Question about Sony KDS-60A2000 60" HDTV
Our Sony TV Model KDS60A2000 screen is black with only Video 4 on screen, has green lite showing the TV is on, however, does not have picture. Could it be the lamp?
    New Friend:
  • 90 Answers
It could be but if it is the lamp you wont be able to see anything on the screen, the screen would be black. You sould check the lamp if it looks old and burned out you may want to replace it. If you do replace it make sure not to touch the glass lens on the new lamp.
Posted on Jan 03, 2011
Sony Bravia flat screen TV when turned on has black screen. Green light on the bottom is lite up, electric plug is plugged into house socket, no picture only black screen.
If audio is OK, the fault is with its backlight section. If audio too is absent, the fault is with its digital main board. If you wish to get more details visit the site linked here. Pull up older posts.
http://homenol.blogspot.com/
Jan 08, 2017 | Sony Televison & Video
LG TV 60PZ550 black screen no pic or sound green lit flashing it has back lite
LG 60PZ550 Plasma - No Sound, No Picture - Badcaps Forums ...
www.badcaps.net > ... > Troubleshooting TVs and Video Sources
Sep 15, 2013 - 20 posts - ‎4 authors
LG 60PZ550 Plasma - No Sound, No Picture Troubleshooting TVs and Video Sources. ... I see no change in the screen at any point (no glow). With the rear cover ... I've worked with some electronics in the past, but am new to TV's. I'm sure .... Multimeter on DC 1000V, red on (+) marked, black on (-) marked. Lg 3d plasma 60pz550 i've got sound but no picture
Jul 18, 2014
LG 60PZ550 color issue - Badcaps Forums
Jun 9, 2014
Purple/Pink Lines / Postering on plasma LG 60PZ550
May 29, 2014
LG Plasma 60pz550 has strange greenish rainbow ...
Jan 20, 2014
More results from www.badcaps.net
Jan 10, 2016 | LG 60PZ550 3D Plasma TV
We have sound but no picture
LCD Easy Fix (sound but no picture) - YouTube
? 4:52
https://www.youtube.com/watch?v=IBRE1Dcyxp4
Jan 13, 2012 - Uploaded by Clay Whitehead
TV Has Sound But No Picture Troubleshooting Guide - Duration: 2:30. by Repair.com 467,264 views. 2:30. LCD & LED TV Repair - No Image ...
How to fix sony bravia has black screen - Digital TV - Streaming ...
www.tomsguide.com/forum/56867-4-sony-bravia-black-screen
Aug 19, 2014 - 12 posts - ‎11 authors
Hello, My Sony Bravia TV screen has gone all black. The green on/off light comes on,but no picture appears. The model ... Your solution solved the non picture for live tvbut still no picture (just sound) fir OnDemand. Score. 0. No picture on LCD TV with HDMI cable plugged into ...
Aug 4, 2014
Tv problems picture ok but no sound - HDTV
Sep 8, 2011
More results from www.tomsguide.com
Dec 14, 2015 | Sony BRAVIA KDL-55XBR8 55 in. HDTV LCD TV
I have a Sony WEGA, Model #KDS60A2000. The screen has a green tint to it & also states that the rear projection lamp is nearing end of life. After research & reviewing class action lawsuits, replacing...
YOU WILL NEED TO REPLACE THE OPTICAL BLOCK; I don't think you're going to get much help from Sony at this time. The cost to make the repairs are not cost effective on a unit of this age.
Go shopping for LED or LCD TV
Jul 22, 2014 | Televison & Video
My sony KDS60A2000 has a continuous problem of the picture coming on then after about 5 min the screen goes black with the sound intact, then comes back on, this cycle is constant... sony says I have a...
REPLACE THE LAMP THE ON/OFF CYCLE IS MOST LIKELY THE LAMP. FOR THE BLUE I SUGGEST CHECKING ALL THE CONNECTIONS FOR VIDEO YOU HAVE HOOKED UP IN THE BACK. OTHERWISE THAT MODEL HAD PROBLEMS WITH YELLOW/GREEN VIDEO DISTORTIONS REGARDING THE OPTICAL ENGINE NOT REALLY ANY BLUE.
Dec 16, 2010 | Sony KDS-60A2000 60" HDTV
I have a Sony, 54" Projection Screen HDTV that I bought in 2002. I believe it is a 1080i. When I am waatching TV, I notice that when the screen is mostly black, for instance a night scene, the black areas...
Confirm the actual model number as the one indicated in the title is not HD.
Some of these sets had bad picture tubes that on a black screen or blank video input may in your case show faint curved lines and or some color (red,green or blue) present in the background.
If this is the case there is a fairly simple way to attempt to adjust something for this--not in the customer menu but fairly easy to get at and try.
Most of these sets were KP51ws500, 57500 etc.
SD TECH
May 11, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
KP-57WS520 Sony Projector - No picture
5 times blinks shows incorrect white balance (AKB) error. TV needs Screen Volts (G2) adjustment.
Take off lower front panel, find Focus Block that has 6 control knobs, adjust Screen volts of each CRT (red-green-blue) and problem will be solved.
Be Careful while working in TV.
Let me know if you have further question.
Thanks.
Dec 09, 2009 | Sony KP-57WS520 57" Rear Projection...
Color lines out of focus
dc2eb76.jpg MikeNJ1964
Rank:guru_s.gif Guru sony.gifSony Expert
Rating: 89%, 674 votes
You have a completely different problem. The screen voltage for the blue picture tube is slightly too high on your set. This will put fine lines in the background of the picture, called retrace lines. This is very common and easy to correct. Remove the front speaker cover and the access panel behind it. Look inside and you will see a black box with six controls, each control having a little white glue on it. This is the Focus/Screen block. Three controls are labeled Focus and three are labeled Screen. The screen control in the center is for green but I am not sure if the screen control on the left or right is for blue for your model. With the TV on, set it to VIDEO 1 but do not connect anything to the VIDEO 1 jacks. This will produce a pure dark picture, showing any faint lines in the background. Choose one of the screen controls and increase (turn clockwise) it slightly. If the blue lines do not get brighter it means you are turning the red screen control, so put it back where it was and choose the other screen control. When you find the blue screen control, decrease (turn counter-clockwise) it until just when the blue lines are gone. If you want you can check that the red and green screen controls are set to just below the point where their faint lines are visible. When done, replace the panels and your picture will be back to perfect.
Did you think this was helpful? Yes No
new MessageRate('spn1737581','spn1737581cnt','spn1737581stats','spnRateWord1737581','div1737581_yes','div1737581_no','imgStar1737581','ancChangeRating1737581','divChange1737581',1737581,0,0,0,false); Solution #2 posted on Jul 04, 2008 Asker's Rating 0%20stars_w.png
noavatar_s.gif gator149
Rank:nonexpert_s.gif Apprentice sony.gifSony Expert
Rating: 0%, 0 votes
MikeNJ1964 was exactly right! I have a Sony KP-65WV600 that had horizontal green lines that showed when the picture was darker. I had to remove 3 screws on the right and left side of the tv holding in the speakers...carefully pop out the middle panel from the clips holding it in....remove 4 screws from the cardboard in the middle and remove the cardboard. I then saw the six screws. The adjustment screws were the three below. I turned the middle screw until the lines dissapeared. I tried the left screw and blue lines appeared which I then adjusted away.
THANKS a bunch. SAVED me money!!!
May 15, 2009 | Sony KP-65WV600 65" Rear Projection...
Sony 46"wide screen projection tv made 2005,getting green shadows around images--alot of GREEN--have to darken picture to get better picture--stand-by lite blinks 5 times every 5 seconds????please...
This should be a relatively straightforward repair, but without the model number, I can't provide the details. Can you please update this with the model number?
Thanks,
Dan
Sep 24, 2008 | Televison & Video
Sony 46in tv screen problems?
You do have a vertical sweep circuit problem.
Aug 15, 2017 | Sony KP-48S75 48" Rear Projection...
Sony KDS-60A2000 60" HDTV Logo
130 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
