Question about Acer X163W 16" wide format TFT Screen 8 ms, VGA 16 inch Monitor
I have my monitor connected to my laptop because the laptop screen went out. The monitor has been working fine until the last few days but now when I power on the laptop & monitor, the monitor only comes up for a few seconds then says no signal. I know the laptop is working because it has fingerprint log in & I can hear the music that plays when my homescreen comes up. Any suggestions for troubleshooting when I'm working "blind"?
  • 442 Answers
Please restart the computer and go to safe mode by tapping F8 key once the system is restarting choose Enable VGA Mode (Windows XP)
choose Enable low resolution Video (Windows Vsita / 7).
Change the display settings to slightly lesser than what the monitor can handle and shut down and restart the computer in normal mode.
Posted on Jan 03, 2011
Monitor works sometimes and sometimes not
Reboot pc until you have a picture, then try updating the drivers for the monitor and your gpu if applicable, outdated drivers can cause erratic and intermittent behavior. Navigation to drivers access varies slightly based on operating system.
Sep 02, 2017 | Computers & Internet
Monitor went black
I have same problem. only 13month worked.
Jul 26, 2010 | Samsung Home Security
HP zv5430us laptop has no video. Blank
The laptop has a built-in video card and the video RAM uses part of the main RAM.
First, re-seat the RAM modules and if the laptop still does not boot up normally then remove the RAM and get it tested at your friendly computer repair shop.
If the RAM is OK then connect an external monitor to the laptop, power up the monitor first and then the laptop. The video data should divert to the external monitor automatically, if you do not get any video image on the monitor then the video card in the laptop is faulty and a motherboard replacement is required.
A replacement motherboard may not be a cost effective solution and If it was me, I would put my money on a new laptop. I would then remove the hard disk and insert it into an USB adapter case and use it as an external USB hard drive.
Mar 22, 2010 | HP Pavilion zv5430us (PR466UAA) PC...
Hi I have a samsung syncMaster 920N The screen has suddenly gone blank - the power light is showing. I have a second identical monitor and have swapped cables but no difference Is it a repairable fault?...
This happened to me a few months back. I removed all cables and left it for 2 days. Switched back on on it worked fine. That is until yesterday when half the screen went black. I found that my driver was out of date. I have undated the driver but have decided to leave it off and unplugged for another day.
You could try this. You say you have another monitor, i would suggest using it for a few days and the try the old one again.
Dec 05, 2009 | Samsung SyncMaster 920N 19" LCD Flat Panel...
Laptop LCD display problem
The backlight is the light bult that illuminates the screen. Before it finally goes out completely it will turn your screen a pink color on startup (and then usually become brighter and the pink fades). It is also possible that the backlight, also called a Cold Cathode Flourescent Light, CCFL, died an immediate death. But usually they take a while and signal with the "PINKNESS" first. If you found that your computer is working just fine connected to an external monitor (and you moved the base of your laptop around while connected to the monitor to be sure and left the computer on for a long time) then you have verified that the screen is the problem. It is usually two things: (1) the inverter, a circuit board that increases the voltage to supply the LCD which eats around 700 volts (yeah baby); or (2) the backlight itself. The first problem is a relatively easy and inexpensive fix. You can find how to replace an inverter by downloading the Hardware Maintenance Manual for the T40, T41, etc., from IBM/Lenovo's site. Replacing the backlight itself, a bulb that is like a strand of speghetti and even more delicate, is a tougher job. I would suggest purchasing a replacement screen in that event rather than replacing the backlight yourself. (The HMM probably does not show you how to replace the backlight/CCFL as it is a potentially dangerous job.) That suggestion assumes you can find a cost-effective replacement screen and do not mind opening the TP and putting the new screen in. At least look at the HMM to see what is involved. Good luck.
Apr 07, 2009 | IBM ThinkPad T42 Notebook
Screen went black
Swap monitor connections to determine if one of the monitors is not working.
If one is not working you probably have an internal problem. If power led responds to the off-on button but no picture is seen, the inverter has likely blown a fuse. Replace the fuse and resolder the leads on all 6 inverter transformers or the fuse might blow again.
Monitor Mike
Mar 27, 2009 | ViewSonic VP201s 20.1" LCD Monitor
Problem with the display on screen
Try connecting an external monitor to the laptop and see if the colors are also present on the monitor. If the monitor display is fine, then your laptop’s LCD display panel is defective. If the monitor also displays the colors, then your problem is with either the video card or motherboard located inside your laptop.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Nov 13, 2008 | Dell Vostro 1500 Notebook
Black screen
One way to test it is to connect a monitor to the VGA port (make sure to activate the external monitor (Fn+monitor key)
If it does work on the external monitor, I would look at replacing the onboard LCD.
If it doesn't, you are looking at problems with the onbaord video.
Aug 05, 2008 | Toshiba Satellite A105-S4334 Notebook
Faulty backlight hp laptop
Well, first off, do you get a screen (external or onboard) if you boot into the bios? If you have no video whatsoever, the only thing that would start working again after time off, then stop, would be the video module went. slowly, but it went.
Main cause is overheating, caused by the heatsink/fan becoming clogged up.
What makes you think the backlight was the problem BTW? Sure it wasn't just the inverter?
Let me know if you can access bios?
Good luck
Oct 20, 2007 | HP Pavilion dv1000 Notebook
Acer X163W 16" wide format TFT Screen  8 ms, VGA  16 inch Monitor Logo
121 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
