Question about Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum
Bissel Proheat 2x circuit board
Hi Red,
Ive isolated my bissells brush roll stoppage to the circuit board part # 002-2036805. (Its in the handle, not in the bottom)
I cant find that circuit board anywhere to order it and Bissel wont let me even search for the part. Can I make that diode array with heavy duty diodes and a resistor? Do you know what kind of dc voltage that circuit board is sending to the brush roll motor? I tried to make a diode array with regular diodes but when the brush roll amperage comes up it blows them.
thanks
J Meredith
Use this link: http://www.4cleanerfloors.co.uk/cgi-bin/product.pl?PID=1278118_amp;brand=Bissell_amp;model=_amp;part=
I had the same problem. Ordered a PCB from Bissel it took 2 weeks to arive. I fitted it, then it blew again, turned out the brush motor was short circuiting. Ordered a new motor it took 10 weeks. I have now had to order the second circuit board.
Over 3 months to get this vac fixed - my advice is - don't buy Bissels!
Posted on Jul 23, 2008
Testimonial: "TY"
Reset circuit breaker in bissell proheat 2X
Hi, it's Jeremy from Crucial Vacuum.
There are a few potential solutions you should try. You can check the brush role to make sure nothing is lodged in it. Your vacuum circuit breaker will automatically shut off the brush if an object is caught in the brush roll. You can also try cleaning and lubricating the bearings on the brush roll. If that does not work the problem could be related to your belt. Belts should be replaced every 6 to 12 months for optimal performance.
You can purchase direct your replacement belts from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/catalogsearch/result/?q=bissell+proheat
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jeremy Lerner
Crucial Vacuum Customer Care
May 26, 2014 | Bissell 9500 ProHeat 2X CleanShot Upright...
I have borrowed a bissell proheat 2x from a friend and she did not have a manual. I cannot get the brushes to turn.
The User Guide for the Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner is available here:
http://canada.bissell.com/images/UserGuides/9500_107.pdf
Note that the brushes only turn when the unit is reclined using the detent pedal.
If machine has been jammed the internal circuit breaker may have been tripped. Unplug machine from power source, remove object or blockage and then plug machine back in to power source to reset breaker.
More seriously the drive belts may have become worn or have broke or a brush may have become detached; refer to page 18 for instructions on how to replace belts and brush rolls.
More information including a video and replacement parts can be found here by selecting the tabs across the screen below the picture of the machine.
http://canada.bissell.com/Products/p/9500/ak/more+info/Product.aspx
Apr 02, 2011 | Bissell 9500 ProHeat 2X CleanShot Upright...
How to get the beater brushes to work
Your belt is broken or has come off the track.
Mar 18, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
My bissel proheat has no suction
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will give you all the information you need to fix your Bissell Proheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
Oct 25, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell proheat 2x carpet cleaner
heatman101
May 30, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissel pro heat unit brushes will not engage
keep in mind they only turn when the handle is down. if that is not the problem, it is usually the belt.
David
May 24, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell 9400 Carpet Cleaner
I assume you checked the belts to see if any cogs were stripped of of the belt. If ok, then I wuld suspect the brush roll motor, it is any inexpensive part and doesn't take much for it to fail. Undo the top so you can get to it and unhook the belt and see if it still shuts of, if it does, ten replace it, it it doesn't, then there is a problem with brush rolls or belts.
May 13, 2008 | Bissell 9400 ProHeat Upright Wet/Dry...
My power brushes on my bissel carpet cleaner stopped working. They do not rotate. This is the 2nd power cleaner I have bought and it has the same problem as the first one. What is the problem with the...
The brushes will only work if the handle is released and the ProHeat vacuum is running . There is a micro switch inside the lower handle that switches on the DC carpet brush motor. The DC power for the motor comes from a Bridge Rectifier on the PC Board. petedcurtis@gmail.com
Apr 18, 2008 | Bissell Vacuums
Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum Logo
953 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
