Question about Microwave Ovens
Delonghi ac930amq Hi thanks for your reply to my problem but the transformer is fine the problem is on the circuit board I have taken the front panel off and the circuit board has burnt out black all on the casing and you can see it has fried the terminals on the board this has happened to both I have currently got both in exactly the same place. I have contacted delonghi on that link you posted but they do not supply the circuit boards any ideas where I can get 2 from. 1 for each oven. Many thanks, Tom Lyon
  • Microwave Ovens Master
  • 9,098 Answers
Since you posted a new message instead of replying back to the existing thread, I have no real sense of context as to what we are talking about.
So I would have to point you back to Delonghi to ask them where to buy parts, then ask the parts people of the board is available. If not, then you'll you'll need to find a technician who repairs boards or replace the oven.
Posted on Jul 12, 2008
LG ldg3016st has no power on main control panel
Did you have any power surges in the house? Any thunder storms?? even if you are not using a microwave, but it is plugged in , you see the clock?? That means it is getting power and running the clock so while you may not be cooking in it, it is actually using power to run the clock functions. So, if there was a power surge, it damages a part on the main board called the Low voltage transformer. It takes the 120 volts from the wall and drops it down to the voltages the board needs to operate, sometimes 5,12 24 or maybe 30 volts. If the primnary winding gets damaged from a surge of some sort. it will no longer light up if that small transformer was damaged. That can happen without even blowing the fuse as the small wires in the transformer were never meant to carry the 15 or 20 amps the fuse is rated at. So the transformer goes bad and the unit is dead but no blown fuse. Have to check the primary winding of the low volt transformer to see if it has continuity. If not, will need new main circuit board. Sorry But $$$$$
Sep 16, 2017 | LG Microwave Ovens
CS Code
Inspect foil side of HV board for burned tracks toward lower side of board. If burned, check HV capacitors (High Voltage Capacitor Test Procedure) and HV transformers (High Voltage Transformer Test) for a short. Otherwise test other components as outlined above.
Solution: Replace defective components as necessary. If applicable, repair foil trace on HV board.
Hope that helps.........
Aug 29, 2008 | Amana RC17 Microwave Oven
I have an eden pure gen 3 model that was purchased in Nov. of "09". I thought it had a 5 year warranty but to my surprise it is only 3 so now it's out of warranty and no one will help me. I was given a...
Did you check the fuse ? If that is ok then normally what goes first is a standby transformer on the front board itself. There is thermal fuse located inside the transformer that goes open circuit. A fairly easy and quick fix.
Oct 14, 2013 | Microwave Ovens
DELONGHI MICROWAVE OVEN MODLE NUMBER AC930AMQ
Here is a direct link to the INSTRUCTION MANUAL for your DELONGHI microwave oven:
http://web1.dlservice.org/dlservice/dataload/istruzio/GB-5719109000.pdf
To view the User's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the manual.
You may need ADOBE READER installed on your computer to read PDF documents.
You can download this free at WWW.ADOBE.COM if necessary.
Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, then follow the onscreen instructions to install the software on your computer.
Please comment back here to this page if you have any details to add, have any questions, have difficulty accessing the links, or just require further general assistance and I will respond as soon as I see it.
I hope that was helpful to you, good luck and take care.
Joe.
Sep 26, 2011 | DeLonghi Microwave Ovens
No power everything was fine then nothing when i got home is there any fuses to check in the microwave
There is a fuse under the cover, as well as a couple of safety thermostats that can cause a dead oven. It may also be that the power transformer for the control circuit board has failed. I've seen several Sharp ovens where the transformer died because of power surges. This would cause no display and no functions even though the oven has power. Also, did you make sure the outlet your oven is plugged into has power? If it's a GFI outlet it may need to be reset, or a circuit breaker in your electric service panel may have tripped.
Hope this helps, and thanks for using Fixya!
Feb 28, 2010 | Sharp R-1850A Convection/Microwave Oven
I have a Delongi Microwave combi and need to locate the lamp, the model is AC930AMQ, so far I cannot see the lamp anywhere and need to replace it. If it is internal I have no prblem with that as I am an...
I removed the outer case by three posidrive screws and two security screws. The lamp is located in a downward position on the left hand side looking from the back. A normal 25watt 300c ses bulb is suitable so no need to buy original if you don't want to. Take care before removing cover by unplugging the unit and only work on the lamp area as there is high voltage present charged in the capacitors !
Oct 17, 2009 | DeLonghi Microwave Ovens
Instruction manual sought
You wil get it here :https://www.2instructions.com/search.php?cmarque=DELONGHI&modele=AC930AMQ
I hope this will solve your issue.
Good Luck.
If my solution proves useful please accept it.
Regards
Arjun
Apr 01, 2009 | DeLonghi Microwave Ovens
Where is the 10 amp fuse on my delonghi micro/combo/grill please
Hi, I take it that this is a combi microwave? Some of these have settings on the front to microwave/grill/etc... so make sure its on the right one first!!
If you have selected the correct one then the m/wave does not work it could be several things!
Microwaves run to earth and need diodes to do this if these break down it will not m/wave! It could also be a internal fuse? ( but very unlikley if everything else works) Then you have the Mag or transformer which could be down to! M/waves run on a high power side and a low power side. The low power will not hurt you to much but the high power side will. My advice to uou is not to touch as it could be fatal as these things carry a high charge even when they are unplugged!
Dec 28, 2008 | DeLonghi MW 605 Convection/Microwave Oven
I have a delonghi ac930amq microwave with convection oven which does not turn on or show any signs of life at all the back has been opened and inspected there is no signs of any strange smells or an...
If there is continuity between the two terminals of the high voltage capacitor, then it is shorted and will need to be replaced.
When the cap shorts, it will blow the fuse, too.
You can get Delonghi spares here.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 08, 2008 | DeLonghi Microwave Ovens
Delonghi AC930AMQ Microwave, Interior Light Bulb
The bulb is usually run by one of the door switches, but in some cases they are run by a relay on the board.
I would suggest you look over our files on safety & door switches here:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/doorsw.txt
Please write back with more details if you need further help.
Jul 05, 2008 | DeLonghi MW 605 Convection/Microwave Oven
Microwave Ovens Logo
209 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
