My machine is not spinning what may be the problem
  • 472 Answers
Depends on what brand and type of unit... is this a front loader a top loader and what brand.. is it direct drive or belt driven.... if it is belt driven could be a bad belt or pulley...if it is direct drive such as a top load whirlpool ,kenmore,roper, you could have a bad drive coupling which is located between the motor and transmission under unit.... if this is a front loader there are numerous items it could be example a motor controller board, main pcb board.
if everything is working but the spin mode and this is a top loader unit may want to check the lid swich that will cause the unit to not spin.... hope this helps kinda a vague description of your probelm....good luck and give me a vote i need them....
Posted on Jan 03, 2011
Kenmore Series 70 Top Load Washer Direct Drive Model # 110.20722991 Serial# CL 1134809 Wet Clothes after Spin Cycle
many machine spin a full tub as they are pumping the water out
this helps to even out the washing load and reduce the unbalance situation
when the water is removed , the machine progresses the program to a high speed spin
call a technician as there may be a problem in the program board
Jun 11, 2016 | Kenmore Washing Machines
Washer does not spin and drain properly
How To Fix A Washing Machine That Is Not Spinning or ...
removeandreplace.com/.../washing-machine-or-washer-dryer-is-not-spin...
May 15, 2013 - Washing Machine Service Repair Manuals Online Your washing machine is not working properly. It does not spin, won't drain, can't turn on, ...‎Washer Not Draining Water - ‎Washing Machine Service ... - ‎How To Fix A Washing ...
Washer Repair - Not draining or spinning ... - YouTube
? 5:17
https://www.youtube.com/watch?v=k41abYwM9WY
Jul 12, 2013 - Uploaded by ApplianceVideo.com
Washer Repair - Not draining or spinning - Repair & Diagnostic- .... off and my machine spins but it doesn't drain (high spin) does not work.
Dec 19, 2015 | Whirlpool Cabrio WTW5500BW White 27"...
Can't spin. Makes ratcheting noise as it attempts to start spin, can't start spin even w/o load.
What to do when Samsung Washing Machine does not spin ?
www.samsung.com/ae/support/skp/faq/1033383
Samsung Electronics'Washing machine not spinning' is one of the major problems faced by people nowadays with ... If so, the washing machine can't spin and may not function at all.
May 13, 2013 - Washing Machine Service Repair Manuals Online Your washing machine is not working properly. It does not spin, won't drain, can't turn on, ...
How to Fix Washer That Won't Spin ' Washing Machine Repair
Nov 28, 2015 | Washing Machines
Washing machine does not spin on spin cycle,only hear a humming noise.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Jun 27, 2011 | Kenmore Washing Machines
Washer does not spin out during the spin cycle. Everything else is working properly.
heatman101
Apr 14, 2011 | Washing Machines
My whirlpool AWOD4606 washing machine won't spin when washing or spinning
heatman101
Apr 13, 2011 | Washing Machines
Wont spin
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
Apr 05, 2011 | Maytag Washing Machines
Clothes are very wet after spin cycle This unit has several spin speed settings, machine does spin but not fast enough to remove water from clothes
heatman101
Sep 16, 2010 | Kenmore Washing Machines
When its time for my washing machine to spin out...it sounds like its spinning, but when you open the lid...the water is out...but the clothes are still wet and the machine is not spinning
heatman101
Aug 29, 2010 | Roper RAS8445KQ Top Load Washer
The machine wont spin when in spin cycle and
try cleaning out the coin trap/drain hose that is underneath the machine
this is also the error code E20 which sometimes the machine will start flashing
Jan 15, 2010 | Frigidaire Affinity ATF7000E Front Load...
Washing Machines Logo
110 people viewed this question
Top Washing Machines Experts
