Question about Belkin Computers & Internet
How do i find the network key? trying to get my niece's comp to work in my house with my modem
  • 600 Answers
The network key is in the routers set-up utility
Open INTERNET EXPLORER and. In the URL address field, enter the IP address for your wireless router ( the DEFAULT GATEWAY. This information should be contained in your router's manual. If you cannot find it, enter "198.168.1.1" as the address. This is usually the default IP address for most routers.do not type "www" just the number
Enter the username and password for your router. This should also be supplied in the router's manual. If you don't have this information, go to routerpasswords.com and find the brand and model of your router. This site lists the default login information for most wireless routers you can try "ADMIN" for user name and "PASSWORD" for passsword.
You should now be able to see your wireless router settings. You can configure your network ports, as well as SSID (wireless network name) and passwords (aka network key, wep key, passphrase).
Posted on Jan 03, 2011
My comp.says network error,thomson tg585v8,i cant access my comp.
Check your network settings
Start, control panel, networking and sharing center. Click on your connection, properties. Click on TCP/IPv4 and TCP/IPv6 and click on properties. Make sure the settings say to obtain IP address automatically and also for DNS, then reboot the modem and computer.
You did not specify if you are using a router.
Jan 29, 2013 | RCA Thomson Digital Cable Modem (DCM305R)
Everything working fine until 9pm last night, Comcast cable modem hooked up to Airport Extreme with 2Macs, 2PC's and 2X-Box360. Everything died at same time and now unable to connect to the network(which...
Try doing a Trace Route on DOS ;
Open DOS - Start > click Run > type "cmd" = DOS
DOS COMMAND
tracert www.yahoo.com
IF THE RESULT WILL SHOW A " * " or timeouts then it is something to do with your line or if the response time is very high like 100ms 200ms 300ms then it is something to do with the line indeed ( normal = 1 ms - 50ms)
Mar 06, 2010 | Apple AirPort Extreme Router
I Cannot connect to the 2wire wireless modem in the house. It just keeps telling me little or no internet connection. but every other device even the ps3 connects without a problem just not my smc adaptor.
this message, limited or no connectivity comes if ur not entering the correct key for ur wirless network
open the sms wireless utility, delete ne profiles if created, try to connect to ur house network and enter the key correctly
it will work
Nov 01, 2009 | SMC EZ Connect g SMC2862W-G 802.11g/b...
My brother has a gateway desktop he got from my niece. She got it from rentway. Model # is 0028957492. He is trying to go online but it wont let him. he gets a network error statement(he is not on a...
Sir,
You are suggested to check if the modems drivers are properly fuctional if they are then it would be that you would need to replace the modem with new one..
Oct 20, 2009 | Computers & Internet
Comp will not connect to internet and tells us there is a cable not connected. It is wireless and the modem is working with all other comps in house. I have checked the modem, switched it off and...
have you installewd the drivers for the modem ? if you have go to desktop and click settings got to network settings open this up it should show any connected networks if not click new connection then go throught the proceedure you can try the first internet connection if not try the advanced option for the wireless.. make sure you installed the wireless drivers as well a it wont work without these.. Good Luck A
Jun 30, 2009 | Advent Netbook
My internet keeps disconnecting
It sounds like the wire from your house to the isp switch is faulty you should probably call them down to fix. Or it could just be the modem are you using the same modem for both computers? If so then that's probably the problem.
Mar 14, 2009 | Belkin (F5D7050) 802.11a/g/b Wireless...
No internet Connection
this is something simple
2 things you will have to do
the router when a problem like this happens again
unplug router for 1 minute this is packet build up and then plug back in i found this out by service provider that its a build up of packets it relieves packets
now the other thing since you went threw all the little areas of trying to reset modem go in remove your network connection
delete it and build a new network connection threw the network setup wizard then your done restart comp everything should be back to normal and you wont have to ever reset network settings again
just unplug the router let sit for minute and plug back in
Jun 01, 2008 | D-Link AirPlus DI-524 Wireless Router
Xoom x6 adsl modem problem
possible issue with freequent connection loss when going over 2 comp on a network are possible issues of collisions on the network meaning that sometimes more often then not, it is possible for two comp to end up recieving same ip address fr modem.
solution: first find out ip range supplied by the router in modem. then statically assign ip address to each comp
this is done by going into tcp/ip properties of either nic or wireless card and set to use following ex
NOTE: IP RANGE USUALLY LAST SET OF NUMBERS IN IP ADDRESSING TIPPICAL RANGE IS BETWEEN 10 TO 99
ip address: 192.168.2.12 (static ip address for computer)
subnetmask: 255.255.255.254 (generic subnetmask)
default gateway: 192.168.2.1 (ip address of router)
Oct 18, 2007 | Zoom X6 (5590) DSL Modem (55900003)
802.11g Network Adapter Radio Control Switch
It's not a physical switch, and they really should put more thought into the error messages they write. To "flip" the "switch" you hold down your function key and hit F2 (you'll notice a little symbol on the F2 button - that's the "radio switch"). After that, just right click on your wireless connection and choose repair.
Aug 29, 2007 | Computers & Internet
Computers & Internet Logo
70 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
