Question about Nokia 6030 Cellular Phone
Backlight does not come on
When I power up my phone the backlight does not come on, you can see what's on the screen, but the screen is dark. What can be the problem? I've tried the brightness, the contrast setting and nothing. Please help me resolve this problem
  • Anonymous Jul 16, 2008
    I have same proble. My display is disappering for some time with blanks screen.
Chek display conector pin resolder with mini iron, chenge display too.
Posted on Jul 13, 2008
Sanyo DP46142 TV comes on for approximately 30 seconds and then screen goes black. Power LED stays on.
Sounds like a backlight problem to me. If you input a signal to the HDMI or Composite input and then it goes black have you tried taking a flashlight to the screen to see if the picture is still there but just dark? That would indicate a backlight issue. That model appears to be an LED edge lit backlight, so if the picture is still there after going black your going to have to trace out the backlight circuit and see whats going on. Usually with LED backlighting if it comes on at all then the LED's are good, its just the driver supply thats failing to keep them on. Some TV's have a small separate board that provides the backlight control, but i suspect with this model its on the power supply board and not the motherboard. Have you checked that board? It could be bad caps on the power supply board, check the voltages to the backlighting when it lights up and then when it goes dark. It could just be some failed capacitors on the power supply causing that voltage rail to drop off.
May 04, 2017 | Sanyo Televison & Video
TV turns on, but the screen is very dark, almost completely black.
It sounds like your backlight is out or barely functioning. Try replacing the inverter board(s). Since you can see a picture, the T-Con board is probably okay.
Apr 20, 2017 | Polaroid 2611-TLXB TV
Dark Screen even when i adjust the 'brightness' tab?
check the power settings on te unit, if it is set to default for the backlight, possible that your LCD's backlight is not powering up properly on the unit or LCD's backlight needs replacement.
Jun 03, 2010 | Apple iPod touch
My dell inspiron 1520 has dark screen
If you replaced the backlight and you still have the same problem then the next step you should take is to replace the inverter.
That should solve your problem, if it doesn't let us know.
Mar 04, 2009 | Computers & Internet
Screen goes black after 30 seconds
Yes, this is a backlight problem. However, it could be either the light itself or the inverter that powers the backlight when it fails like this. I'd recommend replacing the entire screen plus housing and hinges (it is often sold as a complete unit) or just replace the inverter (often relatively cheap) and then if that doesn't fix it replace the screen (the backlight is non-replaceably attached to the screen).
The other option is to simply attach it to an external monitor and use it like that. This is also a free way (well, as long as you know someone that has a monitor) to make absolutely sure that the problem is the screen and not anything else.
Jan 19, 2009 | Dell Inspiron 8500 Notebook
The screen is dark on my e71; the back light is off
It seems you have a backlight failure. If you can still see the screen on the device (as far as texts and pictures), you would simply need to replace the screen in the device.
Dec 22, 2008 | Nokia E71 Smartphone
LG Shine screen display
replaced the LCDS on the phone
Aug 19, 2008 | LG KG800 Cellular Phone
Dark screen
if the picture is REALLY dark, like you can just barely see it in a lit room, then the backlight might not be lit. LCD TVshave backlight that shines through the LCD screen which allows you to see the picture.
If it's not the backlight then it would be the brightness/contrast settings that need to be adjusted. If the picture used to be normal and all of a sudden went dark, verify the backlight. Normally you can look through the slots on the top of the set and determine if the backlight is on. If you can see a bright light through any of the slots, the backlight is probably OK... go after the brightness/contrast settings.
Mar 25, 2008 | Vizio L37 Television
Nokia 6030 Cellular Phone Logo
90 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
