Question about Intel Gigabyte 8I845GVM-RZ 82845GV GMCH chipset 533MHz FSB DDR333 Socket 478 mATX Motherboard with L... (MB47GB5GVMRZ)
No display cpu not accecpt but v core voltages is ok.
    President:
  • 2,351 Answers
Remove the CPU from the motherboard. (A pain in the rump).
Double check the CPU pins. (Many) Make sure they are not bent or missing pins. (If any are broken than the CPU is finished, it can not be fixed. Replace the CPU). If ok, reseat CPU & make sure CPU slides gently into the socket. (If you have to push it in the socket, than it is not lined up correctly). You can see how to install a CPU by opening this link. (Though this CPU may not be the CPU as your's this is how to install one).
http://www.pcguide.com/byop/byop_OpeningandExaminingtheCPUSocket.htm
Click the blue arrow to go to the next page & so on.
If this has helped, great! If not please explain what I am missing so I can help you find the correct method/answer to fix this.
Luck!
Mike
Posted on Jul 09, 2008
After i change the processor dual core 1.80ghz on the IBM thinkcentre M 55e 9632 series the monitor only showing, cpu=1processors detected,cores per processors=2 intel pentium dual cpu 2160 1.80ghz 1527...
HI,
I am sharing some general info:-
If you are change processor no problem, some point see you like after change processor any beep sound, processor more hitting.
Second check it *********** board power come or not, your display cheap more hitting or not. Check RAM proper connect, your all cable proper connection. If all things ok then may be your PC not supported processor.
Thanks..
Oct 14, 2013 | Lenovo ThinkCentre M55e 9632 PC Desktop
Show all solution to d945plrn motherboard problem not powering up
PSU IS OK? You're sure? You tested the 3 main voltages coming out?
DON'T rely on; "The LED lights are on, and the fans spin, so therefore the PSU must be good.
1) If ALL the LED lights were on at once, they would use less than 1 Watt of power.
2) EACH fan uses 2 to 3 Watts of power.
3) A typical Processor uses 51 to 125 Watts of power.
With a Power Supply that has a weak voltage power rail, you will see LED's light, and fans spin; BUT not enough power to turn the Processor on.
Power Supply also needs to be plugged into motherboard to test, because you need a Load on the Power Supply.
PSU is KNOWN to be good? I mean KNOWN.
Not, "It's brand new so I know it has to be good"
Okay, moving on.
CPU OK?
How did you test it? Install on another working motherboard?
Are the Electrolytic Capacitors on the motherboard good?
http://capacitorlab.com/visible-failures/index.htm
http://www.youtube.com/watch?v=Lut7MX5Dd_A
Capacitors on the motherboard are used as Filters, and Voltage Regulators.
The ones used as Voltage Regulators are in the Motherboard Voltage Regulator Circuit,
http://www.hardwaresecrets.com/article/616
Part of what the Motherboard Voltage Regulator Circuit does, is to regulate voltage for the Processor. (CPU)
The CPU MUST have a steady, 'clean', supply of voltage, and it MUST be kept within the Processor's voltage tolerance range.
Too much, or too little, and the CPU shuts off. BIOS turns it off.
(CPU stands for Central Processing Unit. Another term used is Microprocessor, or simply Processor for short.
I know you are aware, just posting for all those who read the solution in the future)
http://downloadmirror.intel.com/15140/eng/D945PLRN_ProductGuide02_English.pdf
[Better motherboard due to the Intel Q965 motherboard chipset,
http://www.ebay.com/itm/INTEL-DQ965GF-CORE-2-DUO-LGA775-SOCKET-P-4-MOTHERBOARD-I-O-FACEPLATE-INCLUDED-/290863623024?_trksid=p2047675.m1850&_trkparms=aid%3D222002%26algo%3DSIC.FIT%26ao%3D1%26asc%3D11%26meid%3D5685984037376928917%26pid%3D100011%26prg%3D1005%26rk%3D1%26sd%3D330632928551%26
http://en.wikipedia.org/wiki/List_of_intel_chipsets#Core_2_chipsets
Scroll down to Q965 in left column ]
For additional questions please post in a Comment.
Regards,
joecoolvette
Feb 18, 2013 | Intel D945PLRN Motherboard
Cpu fan moves & stop No Display
First you disconnect the ATX 4 pin connector (12v, two yellow and two black wire ) from the motherboard and try. If the motherboard is switching on the problem is related to your motherboard cpu core voltage section.
Nov 25, 2010 | Intel 845GE Motherboard
No display but power on ram ok cmos battery ok cpu fan and cpu ok
first check ur display cable for breakr if you have built in display disable it in bios and and if you have addon display card remove them insrert a new addon diplay card if you have display the display section in you motherboard is faulty or diplay add on card is faulty if it still dont work the clock and reset section in your motherboard is fulty to find the at the above section if you have a multimeter check the pci slot A15 means the pci pins facing the processor must have 5v if this is ok your motherboard is ok and the problem is with your display card
Oct 07, 2010 | Intel D845GVSR Motherboard
New CPU, No display
in my view, ur motherboard doesn't support the new processor, so plz check the capability of your motherboard, and replace with the supported cPU. ok byee
May 16, 2009 | Intel Core 2 Quad Q9550 2.83GHz Processor
HP dv5 heating up
if hp dont have solution for that my advice is buy a laptop cooler or call HP to replace your computer, i was looking for the reviews and there are no negative reviews and hardware heating
Mar 20, 2009 | HP Pavilion dv5-1140us Notebook PC
No display on IBM motherboard
replace your ram as wwell as cmos battery
Mar 13, 2009 | Computers & Internet
Your solution re motherboard
"voltage regulator module" thats have next to core voltage connector it's supply to cpu
cpu need 2 volt 45 amp and our power supply can produce voltage 12 volt 3 amp so motherboard can produce more amp for cpu . 6 mosfet using for this process it's near by cpu
Apr 11, 2008 | Intel Motherboard
Computers & Internet Logo
89 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
