Epson nx 420 printer error e-01 - Office Equipment & Supplies
  • 42 Answers
SOURCE: Communication error Code # 0503 using Epson nx 300
hi,
i do not use this same model, but my colleague who uses this machine had a similar problem. we broke our head on it for 4 days, then turned off the error correction mode. it solved the issue for him. it could solve your problem too.
cheers
Posted on Jul 25, 2009
SOURCE: Epson Stylus NX 400 won't start I only have an
need to install at my computer
Posted on Jun 05, 2010
SOURCE: error 01 0n epson dfx 9000
please i need solution for dfx 9000 epson for error 01 problem
Posted on Sep 24, 2010
  • 50 Answers
SOURCE: when i turn my printer on error message occurs
Power off the printer, unplug the power cable.
Lift the scanner lid, check for obstructions that might be blocking the print head.
Close the lid, reconnect the power cable and power on the printer.
If it still says E-01, please contact your local service center or the store where you purchased the printer for your warranty options.
Posted on Dec 08, 2010
Basti
  • 1447 Answers
SOURCE: The NX 420 is Printing
Hi!
Are you printing from your computer? Sounds like your driver software is corrupted. Uninstall and reinstall driver software.
Hope this helps.
Posted on Dec 17, 2010
Epson 420 printer has error OxF1....how do you fix it
Here is one web reference that may help.
If you are lucky the issue has to only do with the printer and unplugging it/removing cartridge/reinstall may fix the problem. If that does not work then supposedly the problem is created by your PC and that is much more a pain to fix
http://printers.iyogi.com/help-support/errors/fix-0xf1-epson-error-code.html
Good luck on your troubleshooting
Jan 17, 2018 | Epson Office Equipment & Supplies
Epson printer xp 305 printer error E-01
This Epson Printer error E-01 occurs in the Epson Service Manual which indicates a type of fatal error. It simply signifies that the printer is incapable to finish the self-test process. When users are trying to power ON the printer it begins to check for all systems. If it is found that it is unable to finish the self test process then, the printer will come up with an error message as mentioned above. Follow these steps to resolve Error E-01.
Steps to Resolve Error E-01:
Step 1: Turn on/off the printer power button
  • Turn the power off. Wait for a while then turn on it again.
Step 2: Managing the lock of the printer
  • Store transportation lock carefully.
Step 3: Managing the CD tray
  • Press the CD Tray button to retract the tray to its original storage position. Be careful never to push or pull the CD tray into the wrong position. Turn off the Epson Printer and make sure that there is no paper left which may lead to paper jam issue inside the unit.
Step 4: Checking the printer cartridge
  • If the printer is installed with the CISS then, make sure that its carriage is easily movable towards left and right side.
  • The printer's upper scanner part should be closed tightly.
Step 5: Perform a check-up process.
  • Install original Epson ink cartridges and then run the printer.
Step 6: Access the cartridge
  • Access the cartridge loading area while the printer is in off-mode and then, move the carriage right away from the stop. Carefully disassemble the printer and then, clean all its optical sensors, paper feed sensors, encoder strip as well as disc encoder.
Contact Epson Printer Support Number if you have any issues in printer.
Apr 12, 2014 | Epson Stylus RX580 InkJet Photo Printer
The NX 420 is Printing only symbols How can i reset The actual printer manually so that this will discontinue
Hi!
Hope this helps.
Dec 17, 2010 | Epson Stylus NX400 InkJet Printer
My Epson stylus NX 400 continually says "error..replace ink cartridges" I did and nothing changed.
Assuming the cartridges are new (since almost all of them have a chip on them)
1. Make sure you match color of cartridge with the correct slot. If same error, then
2. remove all carts. and clean both cartridge holder and cartridge contacts with alcohol.
good luck
Nov 06, 2010 | Epson Stylus NX400 InkJet Printer
Error 01 0n epson dfx 9000
i have a problem on my printer epson dfx 9000 with erro code 01 turn off your priner any one with solution?
Aug 29, 2009 | Epson DFX-9000 Matrix Printer
hi,
cheers
Jul 25, 2009 | Epson Stylus NX300 All-In-One InkJet...
My Epson NX 400 is giving me this error message:Error B88/69/68 C
Try to run the ink pad reset utility software.
Please log on to epson.com. The software runs on win xp and win vista.
Mar 31, 2009 | Epson Stylus NX400 InkJet Printer
835 people viewed this question
k24674
jasbo
jasbo
