Question about Sewing Machines
The Teeth On my sewing machine are up But i want to Do free embroidery.. How do i put the teeth down?
    Genius:
  • 1,788 Answers
You either have a plate that goes over the feed dog teeth or you have a lever, usually next to the bobbin access door on the front of the machine. You did not say what model you have, this info is in your manual.
Posted on Jan 03, 2011
Hello, Please can you tell me how to lower the dogs teeth on Elna SU airelectronic 68 so as to do free hand embroidery. Thank you julie Roberts
The owner's manual would have that information. If you don't have it, here's one:
Instruction Manual Elna 68
unfortunately, Elna manuals are usually not free
You could probably also ask your Elna dealer how to do darning on your machine. You will also need a darning or free motion quilting foot for your machine. Your machine either has the ability to raise/lower the feed dogs or the machine came with a darning plate to cover the feed dogs.
The following video series may have some information:
Vintage Elna Air Electronic SU Sewing Machine Series Part Overview
Nov 13, 2017 | Elna Sewing Machines
I have a singer model 513. It suddenly stopped moving the fabric forward while sewing....the little "teeth" are not moving, is this a belt issue or something else?
The feed dogs are not pulling the fabric through the machine properly. There are gears and arms that make that all happen.
These parts can break. Look for a switch or setting that lowers the feed dogs for free motion sewing. Please let a professional trained technician make any repairs or adjustments.
Cheers,
Embroidery Services
San Diego, CA
Sep 14, 2017 | Singer Sewing Machines
Bobbin thread will not catch unless the foot is down?
Ashleigh--Your machine will work satisfactorily ONLY if the presser foot is down. When the presser foot is up, the tension disk is released, therefore, no tension = a big knot of thread.
To free motion quilt, you should drop the feed dogs. Install a darning foot (this foot is shorter in length so when it is lowered, there is a space between the presser foot and needle plate). The space allows the fabric to be moved easily while stitching.
Some sewists will free motion quilt without a presser foot (if they don't have a darning foot), but that is very dangerous as one can easily sew through a finger. However, even when sewing without a presser foot, the presser foot mechanism needs to be lowered in order to properly form stitches.
How to Free Motion Quilt on Regular Sewing Machine
Feb 25, 2016 | Sewing Machines
The sewing teeth were down for quilting, I cant make them come up again for sewing, wheel turns but teeth dont move, any suggestions?
Look at the presser foot and imagine they are at the center of a clock. Now look at 4:00. There is a horizontal wheel (dial) on the free arm that needs turning.
The feed teeth are lowered when you turn the dial on the front of the free arm to the left . Turn the dial to the right if you wish to raise the feed teeth. The feed teeth will raise as you begin to sew.
Look at #12 on page 2 here: http://new.husqvarnaviking.com/sitefiles/clientsite/57/57c874e2-c4de-4acc-a703-3d47b01f941b.pdf
Feb 22, 2015 | Husqvarna Interlude 445 Sewing Machine
Zig zag stitch not foewarding on fabric
Have you checked that the dog teeth are rotating to carry the fabric through. Sometimes if there is an embroidery feature to the machine the dog teeth may have dropped. There will be a button,slider or switch to drop the teeth. ALso check that the foot is fully down. Failing that it could be the timing and that needs a machine mechanic
Mar 27, 2014 | Kenmore 15718
Lower feed dogs
had a quick look at the manual for this at www.singer.com and I'd say your machine doesn't have the function to lower the feed dogs, many don't. It shows a darning plate which goes over the feed dogs to sew on buttons so if you are wanting to do free motion embroidery or similar, then use this plate to cover up the feed dogs.
Oct 10, 2013 | Singer 1507
Problem with brother vx-1120 will not feed fabric
This is usually caused by the feed-dog ( the metal teeth in the area below the needle) being down instead of up - run your finger under there (over the teeth) if they do not stick up above the base line of the machine, they cannot feed the fabric. If this is the case, look in your manual (or and online manual for your machine) and find out how to put the feed dog up. Other than this, some machines have a plastic plate which fits over the feed dog, so that you can do free machine embroidery, if this is the case, you should be able to remove this and the fabric will feed through
Nov 30, 2012 | Brother LS-2125 Mechanical Sewing Machine
SINGER CG 550
If the plate is moving up and down eithetr the teth are set far too high pushing the plate up or the teeth are set too far forward, I would go for the first, if the teeth are coming up well above the slot they are too high, they should be set so that when you look alongside the plate you can just see the top of the teeth, you can adjust the teeth by adjusting the screws underneath the machine where the teeth are.
Mar 03, 2010 | SINGER 7470 Sewing Machine
Husqvarna 950E, the feed teeth will not lower. I move the dial and they stay raised. Even when the embroidery attachment is on. Can I manually lower the feed teeth?
If the machine has been taken apart it may have been reassembled improperly so that the dial on front of freearm is interfering.
Also, try removing the needle plate. If the teeth touch the side of the plate they may not drop properly.
Aug 29, 2009 | Husqvarna Designer I
Hi I have a professional xl 1000 and would like to know how it is possible to put the teeth down so they dont catch when embroidering with a free foot Thanks Natasha Searls-Punter
hi again
i managed to sort my problem
i knew there would be some knid of switch but i didnt no where
but if you slide the bottom part of the machine that contains all the tools then there is a little switch there that puts the teeth down
Nov 19, 2008 | Singer Quantum XL-1000 Computerized Sewing...
Sewing Machines Logo
109 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
