Hello, I am experiencing a problem with my wall furnace. It is a Williams branded furnace. I have replaced the thermocouple twice, and the pilot was working for a while and functioning perfectly, when a few days ago it went out. I can light the pilot but it will not stay on. Here are some details I found on the pilot: Robert Shaw 7000 MVRLC NAT 4.0 VC For millivolt system only P323011 Thank you for your time. - Erick R.
  • Anonymous Jan 03, 2011
    Will replacing the pilot assembly resolve this? I will look into the gas valve tommorow. What do you mean by the intermetent? Thank you for the kind reply.
  • 472 Answers
Sounds like the gas valve may be failing .... possibly a small leak in the diaphram of the gas valve...
what your describing i to would start with the thermocoupler and usually that would correct the problem,but if you have done that and it still is shutting off and you are not getting any drafts that would cause the pilot to go out .then i would say the gas valve is your problem and it is intermetent failing....
Posted on Jan 03, 2011
    Will replacing the pilot assembly resolve this problem? I will look into the gas valve tommorow. What do you mean by intermetent failing? Thank you for the kind reply.
Williams wall heater 2509622. How do I keep the pilot on? It tends to turn off after it reaches the desired temperature.
WILLIAMS 2509622 OWNER'S MANUAL Pdf Download.
www.manualslib.com > Brands > Williams Manuals > Furnace > 2509622
2509622; 2539622; 2559622; 3509622; 3539622; 3559622; ... WHAT TO DO IF YOU SMELL GAS: ... Williams furnace co. direct-vent wall furnace owner's manual (24 pages) ... Caring for Your Furnace ............24-25 Locating Wall Furnace and Thermostat ........6-7 Learn how to keep your new Williams Furnace operating.
How to light Heater or Furnace Pilot Light Gas Pilot of ...
? 5:01
https://www.youtube.com/watch?v=FZVQmKTYTTg
Oct 25, 2013 - Uploaded by 3p0cHx
How to light a gas pilot for a heater or furnace of the Williamstype. This is a general guide and is not ...
[PDF]Monterey Installation Instruction Manual - Home Depot
Dec 08, 2015 | Williams Heating & Cooling
How do I install a thermocouple part #322391 in a Williams gas furnace
Gas furnace will not light. Thermocouple test with the ...
? 4:03
https://www.youtube.com/watch?v=suen7QlJl4o
May 12, 2012 - Uploaded by grayfurnaceman
I show how to bench test a thermocouple for a gas furnace using a multimeter. This video is part of the pilot gas furnace playlist.... Pilot Light Won't Stay Lit - How to Replace a Broken Thermo Couple on Furnace - Duration: ...
Oct 29, 2015 | Williams Heating & Cooling
The pilot goes out when the heater cycles
The thermocouple is not working correctly. sometimes you can clean the soot build up from it and it will work again. sometimes they just need replacing. the thermocouple is what the pilot light flame heats up when you turn on the heater. when the thermocouple gets hot it sends a 20 to 60 millivolt signal to the gas valve to activate the gas flow to the main burner.
Feb 18, 2015 | Williams Wall Heaters: 50,000 BTU/Hr...
Williams wall furnace model 5009622A pilot light will not light
make sure the thermocouple is sitting 3/8 to 1/2 inside the pilot flame when lighted. if it isn't, it wont generate enough dc current to keep pilot on
Dec 30, 2014 | Williams Heating & Cooling
Williams wall furnace 5009622 the pilot light will not stay on
The thermocouple is bad and needs to be replaced...
The thermocouple is the copper rod that sticks up into the pilot flame and then screws into the gas valve...
they are sold by lentgh so you need to measure the old one when you go to buy a replacement...
heatman101
Jan 06, 2011 | Williams (5009622) Ceramic Gas Wall...
Pilot Light won't stay lit on wall furance
The low voltage wiring and the thermostat has noting to do with the pilot function of the wall furnace, check to see if when you have the pilot lit manually, while holding the button in does the flame impinge on the thermocouple and does the flame try to wrap around the thermocouple? if not the thermocouple and pilot flame need to be adjusted so that it impinges on the TC, if it does have a good flame impingment, then you probably have a bad TC from the factory, call them and have them send you a new one if still under warrenty.
Jan 20, 2009 | Williams 1403622 Gas Compact Heater
Heating & Cooling Logo
108 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
