Question about Refrigerators
How much will it cost to fix a Kenmore side by side refirg. that is not cooling.It is a 2003 model.
  • Barrett Palumbo
    Barrett Palumbo Jan 03, 2011
    no way to tell without looking at the unit, contact a service company
  • 472 Answers
DEPENDS ON WHAT IS GOING ON WITH UNIT.... IS THERE FROST BUILD UP in the back of freezer section if so then you know the compressor is working most likely could be a defrost issue and these are relative inexpensive to repair.... if the unit is not cooling at all and you have no frost build up is the unit clicking from the rear of unit ...could be a start relay on the compressor that has failed.... some of these units also have control boards on them that start the unit and stop the cycle just depends on whats going on .... i know my company only charges 65.00 to come out and tell you whats wrong...may be worth calling a appliance person could save you from buying a new one.... give me a vote ..... texas based heating /.air /and appliance repair company
Posted on Jan 03, 2011
My kenmore refridgerator does not defrost it has ice all the time.
NO DEFROSTING,,GET MULTIMETER ,LOOK IN THE FREEZER COMPARTMENT REMOVE THE EVAPORATOR COVER THEN CHECK IF HEATER TERMINAL ARE PROPERLY CONECTED ,CHECK IF THE B-METAL AND HEATER FOR CONTINUITY ,IF NO CONTINUIRY ON B-METAL IS BAD ..THIS 2COMPONENTS ARE OK,PROBABLY YOU HAVE A BED MECHANICAL TIMER OR DEFROST ADAPTER BOARD. A REFRIGERATOR DOES 2DEFROST CYCLES IN 12HRS SYSTEM STOP FOR ABOUT 30MIN IF YOU REFIRG NEVER STOP YOU HAVE A TIMER PROBLEM..
Feb 19, 2011 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
We also have a 10 year old Kenmore side-by side that has stopped cooling. The compressor continues to run (does not turn off after a few seconds). Worth repairing???
well to be honest its a "no, no" a 10 year old unit is not very good and is costly to run to fix it would cost half the price of a new one, and by now you must have had your money's worth out of it, so its best all round to buy a new one to fix your unit it would need a new compresser a re,gas and maybe a thermostat as well, ,,see what i saying,,,lots of money for an old unit
Jan 07, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
My refirg wont get cood and the freezer isn't freezing the lights are on and i can hear it running but my contents in there is meltingwhats the problem
It sounds like the circulating fan is either wearing out or has worn out. This fan supplies circulation for the freezer as well as the refrigerator. When it doesn't work there is no circulation of air to cool the refrigerator nor freeze the freezer compartment. The minimum cost to repair/replace the unit cost around $300.00
Jul 11, 2009 | Refrigerators
Kenmore refrigerator not working
Hi!!! Go to the back of the frig and see if the compressor and condensor fan motor are working.If not then you have a bad current relay.easy fix.its located in the compressor where the wires go into..Good luck.Heres a picture of your current relay..
Jan 04, 2009 | Kenmore 57029 Side by Side Refrigerator
Kenmore Side by Side defrost Issue
well tia i need the model number so i can guide more to wich part is failing but if you want repl the timer and defrost thersmotat you can repl all parts under 200 dollars versus 1500 for a new refrigerator is worth fixing it
Oct 06, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Make sure the coils underneath and backside don't have large amounts of dirt on them. Check door seals with a dollar bill, go around the entire door. close the bill inbetween the seals and tug on the bill, if it pulls out to easy the door needs adjusting or seals need replaced. let us know what you found thanks
Dec 08, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
