Question about Nikon 85mm F1.8 D-AF Lens
Hi, just wondering if I should try an dismantle my 85mm 1.8 Nikon lens as the focus ring has slowly but surely stiffened up to the point it will no longer rotate- AT ALL! No budging. My brother tried to rotate it, but the rubber grip has now come loose, and slipped off. I fixed an oil problem on my 50mm aperture blades the other day, so I was wondering if I should go in the same way, if I should at all? Thanks, Matt
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Nikon Master
  • 102,366 Answers
If you have a lens collimator and other equipment required to ensure the proper alignment of the lens elements when you reassemble the lens, then go for it. If you don't have the gear needed to reassemble the lens properly, then I strongly suggest taking the lens to a good camera shop and have a trained professional do a clean-lube-adjust. It won't do you much good to have a focusing ring that turns if the lens elements are out of alignment so it doesn't focus properly.
Posted on Dec 23, 2011
Error messages nikon d7000
Nikon makes several different 85mm f/1.4 lenses, but it appears you're using one with an aperture ring. Turn the aperture ring to its smallest setting (largest f/number). You can control the aperture from the camera body, the same was as on a lens without an aperture ring.
Oct 23, 2013 | Rokinon Cameras
Hey there! I'm so glad for sites like these! Well, the point is, I got a FEE error on my NIKON D80 after putting on an old NIKON 28-85mm AF macro lens. Actually on aperture F22 it's working...
Leave the aperture ring on the lens at f/22. You can control the aperture from the camera body, the same way as on a lens without an aperture ring, by turning the command dial.
Sep 23, 2011 | Nikon 28-85 F3.5-4.5 AF ZOOM-NIKKOR Lens
Canon 7D -I have my setting on one shot - in any mode.- Lens: Canon 17-85mm. The autofocus jumps back and forth no matter where I focus at.
it means the lens is about to die.
i get same problem with my nikon 18-55 mm lens. the solution for my problem was that i shift from autofocus to manual focus on the llens and then back to autofucus. the lens works fine for me then :P
u can try the same thing.
Mar 02, 2011 | Canon EF-S 17-85MM F/4-5.6 IS USM Lens
My Nikon 85mm f 1.4 is not connecting with my D700. It's saying that it's a non cpu lens. Any insight?
Nikon has made at least two different 85mm f/1.4 lenses. Some of them have an aperture ring. If your lens is one of those, turn the ring to its smallest aperture (largest f/number, it should be f/16).
Oct 09, 2010 | Nikon Cameras
ROKINON AUTO ZOOM Macro--- HELP to enable macro
Some of the Rokinon (and other ) zoom lenses could only go into MACRO at certain focal lengths- the lens you have "zooms" from 80 to 200 focal length,but is that done by "sliding" a ring forward and back on the lens, or by twisting a different ring that the one that focuses?
May 16, 2010 | Rokinon 85mm f14 for Nikon
Will the Rokinon 85mm 1.4 lens autofocus with the Nikon D90?
No!
The Rokinon is like the Nikon 85mm AIS lens and is manual focus only..
Hope this helps, Andrew
May 07, 2010 | Rokinon 85mm f14 for Nikon
Canon 17-85 is usm lens very loose focus ring causing lens creep
I also have a 40D with exactly the same lens and fault. Over the course of a few months the lens became "sloppy" so if the lens was pointing towards the ground it began to creep. Towards the end it dropped to its full extent. About 10 days ago it locked up completely and I was unable to zoom at all. Returned to Canon as mine was just in warranty and they have fixed and returned it within 7 days. Very effecient even sending me a text message to say that it had been dispatched. The lens is now just like new and I only hope that this is not an annual trip.
Bottom line; I am an engineer by profession and I wouldn't touch it with a barge pole. To do these properly you need special tools and jigs to make sure things line up properly. It also needs to be done in a "CLEAN" environment.Do yourself a favour and leave it alone.
Apr 15, 2010 | Canon EF-S 17-85MM F/4-5.6 IS USM Lens
I just purchased the Nikon AF f/1.8 85mm lens and it's giving me an error message on my D300, it wont let me change the apeture via lens ring,if the ring is locked I can adjust it with the controll wheel...
There doesn't seem to be a problem with the 85mm.
Nikon has made a lot of different 50mm f/1.8 lenses, so I won't say anything about them without knowing which particular type.
Dec 25, 2009 | Nikon 85mm F1.8 D-AF Lens
I have a Nikon 18-70 DX kit lens as well and it cannot focus either. It will quickly hunts from infinity to close range while making screaching sound. I found that if I point the focus point at a lamp,...
HI I AM SAGHA FROM MUMBAI I AM A REPAIRER AND I THINK UR PROBLEM IS NOT SOLVABLE BY YOURSELF YOU HAVE TO TAKE THE LENS TO EXPERT THERE YOU HAVE TO GET THE AF SENSOR CHANGED.THIS WILL SOLVE YOUR PROBLEM DON'T TRY ANY MORE ADJUSTMENTS WITH CAMERA IT MAY CONFUSE YOU MORE.
May 13, 2009 | Nikon 18-70mm f/3.5-4.5G ED-IF AF-S DX...
Distance scale does not move on canon efs 17-85mm lens
Yes, this is normal. Some zoom-lenses adjust the focus when zooming, to always keep the subject in focus. Those tends to be the more expensive lenses.
So you don't have to worry, nothing is wrong with your lens.
/Chris
Jan 10, 2009 | Canon EF-S 17-85MM F/4-5.6 IS USM Lens
Nikon 85mm F1.8 D-AF Lens Logo
99 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
