Question about Whirlpool GS563LXS Kitchen Range
This range has worked fine for over 3 years. We use the oven a lot, the broiler not often. Last evening after using the stove for several things, then the broiler very briefly, both of them stopped working. The "Preheat" display comes on, then you hear the loud click (which I assume is an electronic valve), then instead of hearing the burners ignite, you get another loud click, no ignition. The stovetop burners all work. -------------------------------------------------------------------------------- Following up on my own question here, I found a document online titled Whirlpool Gas Range Direct Spark Ignition System, which applies to this range. I got a multimeter, followed the directions in the document. Seemingly this procedure indicated this Spark Ignition Module, which controls both the broiler igniter and the bake (oven) igniter, was bad. Then, just to be thorough, I tested the double solenoid which is part of the electronic Gas Distribution Valve which runs gas to the bake burners and the broil burners. The broil terminal was dead. This manual says if one is dead, neither will operate. The solenoid is tested when it is disconnected from the oven. The solenoid IS connected when you test the spark ignition system. So, my tester showed two problems, and for either one, the manual says replace it. But, it's hard to believe both parts went bad at the same timel So, I hope the gas distribution valve solenoid is the whole problem. Anyway, I going to replace that first, and see what happens. Does that make sense?
  • 146 Answers
Your probably right. The oven sensor, or what you call a probe, when open will not light the oven. Take it out and check for 1 to 1.5K ohms. at room temp. if you don't have that replace the sensor.
Posted on Dec 21, 2007
  • 96 Answers
SOURCE: Kenmore Propane Range won't bake
The glow plug underneath the over floor need to be replaced
Posted on Dec 19, 2008
SOURCE: whirlpool super capacity 465 gas range model# sf377pegq5
I have the same problem intermittently on my Super Cap 465. After reading the following quote from another site, "There have been cases where radio waves, electronic signals and sometimes something as strange as dimmers in lights have caused some weird problems with some computer panels in stoves like these", I tried turning off lights that might be on the same circuit and wouldn't you know it, the oven igniter circuit worked.
Posted on Jan 04, 2009
  • 1531 Answers
SOURCE: Igniter in oven will try to ignite. Hear gas flow.
the ignitor may be faulty and not pulling enough power to keep the as valve open in order to light them oven, even though it is getting red or glowing the power is not enough.try and replace the ignitor
Posted on Jan 24, 2010
  • 1531 Answers
SOURCE: Oven wont heat.
there is a chance that the electronic control has gone bad.
but you nee to check the ignitors and see if they are coming on if not check the power from the EOC to the ignitors.
Posted on Apr 10, 2010
My broil HAS NEVER WORKED. top element does not heat up even after the control panel was changed.
Search Results
    Gas Oven Broilers - Do Any Really Work? - Chowhound
    Nov 8, 2013 - but do want to say that I broil in my Breville Smart Oven and it's great.... I have never had a gas stove in any home I've ever lived in, always ...
    Kitchen Basics: How To Use Your Broiler ' The Kitchn
    Apartment Therapy's The KitchnMar 31, 2010 - Every oven that we've ever come across has some kind of broiler - it's the same device as heats your oven for baking or roasting, after all.
    I have a Kenmore electric range; model 920/9285*. The ... > Manage My Life > Questions
    The oven and broiler on my stove won't heat up. Was working ... Having a Oven not working can be rather disappointing as well quite a concern. I have taken the ...
    Top or Bottom Broiler? [Archive] - Community > ... > Food > Popular Threads Archive
    Sep 3, 2002 - 24 posts - ‎7 authors
Jan 27, 2016 | Stoves Ovens
Model ew30gs65gsc. Why is broiler not igniting?
Electrolux Oven Broiler Not Working - Model E30DF74EPS ...
Most Frequent Causes for Oven broiler not working. See All Range/Stove/Oven Parts for model E30DF74EPS. Cause 1 Temperature Control Thermostat.
Electrolux Oven Broiler Not Working - Model EW27EW65GS6
Electrolux oven broiler not working? Use our DIY troubleshooting & videos. Then, get the parts you need fast. Return any part for 365 days.
Oven Broiler Not Working - Repair Parts -
Oven broiler not working? Use our DIY troubleshooting & videos. Then, get the partsyou need fast. Return any part for 365 days.
Gas Oven/Broiler not working/igniting - ApplianceBlog
Jan 13, 2016 | Electrolux Kitchen Ranges
My gas stove isn't working properly. The range works fine, the broiler works, but the oven takes over an hour to preheat and doesn't hold the temperature. It's less than a year old. We replaced the last...
If your range is less than a year old it will be covered under the manufacturers warranty. Contact the manufacturer of your appliance to set up a service call.
Jan 30, 2015 | Kitchen Ranges
My whirlpool SF265LXTS oven turns on properly, but the oven itself isn't getting hot. The gas stove top and broiler both work fine.
It sounds like you might have a clogged burner plate or manifold. You should call a certified gas repair service. This could be very dangerous, even deadly.
Dec 15, 2013 | Whirlpool SF265LXTS Kitchen Range
We have a GE gas stove. The burners all ignite; the broiler lights up, but the oven does not heat up. Doesn't even start to heat up. Can homeowner repair this kind of problem? We don't have any money to...
If you just purchase it or it is still under warranty take it back it going to cost the same to repair. You also run the danger of creating an electrical fire.
Nov 13, 2010 | GE Spectra JGBP35 Gas Kitchen Range
Whirlpool electric oven not heating (has a functional stove top)
Hello Daniellel583! We are terribly sorry to hear of your concern with your Whirlpool Range. Please respond back to this email address with your name, reviewer name (Daniellel583), phone number, street address, zip code, model & serial number, and date of purchase on the appliance. We would be happy to assist you. We look forward to your reply.
Jun 18, 2017 | Whirlpool RF111PXS Electric Range
MGR5755QD CleanDesign Gas Kitchen Range: oven wont light. stove and broiler work fine. bad ...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
May 17, 2010 | Maytag MGR5755QD CleanDesign Gas Kitchen...
When using the oven or especialy the broiler the outside of the stove (the part where the control panel is), right above the burner gets extremey hot so hot if you would touch it you would get a severe...
There is a vent pipe for the oven in the back usually just under the left rear burner, it is normal too get hot air there, if your drip pans are all solid you might want too change too pans that have holes in the center it should allow the top too breath a little better.
Jul 30, 2008 | Maytag Kitchen Ranges
Whirlpool GS563LXS Kitchen Range Logo
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
