Question about Horizon Safety Magnet Key, Rope/beltclip-
The safety key won't reset? What do I do? The treadmill closed quickly and hard when I was trying to put a mat under it. I just bought it today used and it worked until this happened. Any suggestions
    Novelist:
  • 128 Answers
Inside the console (you will have to remove the bottom cover of the console) you will find the reed switch that was glued secure to the safety key position, has probably come loose . Just resecure it with hot glue and you should be good to go.
Good luck.
Posted on Jan 03, 2011
Our treadmill stopped working when we turn it on all 3's appear on the screen
Hi Andrea, I had a similar problem with my treadmill, I live in Australia and I didn't checked the fuse because there were lights on the console display mat which meant power to the console mat and I eventually replaced a faulty console matt for $100, Hope this helped .......CHEERS..
Apr 11, 2016 | Exercise & Fitness
Can you advise please
reset the machine make this: God bless you
Unplug the treadmill. Locate the console key and place the safety or reset key into the treadmill console. Replace any parts that need replacing, or is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
    • 3
Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
    • 4
Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset.move on to the next step.
    • 2
Locate the reset switch on the underside of the treadmill console. Usually the button
Nov 28, 2013 | Precor 935 Premium Series Treadmill
I bought a elite saracen treadmill n it says error code 4 what does that mean please n e wun help me pliz
reset the treadmills, follow this steps and fix it. GOD BLESS YOU
However you must RUN the software calibration for fix it. see your owner manual. or download free from www. fitness.manualsonline.com
    • 1
    • 3
    • 4
    • 2
GOD BLESS YOU
Nov 08, 2013 | Exercise & Fitness
I cannot see You Tube on my I Pad
reset the system and try again.God bless you
    • 1
    • 3
    • 4
    • 2
Oct 16, 2013 | Exercise & Fitness
PLO5 error message on Quinton Clubtrack treadmill
Try to clear the error message. God bless you
1 )Locate the reset switch on the underside of the treadmill console. Usually the button is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
  • 2
  • 3
Jan 25, 2013 | Quinton Stairmaster Clubtrack 3.0 GymTough...
I have an Ifit treadmill. I was changing speeds and it turned off and won't restart. It beeps when i turn it on but no lights on console.
Power issues with ProForm treadmills fit into two categories: the power does not turn on or the power shuts off when using the treadmill. If the power will not turn on, make sure that the treadmill is plugged into a working power outlet. In addition, you should use a single-outlet surge protector for the treadmill. Single-outlet surge protectors protect the machine from any voltage changes that may occur in your home.
If the machine is plugged into a working outlet, make sure the safety key is in the keyhole on the console. If the safety key is not plugged into the machine or if it is pulled out during operation, the treadmill will not operate.
Finally, make sure the circuit breaker located on the frame near the power cord is set to "Reset." The circuit breaker is set to "Reset" if the top of the button is pushed in. When the breaker is tripped, push it back to the "Reset" position and wait five minutes before powering on the treadmill.
If the ProForm treadmill shuts off during operation, check the power cord and circuit breaker as described above. You can also try removing and reinserting the safety key.
Increase Engine Horse Power.
Jun 02, 2012 | Proform Exercise & Fitness
Treadmill rubber tread has strong odor
Turn off and unplug the unit before making any adjustments. Check the belt alignment on the treadmill. If the treadmill is making noise or you smell burnt rubber, the belt may be loose or out of alignment. There should be a belt roller on the side or the front of the unit. You can use a hex wrench or an adjustable wrench to loosen the belt so it can be properly aligned. Make sure you tighten the belt so it does not rub against the machine. Consult the user manual for specific instructions in adjusting the belt.
  • 2 Reposition the heart rate monitor. If the monitor does not show a reading, it may need to be repositioned. The monitor should be placed against your skin so the sensor is facing toward your body and the HealthRider logo is facing away from you. The monitor will only work if you stay on the treadmill, walking in the middle of the belt.
  • 3 Test the hand grip monitors for a correct reading. These are the metal plates that are secured to the hand railing. If the plates are dirty, they may not function correctly. Wipe them clean with a damp cloth. Your palm will need to wrap completely around the plates at all times for a proper reading.
  • 4 Reset the unit if the treadmill still does not function correctly. Unplug the unit from the electrical outlet. Leave it unplugged for about one minute and then turn the machine back on. Remove the safety key from the treadmill and reinsert it into the key slot. Taking out the key will reset the unit, clearing all memory and resetting it to factory defaults.
  • Nov 09, 2011 | Exercise & Fitness
    We just bought the floor model of the weslo cadence 58 treadmill and it wont work, we have the key, but it is not working. is there a switch we should be turning on to get it to work?
    Plug in the power cord . Next, locate the reset/off circuit breaker on the treadmill frame near the power cord. Switch the circuit breaker to the reset position. Then put your safety key and it should start up for you.
    May 03, 2010 | Weslo Cadence Ct 5.8 Treadmill
    Ifit treadmill will not incline but everything else works, how do I fix the incline
    You may need to calibrate the incline. Do this with the following procedure.
    Safety key out
    press the stop and speed up buttons at the same time while inserting the safety key. (you are now in diagnostics)
    press the stop button one time only.
    now press the incline up button (incline motor should start moving up)
    incline will go up to the top and then all the way to the bottom. when it gets done you can remove the key. Reinsert the key and you should be operating normally.
    Good luck Tim
    Nov 23, 2009 | Proform Quick Burn Pro Treadmill with 12...
    Horizon Safety Magnet Key, Rope/beltclip-  Logo
    200 people viewed this question
    Top Horizon Exercise & Fitness Experts
    Electro Med Services...
    Ross Metcalfe
    Ross Metcalfe
    Matt Olenzek
    Matt Olenzek
    Are you a Horizon Exercise and Fitnes Expert? Answer questions, earn points and help others
