Question about Lucent AT&T Speakerphone 825 (21211)
Where can i get a new directory card?card is where i enter names of persons i weant to call. my old card is full and i need to enter new names
Sony sdcard root directory is full
There is a limit to the number of files you can copy to
the root directory of a memory card. The simple solution is to create folders for the photos...
then you can take full advantage of the memory capacity.
to make a folder right click in the drive select new folder you should name it
hope it helps
May 31, 2012 | Electronics - Others
What are the commands to switch directories in MS-Dos? and What is the command to run an executable file?
CD hit space - and desired folder name, to open that folder ENTER
MD hit space and name of new folder- make new directory or folder ENTER
CD.. - to go back to previous directory ENTER
To run an executable file just write the file name you want to execute and press ENTER, or file name followed by .EXE and press enter.
Hope this helps.
Sep 27, 2010 | Computers & Internet
The automated recording that comes on when the lines are full needs to be changed and the recording of an employees name on the directory needs to be changed. I have already changed the display name on the...
The persons name is recorded in their personal mail box.Thats done by pressing open voicemail or feature 981 followed by their password, press 8 or admin and press 1 to re record thier name in the company directory.
To re-record greetings, enter Feature 983. if your system has 2 digit intercom #s your default password is 120000 if your system has 3 digit intercom #s your default password is 1020000. once you have entered the password you will see 3 selections you can make .use the three soft keys under the display and select AA (auto Attendant). next press greeting and greeting again. next it'll ask for the greeting number your probably working with greeting 1. press record to start and ok when finished. dont forget to save the greeting or it will be deleted if you exit early. hang up when finished.
Apr 06, 2010 | NorStar M7310 Corded Phone
How do i restore the directory
In RPL mode, put the object on the stack. Enter the name you want for the directory (must not conflict with an existing object) between ticks and press STO.
Mar 18, 2010 | HP 48gx Calculator
How do i get the name of the person along with the number to print for adress on confirmation sheet
Please specify the model...some aren't able to do it but in all cases you have to be sure the full name is entered in the fax # directory.
Nov 06, 2009 | Ricoh Office Equipment & Supplies
Rename a folder in c drive using java code
import java.io.*;
public class RenameFileOrDir{
public static void main(String[] args) throws IOException{
BufferedReader in = new BufferedReader(new InputStreamReader(System.in));
System.out.print("Please enter the file or directory
name which has to be Renamed : ");
String old_name = in.readLine();
File oldfile = new File(old_name);
if(!oldfile.exists())
System.out.println("File or directory does not exist.");
System.exit(0);
System.out.print("please enter the new file or directory name : ");
String new_name = in.readLine();
File newfile = new File(new_name);
System.out.println("Old File or directory name : "+ oldfile);
System.out.println("New File or directory name : "+ newfile);
boolean Rename = oldfile.renameTo(newfile);
if(!Rename)
System.out.println("File or directory does not rename successfully.");
System.exit(0);
else {
System.out.println("File or directory rename is successfully.");
Mar 30, 2009 | Sun Java Programming Language (cdj-275)
Adding/deleting a new contact to the system directory
You can download the full phone manual from Panasonic here.
Mar 26, 2009 | Panasonic KX-T7630 Corded Phone
Cant store data
You need to connect an SD card reader to your computer and pull the card from the PPC-6700, copy the contents to a directory on your hard drive and then remove that card from the reader, insert the new card and copy the content of the directory you just copied the old card to the new card. That is all you need to do.
Please do not hesitate to contact me for more information or for other questions.
Please remember to rate this solution.
Sep 17, 2008 | Audiovox PPC 6700
Save & save as
Save= you save the recent one on the one existing. Means, all you have changed will be applied on to the file you have had.
Save as= you can put a new name (in a new place/ folder/ directory), means you will have a new file while the old one would be still there unchanged. But if you put the same name & directory with the old one, it would be applied to the old/existing one.
May 23, 2008 | Microsoft Office Professional 2007 Full...
Lucent AT&T Speakerphone 825 (21211) Logo
56 people viewed this question
Top Lucent Lands Phones Experts
george  peters
george peters
Paul C.
Level 1 Expert
tfelton3
Are you a Lucent Lands Phone Expert? Answer questions, earn points and help others
