Question about Miele S514 Solaris Electro Plus Vacuum
Hi a curve piece of wire or metal fell out of the handle when taking it apart.Can`t figure out where it goes?
If it is about 2" long , it is the snap ring almost right at the end in the narrowest part which keeps the extension tube in place .
If it is about 7" long , It is the antistatic strip which sandwiches between the 2 halves of the handle underneath.
Hope this helps.
Posted on Jan 09, 2011
I took apart my Eureka 71B hand held vacuum and a small spring fell out. I don't know where it goes and can't find a manual anywhere. Help?
Lonny,
I have a 71-B2 model myself and if you can take a picture of the spring, I can try to take mine apart and see if I can figure out where your spring goes and get back with you.
Aug 09, 2015 | Eureka 71B Easy Clean Hand Vacuum Yellow
I removed the bottom medal plate, covering the brush, and there were 3 additional pieces that fell out - 2 clear and 1 darker gray (aprox 2" H and 1.5" W). I can not figure out where this last piece goes...
I've never seen a Dyson with a "medal". For that matter, I've never seen a Dyson with any metal parts either, except the screws.
You should take it to a qualified vacuum repair shop to make sure the parts aren't necessary before running it again, just in case.
Oct 16, 2013 | Dyson DC15 Animal Bagless Upright Cyclonic...
Where does the static wire go in the handle. It fell out and now I am having trouble getting it back in. I fixed the cord myself. Model XL2100rh
If you look closely, you can see a sahllow groove along the inside top of the handle. The curved portion of the static wire fits in that. One end fits in a hole just below the switch, the other end just goes down inside the metal post.
Dec 31, 2010 | Oreck XL Ultra Bagged Upright Vacuum
I need help removing a cat toy from the handle that connects to the hose on my vacuum? The ball seems to be stuck in the curve or just below the curve before it enters the hose.
The handle needs to be removed to do this. Taking the handle apart and especially putting it back together can be tricky, so I recommend taking it in to an authorized Aerus Electrolux store to have the item removed. If you don't put it back together properly, it could result in an electric shock, and even a fire. I have seen a totally melted hose from someone trying to dig out an object, then the hose wiring shorts out and lights up.
I dislike having a disassembled machine or part brought in to be reassembled, and finding a broken tab that requires replacing the handle or part that's brought in.
Be safe, please take it to the shop.
http://www.aerushome.com/storelocator/
Dec 17, 2010 | Electrolux Lux 5500 Canister Vacuum
Water won't come out when you press handle to shampoo carpet.
I Had the same problem with my model 79011...take the upright handle apart & you will see a pot-metal rectangular box midway down the lower section of the handle with wires on it & 2 hoses attached. This is the water heater unit. LET IT COOL IF YOU JUST HAD THE UNIT ON AS IT WILL BE HOT!!! Take the hoses off & carefully **** the inlets out ( do NOT probe more than about an inch in) with a piece of coathanger wire. Flush heater unit out by hooking a peice of hose up to the heater unit & blow into it to flush the loosened crud out. Hook it all back up & it should work like new! What happens, is the alkalis in the cleaning solutions react with the pot-metal & cause corrosion to build up, eventually clogging the unit, thus not allowing waterflow thru it. Built to fail just like all modern junk! ;) Hope this helps! Ross
Sep 07, 2010 | Bissell 7901-1 ProHeat Scotchgard Upright...
TechDrive power assist fell off
See if THIS helps.
Not sure how far you went disassembling the unit so here are a few more useful articles that you may want to see:
How to connect wires
How to get the transmission installed.
Rocky
May 30, 2009 | Kirby G5 Bagged Upright Vacuum
Formed metal wire inside handle
this bent metal wire goes right at the surface in a grove where the two pieces of the handle go together where your fingers grip it. I think it is to discharge static electricity.
Mar 27, 2009 | Oreck XL Ultra Bagged Upright Vacuum
I need to reassemble my rainbow e series electrified hose handle
Yes, it is a ground wire. When you put it back together, make sure that the two halves of the hose handle are holding the wire up against the metal. I just had one apart the other day for the first time and if I recall correctly, the wire goes near the center for reassembly. Hope this helps!
Mar 15, 2009 | Rainbow E series Canister Wet/Dry Vacuum
Eureka 411B Upright Vacuum
It goes in a slot beside the right wheel. It is a detent for the hinge. Metal spring first and then the nylon piece round edge up.
Nov 14, 2008 | Eureka 411A Upright Vacuum
Miele S514 Solaris Electro Plus Vacuum Logo
216 people viewed this question
Top Miele Vacuums Experts
Mack Baxter
Colin Stickland
Colin Stickland
Are you a Miele Vacuum Expert? Answer questions, earn points and help others
