Question about Toshiba Regza 32LV67U 32 in. LCD HDTV
I have my tv in pc mode. how do i get audio to work \
  • 39 Answers
You must plug speakers into the the computer because the sound comes from the pc I have a pc which I plug into my hd tv so that should work
Posted on Jan 03, 2011
HDMI sound is not working. I recently upgraded my laptop to one which has a HDMI output. When I connect it the picture works fine, but there is no audio...I have checked all audio settings on the laptop,...
The picture appear in the TV?So better check the plugging of HDMI cable or please try anather HDMI cable to find if the problem is in the cable.Then try it again the setting of the TV.Check the menu of the TV and set it to pc mode.
Jul 04, 2011 | Televison & Video
Tip
How to connect a PC to a TV.
At the rear or side of the PC there should be either or both of a 15 Pin DIN Plug, HDMI socket. or a Yellow RCA or 4 -7 pin DIN. Now IF these are present then YES you can connect to a TV. Now some TV's have a connector a DB15 MALE, so that the cable from the PC to the TV, is DB15. this plugs in directly, with appropriate DB15 cable. This, however, will ONLY take the VIDEO to the TV, Audio is delivered via the "Audio Out" Jack on PC, and Plugged into the AV Sockets on the TV, with a dual cored coaxial cable, they are Red & White. Some PC's also have a Yellow RCA Connector, OR a 4 -7 Pin DIN Socket, that requires a Special Adapter Cable (That generally came with the unit, and are colored and marked as to output) to use, for Video/Audio Out to TV. This signal is Composite or SVHS Video & Stereo Out. This connects up TO the TV's Composite/SVHS input Jacks and the Red & White Audio IN, RCA Jacks, &/or DIN SVHS socket. Also we have "Component Video" marked "Y" "Pb" & "Pr" these simply go color to color at BOTH ends, this is where the Red, Green, & Blues, colored Ends, of the Wires, goes, remembering that this is ALL only Video. With this method, you still must use the AV, red & White, Audio, Inputs to get the "Sound" into the unit
First you need to know if your PC can output to a TV. Then you need to get the adapter & cables that connect the PC to the TV. Then you need the correct TV drivers installed for your video card. When they are all installed, you need to "Enable" that Monitors, the TV's, Desktop. You need to set either a "Cloned" display or "Spanned, Extended Desktop". Go to "Display Settings" Now ensure the TV/Monitor connected has the correct input/output display settings. Adjust the screens resolution via the resoloution "Slider", it is best to start with, 800x600 32 bit color. or even lower. and once working OK, THEN increase to max resolution, your TV can handle, find out from manual. Once it is all connected up. It should all just work great. Now, from then on, &, to get it to work every-time, the process is. Turn everything OFF. Connect the leads between PC & TV, Turn the TV, ON. Then, startup the PC up. It should "Detect" that it has TWO "Monitors" ie: One Monitor & One TV/Monitor, & you should see your desktop appear after a bit. Now you have screen 1 & screens 2. Now, if you are using "Cloned" mode, then whatever is displayed on the Master monitor, will be displayed on the TV. If you used Spanned, mode, in this mode, however, you will have to."Drag" the Video window, over to the TV, and it is though, you have one "Big Desktop". Now IF using Nvidia or ATI then BOTH of those have thier OWN, Control Panel, this, all then can make it all a lot easier to do it. So I would suggest that this method be used. But if you get stuck, or just want to do it by hand, then the the "By Hand" method is the only way.There is a great program called MultiMon, this allows great control over dual displays, and is well worth installing.
on Feb 07, 2010 | Computers & Internet
I have a samaung pc/tv monitor,i use for pc and tv use,i have external speakers for the pc and would like to connect them also for the tv as the sound as is not very good,putting the tv menu in external...
Some actual model numbers would make this conversation more relevant.
If your PC speakers are self-powered they should accept the RCA output from any device that provides headphone or Line Level audio.
Where is the TV audio actually coming FROM? Maybe a Cable Box? THAT is where the PC speaker should tap in.
Many TV's have a Fixed or variable audio output. Fixed allows for disabing the TV speakers or turning its volume down without affecting the audio out to other devices.
Mar 13, 2011 | Audio Players & Recorders
Issues with LG 26LE5300 26 in HDTV LCD TV Both audio & video flicker off & on when connected to PC via an HDMI cable. No problem when in TV or AV (DVD) modes. PS. worked fine on Day 1, did not...
Reduce the resolution of the PC to 1024 x 768. This can be done by right clicking on the desktop ( not any icon ) click properties / click settings / slide the screen resolution pointer to 1024 by 768 / slick apply / Computer will ask if you want to save this setting /Click yes and then try connecting the TV to the HDMI port. Should work
Mar 11, 2011 | LG 26LE5300 26 in. LCD HDTV
My tv is in pc mode but i cant get audio to work. what do i need to hook this up
Look close by where you hookup the video cable for the PC video input, there should be a small hedphone jack the same size as the MP3 player, it should be labled with PC audio, that is the audio input for PC mode, you will need the cable also.
Jan 03, 2011 | Toshiba Regza 32LV67U 32 in. LCD HDTV
I can watch a movie from my computer to tv but the sound only came from the computer not on the tv
if you want the sound from tv, get an audio cable and put one end to computer where the speakers connected and the other to the audio input or aux in back of tv.
good luck hope it works, if so do rate the solution
Nov 28, 2010 | Vizio 42 in. LCD TV
Which accessories are a 'most have' for connecting my TV to a desktop pc?
You'll need:
•VGA cable
•S-Video Audio to 3 RCA Type Adapter Cable
•HDMI cable
•DVI cable
Check the connection options on your TV. If your TV has a VGA connection slot, plug the TV into the computer with a VGA cordlike a computer monitor. Connect one end of the VGA cable to the back of the computer and the other end to the TV. Switch between normal TV viewing to displaying your computer on your TV by selecting the proper mode from the remote control, some remotes will mark the proper mode as "VGA" while others will label it "Computer" or "PC."
Check the back of your computer to see if you have an S cable slot. Connect S cable portion of the S-Video Audio to 3 RCA Type Adapter Cable to the computer and plug in the green audio plug to the audio port of the PC. Plug the red white and yellow RCA cables into the matching colors of the RCA slots on the TV. With this method you will need to switch modes from TV to video.
Check the back of the computer and TV for either DVI or HDMI slots. The slots on your computer must match, you cannot connect a DVI to a HDMI. Plug one end of the corresponding cable into the the back of the TV and the other end into the computer. Choose the correct program mode, HDMI or DVI, from the remote to view the computer from the TV.
Aug 12, 2010 | Televison & Video
Problem using Audio 3 sound inputs for HDMI video
Normally this problem is simply a matter of selecting the correct default audio playback device in the Windows control panel (sound option).
Check the Playback tab and set the default device to either DVI or HDMI.
http://pcaudiohelp.com/fix-hmdi-sound-to-tv
Feb 25, 2010 | Sanyo DP50747 50 in. Plasma TV
Try to connect Samsung lcd hdtv using pc cable. I click source, PC and enter but no picture.
You must set it all up first. It seldom "Just works" At the rear or side of the PC there should be either or both of a 15 Pin DIN Plug, HDMI socket. or a Yellow RCA or 4 -7 pin DIN. Now IF these are present then YES you can connect to a TV. Now some TV's have a connector a DB15 MALE, so that the cable from the PC to the TV, is DB15. this plugs in directly, with appropriate DB15 cable. This, however, will ONLY take the VIDEO to the TV, Audio is delivered via the "Audio Out" Jack on PC, and Plugged into the AV Sockets on the TV, with a dual cored coaxial cable, they are Red & White. Some PC's also have a Yellow RCA Connector, OR a 4 -7 Pin DIN Socket, that requires a Special Adapter Cable (That generally came with the unit, and are colored and marked as to output) to use, for Video/Audio Out to TV. This signal is Composite or SVHS Video & Stereo Out. This connects up TO the TV's Composite/SVHS input Jacks and the Red & White Audio IN, RCA Jacks, &/or DIN SVHS socket.
Feb 10, 2010 | Televison & Video
Lcd montior with tv box but no hdmi sound
in some cases certain manufacturers say in the instructions that when using s video with seperate audio, you cannot use the HDMI for the sound and sometimes visa versa, it's just the way the output is set up. Remove the other sound cable you are using for pc or tv and just use HDMI to confirm that the sound is re-enabled on the HDMI
Oct 02, 2007 | Sony Playstation 3 (PS3) Console
Toshiba Regza 32LV67U 32 in. LCD HDTV Logo
53 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
