Question about Hoover Floormate H3000 Upright Wet/Dry Vacuum
The motor on my Hoover FloorMate started smoking. What is causing the problem?
  • ccw918 Jan 04, 2011
    Thanks. You are probably right about the belt. I have cleaned the brushes and they turn freely. How do I get inside the unit to see what may be causing the belt to seize up?
  • ccw918 Jan 17, 2011
    Thank you. I agree.
  • 10,515 Answers
I am sorry to tell you that your vacuum motor burnt. The only remedy would be to replace the motor. But if the cost of replacing the motor is near the price of a new one, then might as well buy a new one.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Jan 04, 2011
How do I Replace reservoir and tubing assembly on a hoover floor mate?
Hello, this is Ava with Think Crucial.
You may check the online manual for Hoover Floormate in this link: Hoover FloorMATE Hard Floor Cleaner Owner Manual Also, you may call Hoover for assistance which is 800-944-9200
You can order replacement filters for your Hoover Floormate directly to us. You can check the filters in this link: http://www.thinkcrucial.com/search?type=product&q=hoover+floormate
As a special offer here is an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
Ava B.
Think Crucial Customer Care
Oct 13, 2016 | Hoover Vacuums
How do I check my hoover floormate deluxe spinscrub's filter and motor? Thanks in advance!!
The filter is at the top of the recovery tank (dirty water tank), should be replaced when dirty or odors occur. as to your motor, there is no way for an end user to remove any cover and check it. If you are experiencing noise, have it checked by an authorized service center.
Oct 20, 2014 | Hoover Vacuums
Hi, how do I check my hoover floormate deluxe spinscrub's filter and motor?
Hi Mike! To check the filter on the Floormate deluxe, remove the dirty water tank and pull up on tank lid to separate from the base. Check foam filter for debris, if filter has debris, rinse it with water. To prevent internal damage make sure you are using only the Hoover Floormate detergent. If the machine is still noisy and smells bad we recommend taking it in to a Hoover authorized service center. Follow the link to find the nearest service center to you. Hope this helps! Service Center Locator
My Hoover floormate motor started smoking. It is over 9 years old. I keep the floor brushes clean. I am wonder if replacing the mother is worth it.
MSRP on this motor is $69.95. Labor may be another $30.00. I often see these units in thrift shops, which may be worth a try.
Jan 29, 2011 | Hoover Floormate H3000 Upright Wet/Dry...
Smoke comes out when turned on and weak hum
The motor winding has probably shorted to the stator metal, or the armatur has shorted. You'll need a new motor.
Nov 25, 2009 | Hoover Floormate H3000 Upright Wet/Dry...
Loud noise, smell smoke, brushes turn slower than before, stoped using
yes there are replacement parts for your hoover call any athourized hoover dealer and give them your model # usualy the motors are more expensive than the hole machine
May 22, 2009 | Hoover Floormate H3000 Upright Wet/Dry...
Hoover floormate 500 making super loud noise when
You have a bad motor in the unit. It time for a new machine
May 07, 2009 | Hoover Floormate H3000 Upright Wet/Dry...
Hoover Floormate brushes won't turn
With the drive assembly removed it is a black rectangle with a black piece extending down and to the right. There is a metalic fitting that engages the brushes. With nothing attached turn the motor on with the switch. If it doesn;t turn either the switch is bad or the motor is burned out. If you have a voltmeter check the ouyput side of the switch. If voltage is there check the motor plug. If good there the motor is bad. Hope this helps. Yes, the motor does get voltage when the switch is on. You can find parts by entering Hoover FloorMate H3000 parts into Google.
Kirk Thompson
San Juan, PR
Oct 25, 2008 | Hoover Floormate H3000 Upright Wet/Dry...
Floormate noise
The motor sounds bad. Use the Hoover web site to locate a shop near you for warranty repair. hoover.com
Oct 09, 2008 | Hoover H3030 FloorMate SpinScrub 500...
Repack the Hoover Floormate
Did you ever get the handle off? I'm having the same problem.
Jun 28, 2008 | Hoover Floormate H3000 Upright Wet/Dry...
Hoover Floormate H3000 Upright Wet/Dry Vacuum Logo
308 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
