Question about Jenn-Air Kitchen Ranges
I have the Jenn-Air microwave JMV8208 and I am replacing the light bulb every 2 weeks. Can you tell me what is wrong? I've had the unit for over 5 years and the bulbs in the past have lasted several months.
  • 26 Answers
Are these Halogen bulbs? If so, wear rubber gloves when you handle the new bulb. The oils from your skin shorten the life of Halogen bulbs. If you do accidentally touch a Halogen bulb, be sure and wipe it with alcohol and a cotton swab before installing, or just after you have installed bulb. Do not scrape or touch anything hard with the glass of the bulb. Please rate if this helps, or if it does not. Good luck!
Posted on Jan 03, 2011
How to change light bulb in microwave?
Found this post on another fixya-type site: below is the link..
Here's a repeat of Kai's instructions so you don't have to scroll down. I just replaced mine and it was a snap. Just a few Phillips screws and a few tugs. No need to pull the unit completely out as you can access the bulb after it's about half way. No need to disconnect any wiring harness except pulling the bulb out of its socket. I used the 10w (G4 12V) replacement bulb from Home Depot at $6. The light is a bit brighter but there've been no problems with fuses.
1) Turn off power to the unit
2) Open the lower oven door
3) Remove the side trim screws and pull the trims down and out.
4) Remove 2 screws on the sides of the control panel.
5) Open the Microwave door. Remove the 3 screws on the Air Vent Plastic Cover on top of the microwave. You can then remove the Air Vent Cover by pushing the control panel up and pull out slightly at the bottom.
6) Remove the 4 screws on the Air Vent Plastic Cover on top of the lower oven and remove the Air Vent Cover. (You may have to remove the left under side bracket of the Microwave door temporarily just for the Air Vent Cover to clear the screw of the bracket. Re-secure the side bracket of the Microwave door panel as the front panel may fall)
7) Remove the 2 screws which held the Microwave unit in place behind the Air Vent Cover on step 6.
8) Wiggle the Microwave unit out about half way to expose the light bulb unit on top center
9) Wiring to the Control Panel will prevent you from pulling the Microwave unit out any further. And you don't want to do that as the unit may fall. Space is cramped, but working carefully with pliers you should be able to release the springs which held down the light bulb unit and change the bulb.
http://www.fixed4free.com/answers.php?id=51232
Mar 21, 2012 | KitchenAid Architect Series KEMC308KSS...
Tip
How do I replace light bulb on my Jenn-Air microwave?
Hi.
You will need to partly disassemble the oven by removing the outer cover held by screws (the cover part 2 on the first diagram). once there you will see the bulb hand side, located on the right (the bulb is part 6 in second diagram).
Before disassemblying the appliance disconnect power, by tripping circuit breaker or unplugging the power cord.
Here the replacement part for the model JMC9158AAS, listed in title: PS391758 .
Diagrams below are also for Jenn-Air JMC9158AAS.
If you have a different model, use the links listed here: Where do I find parts and diagrams for my appliance?
Here the diagrams. Click on the pictures to enlarge.
Diagram 1:
Diagram 2:
Unless you are a technician or a trained DIYer, better ringing the number listed on the owners manual to call service support. A badly assembled microwave will be dangerous for your health. The capacitor inside the microwave can also release dangerous discharge, take care and observe safety prescriptions while disassembling.
Regards.
on Apr 08, 2010 | Jenn-Air JMC9158AAS Convection/Microwave...
We have a Jenn Air Microwave Over our built in oven. The light is burned out. How do we replace it? it is a jmc 7010ADB. Thank you Jan G
Mine is JMV8166BAS over-the-range model, and yours may be similar. Disconnect electric source (pull plug, or turn off circuit breaker).
1. Locate and remove 2 Phillips head screws on top projecting from cabinet/wall,etc,
2. Carefully & slowly, slide entire front vent 1/4" towards your left simultaneously pulling toward you.
3. Remove vent filter, if any.
4. In very center maybe beneath filter space, locate approx.4" width aluminum colored metal cover, possibly held in place with Phillips head screw.
5. Remove screw, exposing small light bulb.
6. Gently pull back on bulb, replace with identical wattage, 120V bulb from big box or appliance store.
7. Human touch may shorten life of bulb, so carefully push wire prongs into plastic bulb inlet socket using whatever allows you to grip bulb in the limited space.
8. Reverse 5 - 1 for reassembly. Before replacing vent assembly, notice the small notched angle clips on the bottom before aligning to microwave unit, as these were slightly tricky on my unit when inserting & sliding assembly 1/4" toright.
Jun 30, 2010 | Microwave Ovens
Cooling Fan stays on until the door is open
May be a sensor or thermostat for the fan thats faulty therefore it runs all the time.
Sep 16, 2009 | Jenn-Air JMV8000 Microwave Oven
JMV8208 BAW Model 30" Jenn-Air Convection/Micro combo
have a good look at front to see reset??.press it once it comes back on unplug from the wall and & open it up and go to the part and give it a good clean with wd40, check the push pad for ware & tare dirt gathers and builds up
Mar 09, 2009 | Jenn-Air JMV8208A Microwave Oven
Broken light bulb
Go to an appliance parts store to get the bulb.
Good Luck and Please rate fixya!
Feb 23, 2009 | Jenn-Air JMV8208A Microwave Oven
Jenn-air microwave light bulb
This is an older (Mfgr. May, 1987) microwave oven. Functions perfectly, works an looks good to this day, just no light inside. I searched a couple of websites looking for parts for this unit and appliancepartspros.com provided schematics of the product that I own. From those drawings, it was determined that the microwave oven will have to be slid out of the cabinet above the built-in oven in order to change a $2.37, 40W light bulb. Just a handfull of scrws retaining the oven and exhaust baffles and I'll get it out (onmce the New Year's Eve hangover disappears). The engineer who designed a system like this must have been on an Acid Trip. I haven't looked closely at newer microwave ovens, but I'd have to believe changing a crummy light bulb would have to be made easier than this during the preliminary engineering phase of design.
Dec 31, 2008 | Ovens
JENN Air bulb replacement problems
We see (and repair) this a lot. The problem is indeed on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week.
At our site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa.
Feel free to contact me directly (and please remind me of your model number) for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Nov 08, 2008 | GE JVM1850 1000 Watts Microwave Oven
Jennair Microwave Model JMV8208AA/AC
I am in need of a Jenn-Air JMC7000ADB (black) microwave, so if anyone gets tired of trying to solve the problem, I will buy your microwave from you.
Call Mike at 317-557-5352 or e-mail mslshihan@aol.com
Thank you.
Sep 30, 2008 | Jenn-Air JMC7000 Microwave Oven
Kitchen Ranges Logo
122 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Mike Carew
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
