Question about Kenmore HE2 Plus Front Load Washer
HE2T front load washer F28 flashes machine is locked clothes inside cannot open help
  • elizabethr28
    elizabethr28 Aug 16, 2012
    Hi, My HE2t front load washer locked, i manuelly unlocked it, clean out drains, hoses, unplug and repluges electrical, it powered up went through it's cycle until the last few minutes, then would not unlock, or finish draining, also the drum would not rotate, but the belt is intact...so i am assuming it is the drum motor and or the pump motor...about how much would these cost to replace and where could i purchase them? Any advice would be greatly apperciated!
  • 1,772 Answers
Tre
ert
Sorry to read about your problem, I hope this helps you out.
The error code F28 means one or both of these parts are bad.
Motor Control Unit (8540135)
Microcomputer Machine Control Unit (8540788)
It would be a good idea to order both, as both components have been problematic for
error code F28
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
Posted on Jan 03, 2011
  • kenchristine Jan 10, 2011
    You can remove the bottom panel or toe kick. There are 3 screws at the bottom edge holding that panel. Once you remove the panel there's a manual door release. On my unit, it was on the side of the door latch (not the door hinge), and it required a slight tug. Good luck
What does f23 error mean?
Display shows an error code - Front-load washer ' Whirlpool ...
https://www.whirlpool.com/...error-code...w...
Whirlpool Home AppliancesCheck the following answers for error-code related issues you can correct: ... Duet SportTM washer - F01, F11, F23, F24, F27, F28, F29, F30, F31, and F33.
What does error code f23 flashing mean on a Whirlpool ...
Nov 30, 2015 | Washing Machines
It starts and then stops and then F28 flashes
http://www.ukwhitegoods.co.uk/help/fault-codes/laundry-fault-codes/3708-whirlpool-washing-machine-fault-codes.html
Not good! Probably motor control board or motor or wiring harness from control board to motor.
This leads to a Kenmore Video
Whirlpool, Maytag, Kenmore. Same machine different name different trim.
Whirlpool Duet f28 YouTube
Sep 21, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Error code f28 on Kenmore HE2t model #11047561601
my washer modle 970-C41062-00 my iner bearing it boken i take a part but i try to find bearing kit parts number .I need parts number.kit
If Do you kno it. thank you.
Sep 16, 2013 | Kenmore HE2 Plus Front Load Washer
The machine is locked and can't open with clothes washed inside,. Add garment light is on and the time is flashing'
Whirlpool-made Front Loading such as the Kenmore Elite washing machines use a door lock and switch assembly having a tab that can be pulled manually for emergency opening of the door. This tab can be accessed with the removal of the lower front access panel. Disconnect power to the washer and drain the water from the tub before accessing it. The link below contains the detailed instructions on manual unlocking of the door.
Manual Unlocking of Whirlpool Duet and Kenmore Elite Front Load Washing Machines
Aug 26, 2011 | Kenmore HE2 Plus Front Load Washer
My kenmore he2t 8540911 drum will not spin.all of the time and leave the clothes wet.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 09, 2011 | Kenmore 43142 Front Load Washer
The door is locked and cant get clothes out or washer to run. says f28
you will have to call a tech f28 is a control board failure, or if you are lucky and you have the anti flood hose, to your machine..i would remove them and put standard hose on the unit
Dec 19, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F28 error / water starts to fill then quits in 15 sec's
F28 is a communication error which usually means there is a connection that has come loose.Check the wires on the control board.
Nov 22, 2010 | Maytag EPIC MFW9700S Front Load Washer
F28 code
"F28" means your washer is locked and not unlocking. To unlock your washer take the bottom access panel off by removing the 3 bottom screws.
Reach up near the latching assembly & attached to the door latch is a little plastic pull lever. Pull down on this lever and open the door. Unplug your washer for 60 seconds and plug your washer back in. If the error re-occurs you need to replace your door lock.
Thank you!!
Jul 05, 2010 | Kenmore HE2 Plus Front Load Washer
Every time I start my Kenmore HE2t washer there is
If it has a clean cycle that says, "Bleach Only," run it with 1/2 cup bleach right in the machine. If not, run it on the longest, hottest cycle you have. In the future, leave the door open slightly between loads.
Oct 29, 2009 | Kenmore Elite 45986 Front Load Washer
F-28 code
F28 means your washer is locked and not unlocking. To unlock your washer take the bottom access panel off by removing the 3 bottom screws.
Reach up near the latching assembly & Attached to the door latch is a little plastic pull lever. Pull down on this lever and open the door. Unplug your washer for 60 seconds and plug your washer back in. If the error re-occurs you need to replace your door lock.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Jun 28, 2009 | Kenmore HE2 Plus Front Load Washer
Kenmore HE2 Plus Front Load Washer Logo
1,639 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
