Question about Sport & Outdoor - Others
I just want to know how to fix my sportcraft tx 4.9 treadmill.I start it set my speed it start running then after 7 seconds it stops and shows a 3 in the speed area why does it do that and how do i fix it
SOURCE: Sportcraft TX 2.5 treadmill - error code 3 - stops
Sorry I dont have the solution but I have the same problem.
Read somewhere that Sportcraft control boards had
a design flaw.
Posted on Dec 20, 2009
  • 218 Answers
SOURCE: I have aI have a sportcraft treadmill that stops working after 7
You will need to check the speed sensor for proper alignment and function. it should be located near the front roller or mounted on the motor. It should be within a credit cards width of the magnet or toothed wheel. If properly adjusted check with an ammeter to see if it is opening and closing by manually spinning the front roller or motor flywheel. If it isn't replace the sensor. If it is functioning make sure you are getting 5vdc to it across the wires. If you are not replace the upper control board(console). If you are getting the proper voltage then replace the lower control board(motor controller).
Posted on Aug 13, 2010
SOURCE: Treadmill stops after 7 seconds
you have a broken spinner. Take hte motor cover off and look on the opposite side of the motor. there will be a partof the spinner wheel there. I have yet to find a way to short cirut the connectors nor a replacement wheel.
Posted on Jan 08, 2011
  • 95 Answers
SOURCE: I have a sportcraft treadmill
You can also look for a replacement part by clicking on your model here: https://www.fitnessrepairparts.com/brand/View/67/SportCraft
Posted on Feb 25, 2011
  • 1196 Answers
SOURCE: I have a sportcraft tx
Most electrical materials or board can be affected with one fault or the other due to power surge, epileptic power supply, high voltage etc, the board capacitor diode, or resistor might be shorted. Since the motor works fine, the fault is from the the motor board because one the component mentioned above has been shorted. I will advice you replace the motor board on your sportcraft, you can get a replacement at either ereplacementparts.com or ebay.com
Posted on Mar 29, 2011
Sportcraft tx 2.5 shows code 3 and stops after a few seconds of running time.
If you wish to get some details treadmill repair and error code ; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Sep 07, 2016 | Sportcraft Exercise & Fitness
How can I slow down a Sportcraft TX 320 treadmill?
Hi There, hmmm.... am I hearing that the treadmill starts too fast? At over 1mph? Most US treads will start at 1MPH and some will allow selection of .5MPH in the maintenance mode settings maybe. Otherwise, this could be attacked by a technical crew, like jatinah electronics possibly. If the treadmill would be set at one speed only that could be accomplished by reducing the drive signal at the component-level. It is certainly workable, but I would need to know what the current speed is that is too fast for her, and her ideal speed. ;o)
Jan 15, 2015 | Sportcraft Exercise & Fitness
Starting Problem
see the video attached. LUBE too the rollers bearing front +back and test the drive belt motor, and replace if necessary.
God bless you
Jul 22, 2013 | Sportcraft Tx2.5 Tx 2.5 Treadmill Motor...
I have a sportcraft tx 2.5 and was cleaning it and some water got into the housing where the motor and circuit board is located. Now all I get is the number 7 on the display and it won't run.
Dear Sir:
1) Please unplug the machine
2) Put with air gum machine, and pass in all board and circuit for heating.NOT OVERHEATING.
3) Wait for 24 hours. if you have some infrared lamps, will be better.NOT OVER EXPOSED.
4) Turn ON the machine, and proof, if the problem remain, the board is faulty. and replace.
5) However try to RUN the software calibration for better diagnose, troubleshooting, and fix it. see the block diagram attached.
God bless you
Jun 09, 2012 | Sportcraft Tx2.5 Tx 2.5 Treadmill Motor...
Tx 2.5 is on 7
To reconfigure the controller to factory setting:
1) Hold both the "Mode" and "Stop" buttons down while removing the magnetic key.
2) While continuing to hold both buttons down, replace the magnetic key. All the lights will light up and "beep".
3) Whille continuing to hold both buttons down, press the + button.
It should now be reconfigured.
I hope this helps
May 28, 2012 | Sportcraft Tx2.5 Tx 2.5 Treadmill Motor...
My Sportcraft TX-400 Treadmill shuts off after 7 seconds
Dear sIR:
This by lack of LUBE, in your schedule maintenance DECK BELT. maybe the belt is worn.
2) Lube the roller bearing.
3) Align the belt see the diagrams
4) Test the input voltage motor, if there are voltage motor, the motor need repair.
5) Test the output voltage board, for input voltage motor, if there are NOT the board is faulty.
Now you can RUN the software calibration for diagnose, troubleshooting. See my personal TIPS for HELPs too.
sincerely. God bless you
May 06, 2012 | Sportcraft TX 400 Walking Belt
My TX 5.0 RC Sportcraft Treadmill stops and show in the screen a #3... Start normal, but in seconds stops... I want to know how to fix it... Thanks...
You will have to unscrew that part out of the treadmill and take it out, and then put it back in to see if that makes any difference. If for some reason that does not work, you may have to contact the company to get a replacement on your treadmill, or to see if they wil fix it for you. Since each treadill is different, defects are inevitable, so a person will have to use consider going this route if all else fails.
Jul 13, 2011 | Exercise & Fitness
I have a sportcraft tx 2.5 treadmill thats needs it stops on 7 sec evertime i moved and lost the manual to it what should i do
Can you give more details? are you saying it stops 7 seconds after you step on it, (every time)?
If so, have you had the treadmill a while? this is an indicator of a worn belt. the belt is not sliding like it should, and drawing too much current. your control board will 'clip' the current off after a pre-set time, to avoid burning up components.
other things it could be:
1. your belt is too tight. did you tighten it lately? When did your treadmill start doing this?
2. The motor is going bad, and drawing too much current.
3. motor control board is bad.
look at your motor's current rating: measure the current draw when you get on it. if the current draw is ~ 80% of the rated current of the motor, and your belt is good,..and not too tight, it could be the motor.
if the treadmill is stopping while only drawing 4 or 5 amps, I would lean towards the control board is bad.
cheapest way to get started troubleshooting. Ensure the belt is not too tight, (adjust to only about 3 inches slack, when you pull up on it). next. buy some belt lubricant and lube it up.
If this doesn't fix your problem, keep looking for other fixya help. someone with SportCraft TX 2.5 specific experience. Sorry, I only have generic help here.
good luck.
Jan 25, 2010 | Exercise & Fitness
Turned on, runs a few seconds, shuts off with a #3 on display
Contact the manufacturer. You need the optical disc. It is the speed sensor. Eric For Treadmill replacement parts, please contact our Consumer Affairs Dept. at (800) 526 - 0244
Aug 06, 2009 | Exercise & Fitness
Sportcraft TX 2.5 treadmill - error code 3 - stops after a few seconds of operation. ??? Thanks for any advice
a design flaw.
Jun 28, 2009 | Exercise & Fitness
Sport & Outdoor - Others Logo
51 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
