Question about Dryers
I think my pilot light went out, but I need to know how to locate it
  • Barrett Palumbo
    Barrett Palumbo Jan 03, 2011
    Sorry to read about your issues.
    But you really need to give us the make and model, of your unit. It kinda helps us to help you. and a more detailed explanation, of whats is going on..
  • 347 Answers
Dryers do NOT use a standing pilot lite ..When the unit is turned on and heat is commanded on the gas valve opens and an igniter lite's the gas , then their is a flame sensor to see the flame from the burning gas if no flame is present it shuts the gas back off.. So if you have a no heat concern with your dryer it will be either the igniter, gas coil's or the flame sensor
Posted on Jan 03, 2011
How to light the pilot. The pilot went off when I shut the power off during the Irene storm. I cannot locate where to open so I can light the pilot. I have a GE Profile Gas Dryer, Mod.PDSR 610GG8WT
unless this is a very very old dryer,, it will have a glow plug element in it and should light without the need to light a pilot, just try starting it and see if it lights, But it would have to be ages old to need a pilot lit, I'll try and locate that model, But lemme know if it fires up will ya
Sep 11, 2011 | Dryers
I have a Goodman forced air heating system in my attic that's only about 3 years old and I believe the pilot light went out last night in a storm. My problem is that I can't locate the pilot in the unit...
Marc, look for where the gas line enters the furnace and remove the panel adjacent to it. That should gibe you access to the pilot light. Also, look for a pilot access door, near where the gas line enters the furnace. The gas line will either be 1/2" flexible copper tubing. 1/2" black iron pine or 1/2" vinyl coated flexible stainless steel. Look for the lighting instructions inside or on the side of the unit.
Hope this helps you solve the problem.
Mar 24, 2011 | Goodman Heating & Cooling
My blower on my furnace works but I have no flame for heat. If I stick a lighter in where the gas comes through it kicks in but when cycle is finished it doesn't. I think my pilot light is out and do not...
I think you have a bad thermocouple. The thing your lighting should be the pilot(otherwise you got a bigger problem and you should definitely call someone). The thermocouple senses heat so if it's bad it won't send the signal to the gas valve to open.
Feb 08, 2011 | Heating & Cooling
Pilot light wont stay onfor outside pool heater. Gas co made a service call & relit the pilot light it went out again 4 days later.
There is a thermo couple that keeps the gas on. The pilot light bracket has a small screen where the gas comes through that can get clogged and cause the pilot light to burn away from the thermo couple which would cause it to think the flame has went out and shut the gas off. Or the thermo couple has went bad itself. If you try cleaning the screen use canned air and gently blow it through the orfice once you have taken it off. If you don't know what a thermo couple is or looks like here's a picture of a generic one that will give you an idea. Usually there's a bracket that holds this in place. f1b528a.jpg
May 09, 2010 | Pool & Spa
The top burners light but the oven won't light at all. The stove is 19 years old. I tried turning the oven on and using a lighter thinking the pilot went out but it won't light.
Your oven has a pilot safety. This keeps gas from being sent to the burner(s) if the pilot is not lit. It has gone bad, they all do sooner ar later. You need to get it replaced.
Apr 05, 2010 | Kitchen Ranges
Oven does not turn on! I can smell the gas, I think the pilot flame went off, and I don't know how to turn it on!
looking at the photo / this is a pilot model / the smell of gas is the pilot light in the oven. you wll find it in the center at the back / pull the pot & PAN drawer out to light it . mm
Nov 24, 2009 | Magic Chef 31000 Gas Kitchen Range
Pilot went out and don't know how to lite it
YES YOU DO NEED MATCHES TO LIGHT THE PILOT IT IT DONT HAVE A AUTO PILOT AND IF IT DOES THEN YOU'LD HEAR IT CLICKING OR TRYING TO LIGHT IF NO CLICK THEN YES MATCHES WILL WORK TO LIGHT THE PILOT
Apr 11, 2009 | Williams 1403622 Gas Compact Heater
Hi, we have a dcs 366 gas range. the pilot light for the oven went out and we can't seem to locate the pilot to re-light. the manual doesn't really go into detail for the oven...only the stove top. is this...
You don't give the model number of your DCS range, but it probably doesn't have a pilot light.
More likely it uses and electronic igniter. Internet search on "gas oven ignitor". I think this
might help you with your problem.
Mar 15, 2009 | DCS Kitchen Ranges
Need to turn on pilot light of Williams 3003622 serial # 400518D
Find the gas valve and turn it to pilot. (Or light) Use a long reach lighter. Light the lighter and press the knob in. Light the pilot and continue to hold the knob in for about 15 seconds. When you release it, the pilot should stay lit. If it doesn't, you need a new thermocouple. That's the small tube that the flame touches when the pilot's lit. They're inexpensive and usually not too hard to replace.
Jan 30, 2009 | Williams 3003622 Ceramic Wall Mounted...
Dryers Logo
Top Dryers Experts
