Question about Dryers
Kenmore elite HE3. With the therma fuse what amparge is it? I start the dryer-lights come on and when I push start button; it only beeps-please help. Thankyou
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 239 Answers
If it beeps, it is not the thermal fuse. Likely that the door switch is at fault. Push the switch in and release several times, it should click. If not, replace the switch. Switch is available at http://www.aplusapplianceparts.com/searchquick-submit.sc?keywords=8283288, coupon code 1050 will save you some money if used!
Posted on Jan 03, 2011
  • Iam Jan 31, 2011
    I seem to have the same problem. The panel lights up and all buttons work, but when I hold down the start button I only hear a beep, but the drum doesn't turn. The timer even counts down the minutes. My door switch is fine, it turns the light on and off. When I hit the cancel button I hear a click.
Dryer wont start
check your compasitor it like a big fuse on the side of your dryer near bottom
Oct 13, 2014 | Kenmore HE3 Gas Dryer
Dryer won't start. I push the start button and it beeps once and then won't start. Door is closed, no error messages.
Hello- It sounds like the dryer is not sensing that the door is closed, in other words the door switch may be faulty or there is a communication error to the control board. Unfortunately you may have to have someone out to take a look. Good luck, best regards.
Sep 26, 2010 | Kenmore Elite HE3 Steam 9674 Dryer
When I press start, it beeps, but will not start -- Kenmore HE-3
I pressed the reset button inside the dryer with my finger and then turned the dryer on with the door opened. After I closed it, it worked again.
Jun 16, 2009 | Kenmore Elite HE3 Steam 8674 Dryer
Kenmore Elite HE3 Dryer (3 yrs. old)
when u push the buttons do all lights light up if so ,, machine is in lock mode ,, press and hold the little icon that read lock for about 3 seconds unitll lights are off then run ,, let see
Nov 19, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore elite HE3
You need to check if the Spray Arms are knocking against an item in a basket. If the source of noise cannot be determined, run a program without plates or glassware. If the noises continue, let me know for further investigation.
Oct 05, 2008 | Kenmore 82822 Electric Dryer
Kenmore elite he3 electric dryer
If you get a series of four rapid beeps when you push START in an attempt to start your dryer, your door switch (interlock) is defective.  I have experienced this problem before and it is a fairly simple problem to fix.  The easiest way to tell is to open the dryer door and push the door interlock in by hand.  Hold it in while pushing the START button.  If the dryer starts, then all you have is a simple problem of the door not closing properly.  If the dryer still does not start, however, replace the dryer door interlock.  The interlock should also make a definite "click" while pushing it in.  If it does not, the switch is worn out.  Some dryers have an upper and lower door interlock.  If yours is equipped with two interlocks, make sure they are both functioning and that the door is latched properly.  I have experienced problems where dryers doors with two interlocks would close at the top, but not at the bottom.  The dryer would not start as a result.  If you can provide me with your model number I can get a part number and price for you.  I can also tell you where you can get the part and provide instructions on how to replace it.  Let me know.  I hope this helps you.
Oct 31, 2007 | Dryers
Dryers Logo
105 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
