Question about Kenmore 23612 Progressive PowerMate Bagged Canister Vacuum
It stopped working while I was using it . I tried to plugged in different electric outlets but it still dead. What should I do or look into in order to get it back to normal?? thanks
  • 26 Answers
I would start by taking the wand apart. Be sure vac is unplugged from the wall outlet! You should be left with two pipe pieces, and the beater bar. I would also pull the hose from the canister unit itself. Once all the pieces are pulled apart, check the two or three prong wire connectors on each piece, both the female and male ends. If you have any dielectric grease, use a dab on each electrical connection. Once you reassemble, and still not powering up, wiggle the wand back and forth at the connection near the canister, and after the hose near where the switch is. If the vac cuts on after wiggling it, then you have a loose connection, and will need to tighten the female ends on the electrical connections, by squeezing them together slightly with a pair of pliers. Please rate if this works or does not work. Thanks!
Posted on Jan 03, 2011
No power coming on. Is it dead? Fixable?
can only be a few of the following-
*power source from wall outlet
*GFI reset on wall outlet
*Plug or cord damage(d)
*Brushes in electric motor are worn
Mar 16, 2015 | Vacuums
Lights on front of unit stopped working and a little while later the whole unit stopped working while in the middle of vacuuming
Take it to a qualified repair facility. Even as there isnt to much to a vacum let the tech check it out. Could be a faulty switch or controls. I dont think its a serviceable by homeowner problem.
Dec 20, 2013 | Kenmore Vacuums
No power
what make/model? did you try a different outlet? how old is it? common for these to have bad cords... Has this ever happened before?
Jun 07, 2012 | Vacuums
My dirt devil model bd10025w won;t recharge when plugged in and won'yt woek when plugged in
Assuming that you've tried a different electrical outlet, it may have a defective charger or a totally dead rechargeable battery.
Try Dirt Devil's customer help line:
1-800-321-1134.
Good luck from Detroit, MI.
Jul 18, 2011 | Vacuums
Hi, My Henry hoover has stopped working about 10
Check the motor brushes as well as the on/off switch.
Sep 20, 2017 | Hoover Vacuums
Using my wet/dry vac - less than 5 hours on the thing - it just stopped - can't get it to switch back on. Tried different plugs - different days. Although I purchased over 2 years ago, it has hardly been...
It may have gotten hot if you went too long before cleaning the filter. It sounds like you may have burnt it up. I hope not! You might also check to see if you tripped a breaker on the electrical panel. Try plugging it in an outlet that is not on the same circuit. If it works in another outlet, then you have just tripped a breaker.
Good Luck!
Jim
Sep 30, 2010 | Genie Company GV150 Wet/Dry Vacuum
It electrically stopped- no blockage or horrid noise just won't work! About 4 years old - and yes I have changed the fuse. Any answers?
have an electrician check the switch on the vac. probably went bad. also look for broken wires or connections.
you have tried a different outlet, right? also inspect power cord for any damage.
Apr 19, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Hoover Windtunnel shuts down after 15 minutes
Might be that its not exausting enough heat & stutting its self down..
Try cleaning all the filters & the hepa filter..
This will increase air flow & maybe fix the issue..
Hope this helps !!
rate me good ;o)
Jul 14, 2009 | Hoover U6630-900 WindTunnel Bagless...
Vacuum is not turning on
Try a ruling out a couple of things first before opening up the handle:
1) First lets make sure your outlet has power
a) can you plug anything else in and have it work?
b) is the vacuum plugged into a non-switched outlet?
c) will the vacuum work from a different outlet - in a different room?
2) Check the plug. Are the prongs loose? If so, you'll need to cut the
plug off, splice back the two wires (Black and White), then connect
to a new plug. You can get a new plug for $1-2.00 at any hardware
store.
3) Time to open up the handle:
a) sometimes the wires connected to the switch can become loose
and fall off. if that is the case just reconnect by plugging them
back onto the switch. You may also consider using pliers to
compress the connector onto the switch terminal.
Hope this helps!
Jul 05, 2009 | Oreck XL Ultra Bagged Upright Vacuum
Kenmore 23612 Progressive PowerMate Bagged Canister Vacuum Logo
142 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
