Question about Drills
I need a switch for my 3/8 Milwaukee right angle reversing drill . Do you know where I can purchase one? Thanks
  • 8,404 Answers
Check with the manufacturer for this switch ... or any of the several advertisers here at FixYa.com ... or there is probably a electric supply in your town ... have them order one for you. Here is the manufacturer: http://www.milwaukeetool.com/parts-service/find-service-center
Thanks for your visit today.
Posted on Jan 03, 2011
My cordless drill is running at half RPM. Is it the brushes or the motor?
cordless drills have a switch that allows for more torque at lower rpms si in effect it is a 2 speed drill coupled with a variable speed switch that alters the rpms
If the drill is running I would be looking at a speed control problem at this point I would be looking at the torque control switch
Jul 01, 2015 | Milwaukee Hand Trucks Milwaukee Electric...
How do i troubleshoot a milwaukee right angle drill trigger
Take care with that, Edward. These Care and Operating Instructions may help... http://documents.milwaukeetool.com/58-12-1561.pdf
Feb 07, 2015 | Milwaukee Drills
Where can I buy a new forward/reverse switch for a metabo right angle drill?
you can try going to ereplacementparts.com and typing in your model number buy a switch from them. If you have a problem finding one let me know and I will check into another site for you.
Apr 05, 2012 | Metabo 600626761 Na 1/2" 0 550 Rpm 6.0 Amp...
I dropped my milwaukeee right angle drill, now it is not working. Is it repairable or toast?
anything is repairable if you want to put enough money in it. But first I would remove the battery and then the handle halves to check for loose wiring or broken electrical connections. Try another battery first and look at the battery contacts for loosse connection. If you have a volt/ohms meter try from the battery contacts to the brush leads to find your problem. You can go to milwaukeetool.com and download a breakdown and also a wiring schematic for this tool so you know what you are getting into. Let me know if you need more assistance.
Apr 20, 2011 | Milwaukee Tool Milwaukee 0721 - 20 V28...
Electric Milwaukee drill locked in reverse
This is a common issue with drills, you can resolve the issue by purchasing a new trigger switch and installing it. It is a very simple task. all you will need is a screwdriver and about 10 minutes.
Mar 09, 2011 | Milwaukee Electric Drill 1/2in. Chuck...
How do I change the chuck on my milwaukee right angle 1/2" drill? It has snapped off behind the chuck
Take digital photos when taking the front metal gear box off the drill. Next carefully remove the two plastic halves of the drill if needed to gain access to the shaft that holds the chuck.
Replace the broken threaded metal part that the chuck screws onto.
Normally chuck replacement involves unscrewing the small screw deep inside the chuck on a metal shaft has a left hand thread. Next use a large allen wrench tightened in the chuck with a mallet to loosen the bad chuck. Reverse to install new chuck.
Feb 01, 2011 | Drills
Need to remove the chuck on my 3/8 milwaukee drill. I opened the chuck and removed the screw in the bottom but can't get it off. does it pry off or unscrew? right or left hand screw???
if this is a cordless drill please review the tip section, if not the spindle has a hex that you can put a thin wrench on and the threads are standard meaning you would use a chuck key or allen wrench to hit it in the counter clockwise position to remove it. Let me know if you have any problems
Nov 23, 2009 | Milwaukee Tool Drills
Drills Logo
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
