Question about Fahrenheat Ceiling-Mount Industrial Heater - 7500 Watt
Hello I have a Fahrenheat Ceiling-Mount Industrial Heater 240v rated. Can I use a 220 plug to wire it and connect it to my 220 aux plug in my garage? If so how should I wire it to the heater itself?
  • 1,772 Answers
Sorry to read about your problem, I hope this helps you out.
you will have to install a 30 amp breaker, and make sure the wire is rated for 40 amps, or 110% of 30 amps, you can wire direct to the heater if you wish.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Posted on Jan 03, 2011
Where can i buy a thermostat for my heater fhu5-4b part # 5813-2050-000 Thanks Tom
Northern Tool sells ceiling mount Fahrenheat Heaters Try them, they may have it as an accessory or optional item.
Feb 09, 2011 | Fahrenheat Ceiling-Mount Industrial Heater...
Installed my second Fahrenheat FUH 724 7500W heater in another garage. Installed same as previous heater that works perfectly. used 10 Gage wire and 40A 240V breaker (2-20A). Wiring is correct. Heater...
Could be either. But, I suspect that wiring is getting hot enough to trip the breaker. Check all of your wiring to see if there is a hot spot or insulation melted.
Feb 05, 2011 | Fahrenheat Ceiling-Mount Industrial Heater...
Just installed heater, turned it on and nothing happened. checked voltage and had 118/119 at l1 and l2 inside heater. removed heater and disassembled, checked wiring against schematics in manual and was...
Im.sure there is safeties on access panels. Put it back together and try again. Be sure you have removed all packing material!! Your element should begin glowing in seconds.
Aug 14, 2017 | Fahrenheat Ceiling-Mount Industrial Heater...
Looking for bimetalic thermostat switch for the 5000 watt Fahrenheat ceiling mount heater. do you have a parts source?
My place of choice when purchasing for the warehouse is Grainger, if you have one close by. They usually have these items in stock or will get them for you quickly. Give them a try.
Dec 22, 2010 | Fahrenheat Ceiling-Mount Industrial Heater...
Need instructions on how to install a 750W Fahrenheat heater. Wire size, breaker size, etc.
To know what to tell you you need to know if it is 1 phase or 3 phase and what the voltage is that it will be running on...
Assuming that it is 240v 1 phase current you will need at least a 40 amp 2 pole breaker and #8 wire for a distance of upto about 100 ft. if longer then you need to go up to #6 wire....
7500 watts / 240v equals 31.25 amps... so a thirty to too small and you will need the 40....
Wire sizing needs to go larger as the run gets longer...
heatman101
Dec 13, 2010 | Fahrenheat Ceiling-Mount Industrial Heater...
I have a 724 heater7500 w 28x32x10 garage with dog door it will only keep garage at 40 degree not 50 like i want in minnesota what are my options
The heater is too small for the space you are heating....
You need to get a second heater or get a bigger heater to get more heat...
Heatman101
Nov 30, 2010 | Fahrenheat Ceiling-Mount Industrial Heater...
I'm replacing a non-hydronic electric baseboard heating unit with a Fahrenheat hydronic one. My old unit was 240v using 2 conductors plus bare ground wire. The fahrenheat (PLF series) unit's instructions...
Hello. The red and the black are the hot wires. Therefore, connect one of your conductors to the red and the other conductor to the black. Use wirenuts. The bare ground wire should be solidly attached to the new unit's green wire using a wire nut.
Regards, Joe
PS: please rate my answer. Thank you.
Jan 06, 2010 | Fahrenheat Electric Hydronic Baseboard...
I have the Fahrenheat Model FUH 724 heater. The manual states that it can be wired as a 240v 7500W unit but the directions and the unit itself only allow for three wires to be connected Black, White, and...
1st you will belucky if you actually have 240 v, most
homes are usually 220v. In youyr case you need to start at the breaker panel.
This is an example:
You have a Double Pole Single Throw breaker. Black
Wire is hot and goes into one side of breaker,if you havea red wire that goes into the other have of the
breaker.
The white wire ties in the nuetral bar and the bare wire into the ground bus bar. At the unit you hook up the red and the black wire which will supply the 240
Volts, you could tie the white and the ground wires together into the grounding terminal
Jan 01, 2010 | Fahrenheat Ceiling-Mount Industrial Heater...
I have a 3 car garage in Minnesota all insulated attached to house. What size and type of heater do I need. I also have 4 dogs that go in and out constantly. its about 840 SQ FT
Generally they say about 10 per SQ/Ft so in reallity you would need 8400 watts. You would then have to consider your ceiling height. If it is a 10 ft. ceiling and the fact that your dogs are going in and out you may need even more.
Oct 14, 2009 | Fahrenheat Ceiling-Mount Industrial Heater...
Electric space heater contactor won't stay latched
Jumpered the bimetal thermostat and everything worked smoothly. Tried to clean contacts in thermostat with no luck, so ordered a replacement. At least it was cheaper than the contactor.
Dec 07, 2008 | Fahrenheat Ceiling-Mount Industrial Heater...
Fahrenheat Ceiling-Mount Industrial Heater - 7500 Watt Logo
444 people viewed this question
Top Fahrenheat Heating & Cooling Experts
butch welch
paulcarew
Are you a Fahrenheat Heating and Cooling Expert? Answer questions, earn points and help others
