Washer just makes clicking sound .Filled with water but won't run now just makes clicking sound.Tried all cycles it makes a little different click when I put it on drain/spin then selected no spin.but still won't run locks door but won't run at all.
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
f the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it. Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
Posted on Jan 03, 2011
What could be wrong with our washer So our washer filled up with water and then will not go into the next cycle even if we try to manually do it Do you know what could be wrong
  • Does Your machine have a little switch button activated by the top door? (You can hear it click as you open and close the door.). If that switch is not working, the control click can not let the machine advance to the next step in the cycle.
  • Let US know what you find. M B
Jul 08, 2014 | Kenmore 24032\24036 Top Load Washer
My washer wont fill up or spin on spin cycle. its not a front loader
SOUNDS LIKE A BLOCKED HOSE SOMEWHERE OR OBSTRUCTION IN WATER PUMP
Apr 08, 2014 | Frigidaire Washing Machines
The water pipes have been freezing up for the past two nights, got them thawed out, and started a load of laundry set on cold. Washer started normal, it made a small click noise as allways, and the water...
Have you taken the hose off of the back of the washer and checked to see if you are getting water to that point. Also check the inlet screen on the fill valve to see if it is clean.. You may need to replace the fill valve. There may be a screen in the inlet of the hose at the shut off valves.....So check both ends of the washer hose..... I would check the hoses first before I would replace the fill valve....Hope this helps
Feb 12, 2011 | Maytag Washing Machines
My washer filled up with water but then wouldn't agitate. We have tried different cycles and even tried a different outlet just in case. It is 6 years old and I am wondering if it simply has died?
If you move the cycle selector switch to other cycles will it run. Possible bad selector switch.
Your pressure switch stops the water and allows it to start the next cycle. It's a switch either in the control panel or at the top of the tub with a small tube connected to it which goes down between the inner and outer tub. As the water level increases the air in the tube is compressed until there is enough pressure to make the switch stopping the water from filling. This tube can get clogged and the switch won't work. Remove the tube and clean it out. Blowing on the tube when it's still connected to the switch will make the switch if it's working and clear.
Jun 07, 2010 | Kenmore 24632 Top Load Washer
No water running through cycle once filled....making humming noise once clicks into cycle
pump should be checked for restriction of movement,is there something blocking it?does the capacitor smell?if it does its blown(or meter check-more accurate),hope this helps
May 27, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Kenmore Elite King Size Top Load Washer
If your washer fills, agitates, drains, but will not spin, the likely cause is the gear case (transmission). A new gear case can run about $200 just for the part. With labor, this could be a bit expensive to repair. I hope this helps you some.
Jul 30, 2007 | Kenmore 22642 Top Load Washer
Washing Machines Logo
44 people viewed this question
Top Washing Machines Experts
