Question about C3RS915 SST Remote Car Start Vehicle Security System with 2way L
After install every thing but the starter itself won't start no matter what i do. can anyone help me ? or if you know how to reprogram the remote please show me...
    New Friend:
  • 103 Answers
Did you follow the procedure for programming the remote starter portion of the unit yet?? We get 20-30 calls a day because people do NOT program the starter to start a certain way. It is specified in the INSTALLATION manual that the unit needs to be programmed before using the remote starter.
Posted on Jan 12, 2011
Reprogram remote car starter
I have experience with mine that I have to press lock twice then hit the remote start or it will not start.
Jul 04, 2017 | Hyundai Cars & Trucks
My remote car starter from autostart on a grand am 03 won't start or locks won't work after it died for about a week then changed the batteries
Check to be sure the new battery is a good new one, they set on the shelves for some time ya know. Then make sure it goes in the correct direction.Then refer to your owners manual if it needs reprogrammed.
Feb 18, 2013 | Cars & Trucks
I installed prostart remote starter in 2002 Sonoma,used xpresskit bypass module to bypass passlock 2, truck started with remote ,now won;t start with remote,have to reset and start with truck key
If you are sure that everything is connected properly, then the only explanation could the ground when running from the remote starter to the bypass. If you are using data to data(D2D), switch over to wire to wire. Test the ground when running connection from the remote starter (white) to the ground when running connection of the Xpresskit (blue). You could even go so far as to connect the ground when running of the bypass to constant ground for the test. You CANNOT leave this wire connected to chassis ground.
Also, that vehicle has a second ignition wire(white) that MUST BE power up for remote start. If not, it will trigger the check engine light.
Oct 01, 2012 | Vehicle Parts & Accessories
I have a dealer installed cool start remote starter installed in an '04 LS430. Was working fine until new battery installed. Now doors open and close remotely, but starter does not initiate. Any ideas?
take it back to dealer ,might need reprogramming ,these things are always a pain and go wrong i have seen them on imported cars here but i have had to disable them as they are illegal here as its an offence to leave a unattended vehicle running .
Jan 05, 2011 | 2004 Lexus LS 430
How do you reprogram (reset) the remote starter after power has been disconnected? I dont know what model
Most remote starters do not lose their "memory" when power is lost. However, if an older version bypass module was used for your vehicle it may need to be reset but you must know the model. If you are not able to look under the dash panels yourself, you should take it to your nearest dealer/installer. Some also reset or relearn after the first key start. The FCC number off of one remote may help narrow down model of the remote start also. Vehicle info will also be helpful. DC
Nov 04, 2009 | Omega MARS-22 Remote Vehicle Starter with...
My nissan sentra 95 wont start and its not the starter
it sounds like a starter kill relay was installed on your nissan, if there is a relay in line with the black/yellow or black/blue starter wire under your dash you may need to bypass it, or you might need to reprogram your remote to close the relay when you unlock your doors
Jul 15, 2009 | Bulldog Remote Starter & T-Harness Kit for...
Viper 5900 remote start does not show it is off on the remote.
try a couple of things, 1) try unplugging the anntena for the alarm for about 5 minutes. 2) remove battery from remote for 5 minutes 3) reprogram the remote
May 21, 2009 | 5900 SST 2-Way Security System / Remote...
Trouble getting car to start-"Security" light goes on...
I spoke with a customer service person at Viper, they said that the starter is "skipping", specifically that I need to bring it to whoever installed it (Best Buy, in this case) and have them reprogram the module. This should resolve the issue. When I described the problem, the CS person seemed to know exactly what I was talking about--as though it is rather common--and assured me that the installer(s) will know exactly what it is and how to fix it.
Feb 12, 2009 | 5900 SST 2-Way Security System / Remote...
Bulldog remote start
Its a Fault in the Moduel and The Tech support Dont know How to Repair it I Installed a Bulldog Remote start/lock/tail gate on a 02 Blazer and 1 Year later it did the same thing, I just Disarmed it and forgot about it the Owner tried to get help from them to NO Avail.
Jan 20, 2009 | Bulldog Remote Starter & T-Harness Kit for...
Stumped can get this car to start
if its auto check inhibitor switch also check ignition switch and all fuses
May 26, 2008 | 1995 Pontiac Bonneville
C3RS915 SST Remote Car Start Vehicle Security System with 2way L Logo
389 people viewed this question
Top Autopage Vehicle Parts & Accessories Experts
John
John
Charles Osborn
Are you an Autopage Vehicle Part and Accessory Expert? Answer questions, earn points and help others
