Question about Proform Crosswalk 500 Treadmill
I have a Proform 625 treadmill. The unit had been working fine until recently. The unit lights up, the belt moves but never gets up to a higher speed then when it starts up.
SOURCE: Proform 765 EKG
If I understand correct, the treadmill will not run correct unless you have the safety key in. Well yes this is correct because once the safety key is removed the treadmill will stop. If your treadmill is running extremely fast just by turning it on, you may need a new speed sensor. www.AtlantaFitnessRepair.com
Posted on Aug 24, 2009
SOURCE: Proform 520
Not sure what's happened here. treadmill won't turn on when red key is inserted. checked electrical plug to make sure it worked. I couldn't see that there's anything wrong with the red key. Have any ideas?
Posted on Sep 12, 2009
taran_2005
  • 10515 Answers
SOURCE: Proform 765 treadmill slows down when step on. Do
More likely time to replace the belt. Let me provide you with all the information you need. This information is already there on many websites.
BELT LOSES POWER
(Bogs Down or is Sluggish) This condition is when the treadmill operates normally without a person on the belt and then slows down when someone steps on the belt or when the treadmill operates normally for a given period of time with someone on the belt then abruptly begins to slow down.
There are four typical causes for this problem (listed in order of our experience:
1) The walking belt and/or deck are worn. (85% of the time)
2) The walking belt and/or motor belt are too tight- if you have adjusted either recently. (8% of the time)
3) The motor has lost torque and needs brushes or has demagnetized. (5% of the time)
4) The controller is dropping output. (2% of the time)
Walking Belt is Worn:
The only certain way to test for a worn walking belt is to take a DC amp draw (if you have a DC treadmill) or an AC draw (for AC). Trying to look at the belt or a feel test is highly unreliable. Better tests, if you lack a DC ammeter (they are expensive for a good one), are a coast test or an incline test. To test the deck, go back to the Troubleshooting section and download the belt and deck inspections instructions. The coast test is to get on the treadmill as the lowest incline setting and walk on the treadmill at 3 MPH. Pull the safety key and it should take you 2-3 full steps to stop (this is a general rule…some like a few Tunturi models stop on a dime even with a healthy belt but most this tests works well upon). Fewer steps indicate high friction.
The incline test is to put the treadmill at max incline and walk on it at 3 MPH. If the treadmill operates normally at max incline but bogs down at minimum incline, replace the walking belt. Gravity takes over for the drive system eliminating the friction problem. On some heavily worn walking belts, this test will not eliminate the problem.
Walking Belt/Motor Belt too Tight:
If you have adjusted the walking belt or motor belt recently, check for this problem. When the belts start slipping, some people just crank down the belts and on treadmills, tighter is not necessarily better. The
tighter the belts, the more the drive system has to work to keep everything moving. You should be able to lift the walking belt (with the treadmill unplugged) in the center of the treadmill about 3” without straining. Tighter belts should be loosen but make sure you don’t create a dangerous slipping situation by loosening.
The motor belt (with the treadmill unplugged) should be able to be turned by hand to almost a 90 degree angle from its normal operating position. Loosen the belt if too tight. Make sure to test for slipping and if it does with the proper tension, replace the motor belt.
Needs Brushes / Demagnetized Motor:
Typically when we find a motor that has lost torque; it needs a new set of motor brushes. Typically we can make brushes for almost any motor if we don’t already stock them. Motor demagnetization is not that common but it does happen and it is normally easy to diagnose. If you have confirmed the belt and/or deck is not worn and the belts aren’t too tight, you can test for a motor torque problem. DO NOT USE YOUR HAND OR ANY OTHER BODY PART TO IMPEDE THE MOTOR…YOU WILL LIKELY LOSE YOUR BODY PART IN THE PROCESS IF THE MOTOR IS GOOD. The step to test for the motor is to use a foreign object preferably on a long shaft. First determine the direction of the motor spin (most have directional movement printed on the motor tag), then apply pressure with an object with downward pressure on the flywheel in the direction the flywheel is turning (do not attempt to put force against the rotating direction of the flywheel as you can easily injure yourself). If you can slow the motor, typically you need brush replacement.
To test for demagnetization, the motor must be disassembled. Once you have the motor retaining bolts removed, remove the motor core by sliding it out of the end of the housing. If the magnets pull the core against the housing and it is difficult to remove, the magnets are good. If the magnets do not attract the core, the motor has to be replaced.
Controller:
This is the most uncommon of the causes. Typically replacing a controller in this situation will not solve the underlying problem and then you will end up replacing a belt as well as a control. Normally if a control is dropping output, it will do it with a person on the belt or not. Tests of DC output dropping is normal in many controls since they have a current limiter which will automatically drop output to prevent burning up the board. This is best diagnosed by eliminating the other possible problems first. If you are left with the control as the cause, replace the control.
The site :-
http://www.treadmilldoctor.com/Treadmill-Belt-Bogs-Down
Any further assistance, let me know.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Oct 10, 2009
  • 64 Answers
SOURCE: Proform Crosswalk Dual Motion Cross Trainer
I think you are talking about the front roller. It has a rubber sleeve that helps to grip the walking belt. Sometimes you can tighten this enough to keep it from slipping but you run the risk of overtightening and damaging both rollers. We recomend replacing that roller.
Posted on Nov 18, 2009
SOURCE: The belt on my ProForm Crosstrainer treadmill stops while using i
Sometimes the tread needs to be lubricated. This was the case with ours. You can get a lubrication kit at ****'s Sporting Goods or other larger sport stores and it will instruct you on how to do it.
Posted on Jan 26, 2010
Pro form 320x treadmill stops working when you get on it
How can I get my Proform 320X treadmill from stopping a ...
www.shopyourway.com > Manage My Life > Questions
How can I get my Proform 320X treadmill from stopping a few seconds after starting? ... -why-does-my-proform-treadmill-belt-only-move-a-few-seconds-stops
ProForm Treadmill 320x User's Guide ' ManualsOnline.com
fitness.manualsonline.com > ... > ProForm Treadmill
ProForm 320x Treadmill User Manual. Page 1. Page 2. Page 3. Page 4. Page 5. Page 6. Page 7. Page 8. Page 9. Page 10. Page 11. Page 12. Page 13.
Nov 03, 2015 | Exercise & Fitness
When starting, the motor starts sluggishly. It sounds different and goes very slowly. At higher speeds, way high, it runs fine. Speed censor says one thing, but tread moving very slowly.
Treadmills are usually made up of various components. The rolling surface (tread) is usually placed on a set of rollers when the unit starts due to the low friction between both the surface (tread) and the rollers the surface (tread) starts slowly while the rollers move regularly and the sensor is placed on the movement of the rollers.
What you need to do is get the unit serviced usually there is a way the tread it tightened to have better grip on the rollers. This method differs from one make to the other so get an expert who knows about proform rollers. Once the system is tightened the problem will be solved.
Hope this solution has been helpful?
Jan 05, 2011 | Proform 595LE Treadmill Walking Belt
I have a nordic track c2255 - having belt issues when I run(i am 200 lbs and the belt skips) i think the tread is properly adjusted - I took the cover off and noticed two idler arm spring settings - a...
Hello there, Your are perfectly fine by making that adjustment. That is actually what it is for. When the belts get older and start stretching you can move that spring and get more tension. It does not harm the roller or the drive motor.
Godd Job! Tim
Jan 03, 2010 | Nordic Track /proform Treadmill...
I have a ProForm 625 and the belt has started to slide to one side. How can I fix it?
Check the rear end cap. (end where the adjusting screws for the belt are) check for cracking around the screws they have more than likely broken through the end cap and are no longer adjustable.
Nov 10, 2009 | Proform Weight Loss 620 Treadmill - 24755
I have a proform xp 550s treadmill. The belt
change drive belt proform xp 550s treadmill
Aug 26, 2009 | Exercise & Fitness
Treadmill will not maintain the correct speed.
You can get a book by calling 1-800-999-3756. The treadmill you are usine in a cheaper model. the motors on those units are not that strong. when you incline your unit gravity make the belt move faster. Remember incline put a lot of pressure on you lower spine. This can cause injury for some.
I’m happy to help further over the phone at https://www.6ya.com/expert/howard_079189dd4959a511
Jan 29, 2009 | Proform XP Weight Loss 620 Treadmill
Proform 10.5 QM treadmill
Your problem is the motor controller. It usually burns out sometime after the 8 year mark if you don't replace the belt routinely. You'd have to replace the belt and the controller. Parts for that would be about $300.
Jun 11, 2017 | Exercise & Fitness
Proform Crosswalk 500 Treadmill Logo
127 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
