Question about Volkswagen Vw Beetle Kit for 1998 Up
2001 vw beetle no head lights,wipers, horn,turn signals, blower motor
  • 3,083 Answers
I guess you're trying to locate these parts. A fellow that owns Foreign Aid VW Parts and Service here in Albuquerque, NM might be able to help you locate them, or have them for you. His name is Alex and his number is 505-255-9417. He's an old friend that has been in business for 30 years and should be able to help.
Posted on Jan 03, 2011
Heater blower not work on 2001 vw beetle
a couple of things to check fuse check each fan.speed unplug the wire to the blower motor and check for power the blower motor resistor could be bad or blower.motor.
Dec 05, 2013 | 1998 Volkswagen Beetle
Were is the blower motor located at on a 2001 vw beetle 1.8 turbo
The blower motor location on a 2001 VW Beetle 1.8 Turbo - Right Hand Drive (RHD) vehicle
Jul 10, 2011 | 2001 Volkswagen Beetle
Fuses panel described in English
Hope this helps your out. I know the diagram and locator is a bit blurry but hopefully it gets what you need.
Drivers kick panel:
Front wiper 20A - Front wiper system Cigar 15A- Cigarette lighter Audio 10A- Audio, remote control mirror Air Bag 10A -Air bag diagnostics Stop lights- 15A -Rear brake light, high mounted stop light ECU B+ 10A - Shift lock actuator, transaxle controle module, radio, engine control module Room 10A - Interior light, clock, ignition key reminder, rear cargo area light switch ABS 10A- Anti lock brake system control unit ECU IG1 10A - Transaxle control module, shift lock actuator, ABS control unit, DRL unit Meter 10A - Instrument panel, back-up switch, electronics time control module, inhibit switch Turn signal 10A- Hazard switch ,front and rear turn lights, turn indicator IGN1 20A - Ignition switch ABS 30A- ABS pump motor TNS 30A- Tail light, license plate light COOL/FAN 30A- Cooling fan Cond/Fan 20A- A/C condenser fan Starter 15A- Start signal , Fuel pump Blower 25A- Blower Motor SR/ACC 10A - Ignition switch Hazard 15A - Hazard and turn signal light D/Lock 25A- Door locks ABS 30A - Anti lock brake system control P/W RH 20A- Power window motor right hand P/W LH 20A- Power window motor left hand IGN2 25A- Ignition Switch
Engine compartment :
Head 25A- headlights IG 2 30A- Ignition switch IG coil 15A -Ignition coil, condenser,generator IC regulator, diagnostic connector. O2 down 10A- Rear O2 sensor O2 up 10A- Front O2 sensor Fuel pump 10A -Fuel pump unit Injector 10A -Fuel injector ,camshaft positioning sensor, purge solenoid valve, EVAP, IAC actuator, Mass Airflow sensor, EGR stepper motor. fuel pump relay coil, vehicle speed sensor. A/Con 10A - A/C compressor controls, cooling fan BTN 30A- Brake light , high mounted stop light. Tail light LH 10A- License plate light, tail light , rear combo light, instrument panel illumination Tail light RH 10A-License plate light, tail light , rear combo light, instrument panel illumination Head low 15A- Headlight Head Hi 15A-Headlight Horn 15A- Horn jlmacman.png jlmacman_0.png
Mar 07, 2011 | 1995 Kia Sephia
05vw beetle, items that don't work=horn,lights,blower motor,wipers,fog lights, heated seats.checked fuses on side of dash and on top of battery. No wires look burned. replaced the load reduction relay and...
any of the wires that feeds any of those items not working , will take you to the power source that
is causing the problem..could be a bad fuse,relay,automatic switch. some wires have internal fuses. you have to cut the wire in order to see ,, or test from one end to another for continuity.
the wire that feeds the horn lights ,blower and wipers, is the wire that comes from your ignition
and feeds power to all these items. so you must start by checking there, then following it to the fusebox, and finally to the items not functioning.
Dec 24, 2010 | 2005 Volkswagen New Beetle
My daughters 1998 vw cabrio has a top that won't go up or down. i need to find the fuse for it. i know it's not the motor or hydrylics i have already checked those out. so that leaves the button or the...
"my daughters 1998 vw cabrio has a top that won\'t go up or down. i need to find the fuse for it. i know it\'s not the motor or hydrylics i have already checked those out. so that leaves the button or the fuse... but i don\'t have a diagram for the fuse box. Please help. "
Here's the list and link for the fuse locations.
Fuse/Relay Locations on 1996 VW Cabrio.
Fuses, left to right:
1. Head light, low beam, left
2. Head light, low beam, right
3. Instrument & License plate lights
4. Glove box light
5. Wiper/washer
6. Fresh air fan
7. Tail light & side marker, right
8. Tail light & side marker, left
9. Rear window defogger
10. Fog lights
11. High beam & indicator, left
12. High beam, right
13. Horn
14. Backup lights
15. Open
16. Dash warning lights
17. Emergency flasher & turn signals
18. Fuel pump
19. Radiator fan & AC
20. Brake lights & cruise control
21. Interior lights & digital clock
22. Radio & cigarette lighter
Relays
1. AC
2. Rear window wiper
3. Digilant control unit
4. Load Reduction
5. Open
6. Emergency flasher
7. Fog lights
8. Intermittent wiper
9. Seat belt warning
10. Open
11. Horn
12. Fuel pump
13. Radiator cooling fan
14. Starting interlock
15. Open
16. Open
17. Open
18. Daytime running lights
19. Auto trans
20. Open
21. AC & power seats
22. Power windows
Google Image Result for http://www.2carpros.com/forum/automotive_pictures/266999_cab_1.jpg
Aug 23, 2010 | 1998 Volkswagen Cabrio
1999 VW Passat. Head lights Blower motor blinkers
yes, it's called the load reduction relay and it is in the 13 fold relay panel under driver side dash.
Mar 31, 2009 | 1999 Volkswagen Passat
Volkswagen Vw Beetle Kit for 1998 Up Logo
216 people viewed this question
Top Volkswagen Car Audio & Video Experts
xxxxxx xxx
Colin Stickland
Colin Stickland
David Payne
David Payne
Are you a Volkswagen Car Audio and Video Expert? Answer questions, earn points and help others
