or disconnect power.
2. Connect a new sensor to the board (at P5).
3. Plug in microwave oven or reconnect power.
4. If no failure code appears when starting sensor function:
 Replace old sensor.
5. If failure code appears when starting sensor function:
 Replace power supply board.
6. Plug in microwave oven or reconnect power.
Aug 04, 2010 | Whirlpool GH5184XPQ Microwave Oven
Whirlpool gold gh5184xpb Everything seems to be working but it doesn't heat. If you use the buttons for popcorn or dinner plate, an error message F3H appears. Recently got a wireless router in our home...
its very unlikley to be the wireless router,,,
things like this just happen,,,i would say the magnatron had gust given up the ghost, thats the part that gets the food hot,,,safest bet is have it looked at but get ready to buy a new unit as its likley to be the cheepest way out
please dont go poking about inside your microwave,,
it will still have 1000's of volts inside it,,, these volts will kill you if you tuch the wrong part,,be warned!!!
Jun 05, 2010 | Whirlpool GH7155XHS Microwave Oven
Hello ... I have a Kenmore Elte model #665.63794300 and it has stopped working. I have unplugged it and also turned the breaker off but neither of those things has stopped the error messages of F3H and F7...
Unplug the unit for 1 minute to clear the ECU.
re-plug, and re-try.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jul 10, 2009 | Kenmore 63792 Microwave Oven
When trying to popcornn the sense goes off and F3H comes on
F3H means you have a failing humidity sensor, but the first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes. Then let us know if the hard reset does not fix it.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you don't find yours, or if you want to look at it without disassembling the oven, you can usually download it here.
You can usually find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
May 17, 2009 | Microwave Ovens
Microwave error message
unplug your unit for 1 minute and plug it back again, you'll be surprised ...it will work again cheers
Nov 26, 2008 | Whirlpool GH5184XPQ Microwave Oven
KENMORE ELITE MICROWAVE
F3H is a humidity sensor error.
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again. If that doesn't work, leave it unplugged for maybe an hour.
If it still fails, you have a bad sensor.
You can usually find exploded views and order parts by entering your model number at the Sears parts site.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
Nov 01, 2008 | Kenmore 62702 Microwave Oven
Error code F3H on model GH5184XP
You may be able to clear the error by unplugging the oven for a couple of minutes. Then plug it back in, reset the clock and try again.
If it still has the error after a reset, please write back so we can give you another suggestion.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 18, 2008 | Whirlpool Microwave Ovens
Microwave troubleshooting
I found the fix to the F3H error on another site. Just turn the power to the microwave off for ~2 minutes at the circuit breaker, and then turn it back on. Microwave will start working again then.
Feb 23, 2008 | Whirlpool GH5184XPQ Microwave Oven
Whirlpool MH7140XF Microwave Oven Logo
217 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
