An error keeps showing up beside the Start/Copy option...It isn't printing the whole page, and the colors aren't right.
  • 2,509 Answers
It needs to go through a cleaning cycle first, if that does not help you may need to replace the ink cartridges. You don't state what the equipment is!
Posted on Jan 03, 2011
The printer is showing an E sign in between black and color space near start copy
This E means that there is an error. Endure that there are no paper jams in the printer that could be causing this problem - if there isn't a paper jam, try to restart the printer by removing the power supply for about 15 seconds and this should clear the Error.
If that is not the problem, try and print a test page to make sure that none of the cartridges are empty.
Thank you for using FixYa! Have a great day and please remember to rate this solution.
Best regards,
BearWeb
Sep 15, 2011 | HP DeskJet F4280 All In One Printer InkJet
I just installed a Canon mx300 on my Mac (runs 10.4.x) and all seemed to go well. I can print but the black letters don't print black (actually, the same happens if I have colored text mixed in). It's...
If the colors in your document don’t look right, you can change whether colors are managed by ColorSync or your printer.
To change color management options for printing:
Open the document you want to print.
Choose File > Print.
If the Print dialog contains only two pop-up menus and some buttons across the bottom, click the disclosure triangle beside the Printer pop-up menu.
Choose Color Matching from the print options pop-up menu.
Select one of the following options:
Select ColorSync if you want the application you’re using to control the color management of the printed output.
Select “In printer” if you want the printer you’re using to control the color management of the printed output.
If you select ColorSync and don’t believe the correct profile is selected for your printer, you may be able to change it. If you see a Profile pop-up menu, choose Other Profiles from the pop-up menu, and select a new one.
I hope this info will help to sort out your problem..Regards
Jan 08, 2010 | Canon MX300 Office All-In-One Printer
How do I print a highlighted part of a page in a .pdf file in Adobe Acrobat 9.0, with an  iMac and a Canon MP620 printer. The print window does not appear to give me the option of printing only the...
LEFT CLICK JUST BEFORE THE WORK THAT YOU WANT TO START AT AND HOLD DOWN DRAG THE MOUSE DOWN AND THE COLLORED AREA WILL MOVE DOWNTHE PAGE JUST STOP IT WHERE YOU WANT TO END. THEN RIGHT CLICK WITH THE CURSER IN THE COLORED AREA , A BOX WILL COME UP LEFT CLICK ON COPY IF IT DONT COPY JUST OPEN A NEW PAGE AND RIGHT CLICK THE MOUSE THE SAME BOX WILL APPEAR CLICK ON PASTE, WHAT YOU HIGHLIGHTED WILL BE THERE THEN COPY IT AS YOU WILL
Aug 09, 2009 | Adobe Acrobat 7.0 for PC
My Dell Photo 926 stopped printing in color. It prints in black and white. If I make a copy, it can still make a color copy. I'm stuck.
hi ,
if u can make a copy in color , rest assure ,nothing wrong with the printer .
it s only needs a setting change to be done .
is your pc running on xp r vista ?>
if xp : click start-->run-->type control printers --> your 926 printer should be displayed -->right click on printer icon and choose preferances-->..click on advanced option --more options --see if print color image in black and white is checked ? if so uncheck it
if vista : click start ---the cursor would flash on "start search "...typre printers and press enter key ...then ..your 926 printer should be displayed -->right click on printer icon and choose preferances-->..click on advanced option --more options --see if print color image in black and white is checked ? if so uncheck it
Jul 19, 2009 | Dell 926 All-In-One InkJet Printer
Unable to add a functioning (second) printer, for greyscale.
Clicked on Start/Control Panel/PrinterI. Clicked Add a printer. Obtained (Copy 1) of my HP Photosmart C7280 all-in-one printer. Right clicked on (Copy 1)/properties. Opened Ports tab. Saw comment "Print to the following Ports. Documents will print to the first free checked port." A listed USB Virtual printer port, showed three printers -- my first printer, my copy 1 (& my fax printer) -- was unchecked. I placed a checkmark in this Port box. Both the original printer, and my copy 1 printer are printing just fine. *I have not checked to verify that my fax is functional.
I did rename the original "color". I renamed Copy 1 as "grayscale", and --under printer preferences, checked, under "color options", to print in greyscale.
Mar 30, 2009 | HP Photosmart C3180 All-In-One InkJet...
Test page data states "no" color support
If it is a WinXp operating system follow the bellow mentioned steps:
Go to Start> Control panel> Printers and other hardware or printers and faxes or directly to printer>
Check which icon has the check mark>
If it is Officejet 6100Series> Then Right click on the same and left ckick on Properties> Then in the bottom click on Printing preferences> and click on Color> Under color options> Click on PRINT IN COLOR> And down bellow click on Apply or Ok and close the window.
The same can be slected when printing from a specific document or photo>
All you need to dod is after you click on Print> Go To Printer properties> Then in the bottom click on Printing preferences> and click on Color> Under color options> Click on PRINT IN COLOR> And down bellow Ok / PRINT.
ForVista>
Go to Start> Control Panel> Then Printers or Hardware and sounds> then rest steps will be the same as WinXP
Good Luck
Sep 29, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Lex z25 not printing
Mine wasn't printing at all, but now its printing color. I still don't know why it won't print black, but what I did was go into the control panel, I clicked on printers and faxes found the Z25 and right clicked it. I then clicked on properties, I clicked on the advanced tab, went down to the bottom of that section and clicked printing defaults, that opened the window for the properties for the printer. Once there I clicked on options in the top right corner and clicked on Lexmark Z25-Z35 Solution Center. On the maintenance tab I clicked "Clean to fix horizontal streaks", it takes to you a pop-up that says "Clean and Test Nozzles" a page will start printing to show if you have broken lines or unbroken lines when you print, either way it should clear your nozzles enough for the ink to start coming out again. If you need to repeat it the "Clean and Test Nozzles" pop-up had a box that says "clean again. Once you are done with that you can close the pop-up. If that doesn't solve the problem there are other things to try on the maintenance page besides the "Clean to fix horizontal streaks". Hope it starts working for y'all too. I still have to figure out the black part.
May 06, 2008 | Lexmark JetPrinter Z25 InkJet Color...
Printer malfunction
2 possible soultions,
1. The color required to print the text ( ie: black or a variation of ) may have run out and needs to be refilled or replaced.
2. The other way that could help, is to select only the text you wish to print, by highlighting the entire text of the email, and then press and hold Ctrl while you press P to bring up printing shortcut menu and then check the "Print selected only" before attempting to print.
This should give you only the selected text, but if your black or the color required to print is empty, it may appear blank on the page, or show a low ink error.
Jan 12, 2008 | Lexmark X5150 All-In-One InkJet Printer
Photos
Does this help? You obviously have to insert the media type into the media slot on the far right.(omoademola) Using the top control panel Printing tasks Scanning/Copying/Faxing tasks Troubleshooting
The top control panel lets you print an image from a photo card, scan a document or image, and copy a document or image with the press of a button.
Button/Light: Function: 1 Power : Turns the All-In-One on or off. 2 Copy: light Illuminates when Copy Mode is selected. 3 Mode: Changes the copy, scan, or photo card mode. 4 Scan: light Illuminates when Scan Mode is selected. 5 Photo Card: light Illuminates when Photo Card Mode is selected. 6 Rotate: Rotates the image 90 degrees. 7 LCD Panel: Number of Copies- this changes the copy count. Note: This feature is not active in Scan Mode. 8 Display: Shows copy, scan, and photo card selections. 9 Resize: Enlarges or reduces the size of the image. 10 Page Preview: Shows a preview of the output. 11 Select: Secures an option. 12 Menu: Provides options for image. 13 Arrow : Scrolls left, right, up, or down. 14 Stop/Clear: Cancels a print job or clears a selection. 15 Color Start: Initiates color copy, scan, or photo card output. 16 Black Start: Initiates black copy, scan, or photo card output.
Jan 10, 2008 | Lexmark P4350 All-In-One InkJet Printer
Color print lines
try to replace with colour catridge bye
Sep 24, 2007 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Computers & Internet Logo
David Payne
David Payne
