Question about Husqvarna "Chain Saw - 16" Bar, 3 Hp
Starts and runs good for 5 maybe 10 min. then it dies and won't start and run right
    Brigadier General:
  • 4,088 Answers
Remove the fuel cap to see if the saw will run longer--if so, the fuel vent would appear to be plugged. If no help, then check the fuel filter, air cleaner, and muffler for plugging. Check the fuel lines for decay or other damage. Hope some of this helps!
Posted on Jan 03, 2011
2003 v70 new fuel pump starts runs 10 mins. dies won't start again for a few hours
sounds like a fuel filter issue is there an inline filter
Mar 19, 2017 | Cars & Trucks
2000 softtail dies with out warning
Might be trash in fuel system,check fuel filter for that first.If its dirty maybe you will have to have trash removed from the rest too.
Apr 20, 2010 | 2000 Harley Davidson FLSTC Heritage...
Husqvarna 323L gas trimmer runs & starts great but looses power after 10-15 min and if you give it gas it dies. let it cool and it runs great for another 10-15min. trimm has less than 5 hours
You have a clogged gas cap. Try this: The next time you run your trimmer and it starts to die, loosen the gas cap. It should start running again. It sounds too good to be true, doesn't it?! Well, give it try. Clear the breathing holes form debris, or buy a new gas cap.
Jim
Jun 07, 2009 | Husqvarna 28cc Gas Line Trimmer
88 Toyota Corolla backfires through carburetor.
If that is carbureted, and has a mechanical fuel pump, try running a length of fuel line from inlet side of pump to a gas can that has fresh, clean fuel, and if it runs good that way, you know problem is most likely in the tank. Removing the tank & cleaning it out is best solution from there. I'd even be tempted to add a small bottle or 2 of Lucas Fuel Sytem Cleaner to first fill in clean tank, just to help clean lines as well as carb.
May 20, 2009 | 1994 Toyota Corolla
89 regal won,t start but after 5 or 10 min. runs great
sounds like your fuel pump is going out. One thought might be that the fuel filter is causing enough resistance to over heat the pump. I would check the fule pressure to determine a free flow of fuel.
May 01, 2009 | 1990 Buick Reatta
Eng. dies just like you turn off swich starts backup runs great
Check the roll over protection switch. Make certain that the connection is good and not corroded.
RPM Northwest
Jan 17, 2009 | 2000 Jeep Grand Cherokee
1985 Toyota pickup 22r non cali emissions ( Drives then dies no fuel in carb)
I had a similar problem and it turned out to be the rubber fuel lines being old and cracked. The hoses would warm up and fuel would squirt out of the cracks. I had to replace three fuel line hoses and it has been running great ever since. Good luck.
Jan 15, 2009 | 1985 Toyota Pickup
Husqvarna "Chain Saw - 16" Bar, 3 Hp Logo
67 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
