Question about Philips Televison & Video
My portable DVD player is saying there is no disc, but there is one in it.
  • Philips Master
  • 6,771 Answers
The Laser Pickup Assembly is malfunctioning, the only solution if it works is clean the Laser Pickup lens and allow it to dry for several minutes, use a Q-Tip with rubbing alcohol for the job.
Posted on Jan 03, 2011
Benimur
  • 6966 Answers
SOURCE: Durabrand DUR-7 portable DVD player
Most DVD players that would display such a message even with a known good disc inside signifies that the that the laser eye/lens is not reading the disc. This could probably be attributed to:
1. dirty, damaged, inverted, blank, un-finalized burned CDs or DVDs;
2. defective, weak burned-out laser eye/lens;
3. defective slider shafting (where the laser eye's carriage moves.
A few things you can try:
1. Use a CD cleaner (readily available from most computer shops);
2. use a can of compressed air and blow through the inside of the loaded disc area;
3. gently tap on the top cover where you estimate the reading/laser eye/lens would be;
4. gently press on the tray door once the disc is loaded.
Should this not be corrective, perhaps your best bet would be to seek the services of a qualified professional such as those in a Service Center. Alternately, your friendly neighborhood electronic shop should do just fine.
Hope this be of some help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kindest regards.
Posted on Feb 10, 2008
tseay11
  • 17 Answers
SOURCE: my coby portable dvd player keeps saying wrong disc
You may need to clean the laser in the unit. You can purchase a cleaning disk at Radio Shack or Best Buy. They are normally less than $20.
Posted on Nov 06, 2008
SOURCE: GPX Portable D.V.D Player : No Disc/ DIsc Error
I check the motor. for sping its good. clean the liner eye it's good also check for bad hardness connection it,s with um meter. ok what can it be
Posted on Nov 18, 2008
SOURCE: My portable dvd player won't load any dvds anymore
lachallep,
The solution for your problem will be needing a little knowledge with electronic repair and hands on.Most common problem for portable DVD player is their 1) Spindle motor the 2) flex cable ( tin ribbon wire connecting the optic lens and the main board)
note: to check if your spindle motor is working good, you must measure it's resistance and it should be around 200ohms.
For the flexcable all you have to do is check the continuity.
cheers.
mark
Posted on Jan 16, 2009
petraman7
  • 1175 Answers
SOURCE: my portable dvd player shows no disc when i put my dvd in player
Hi....
Very lightly clean the laser lens ( looks like a very small eyepiece)
with 91% or better alcohol on a swab. Then very lightly dry it off.
Also..have you tried another DVD or CD in it?
Check for dust or debris in where the laser pickup is
Posted on Feb 25, 2009
My philips portable dvd player says "wrong disc" when trying to play a dvd. whats wrong?
The lens isnt reading the disc get a lense cleaner n run it twice that should solve the problem
Apr 07, 2013 | Philips DCP851 Portable DVD Player
My daughter's portable DVD player says no disc
You need to clean the lens - use a can of compressed air and a q-tip. Rub gently, the suspension of the lens is very sensible and can be easily damaged beyond repair.
Aug 29, 2011 | Philips DCP85037 85 in Portable DVD Player
Says loading disk and then says wrong disk everytime. tried several different dvds. always the same answer!
The DVD portable player and the DVD disc came from the same countries?Ur DVD portable player and DVD disc u are using might have the wrong region DVD disc format frequencies.Like PAL frequencies only play Euroupean,Asia,Middle East,Austriala and Africa products.NTSC frequencise play only USA,Canada and Mexico DVD Disc products.
Dec 13, 2010 | Coby 7" Widescreen TFT Portable DVD Player...
My sony portable dvd player won't work. It just keeps saying that its loading. Then it say's check disk. what should I do.
Does this happen with all discs?
Are the discs clean and not scratched?
Try a DVD lens cleaning disc (not a CD lens cleaner).
You may have to try the cleaning disc more than once.
Jun 02, 2010 | Sony DVP-FX810 Portable DVD Player
Dvd player says loading then wrong disc
If it is disc made with a computer, you may need to convert the format to one that the DVD player is compatible with so it will recognize the disc contents.
Sep 22, 2009 | Coby TF-DVD7005 Portable DVD Player
PORTABLE DVD PLAYER NOT SPINNING DISCS AND SAYING NO DISC
When it is region lock it will say it on the display, if the player is not reading any disk, it is more likely a lens problem, see below:
Try first using a lens cleaner disk, like the ones here.
If that does not work, the unit must be disassembled, and lense cleaned with q tips and isopropyl alcohol or cleaning solution. See below:
How to Clean the Laser Pickup Lens on your DVD Player
How to safely clean a DVD lens?
Clean DVD lens, or replace player?
Clean CD or DVD ROM lens with a brush?
Cleaning your DVD drive
How to clean a DVD player
How do I clean my DVD player optical lens isoproponol alcohol
Feb 10, 2009 | Televison & Video
Portable DVD player .disc error unit spins but says says no disk
Likely to be a classic laser failure. It will require technical person to replace it - try starting with the point of sale and see about warranty etc
Dec 17, 2008 | Televison & Video
Televison & Video Logo
26 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
