Question about Dishwashers
My new lamona integrated dishwasher is stuck on no heat program tried to cancel but no change, any ideas I cannot fins my instructions. Thanks
SOURCE: My Kenmore dishwasher has the
I held the "Heated Dry" button down until the lock light went out. It may have been 10-15 seconds. All seems well now.
Posted on Dec 17, 2008
SOURCE: Lamona dishwasher from Howdens. E1 code
we have a howdens dishwasher model number hja8630, which is full of water which hasnt drained . i have ladled it out checked filters are unblocked but it still fails to start. it does a click click sound and then nothing . only 18 months old and only ever used twice a week
Posted on Mar 22, 2010
I had the same problem with my dishwasher. I ended up pulling it out and i noticed that the hose that feeds it water had been folded. I then restarted it and it worked fine but juse to test I turned off the water supply and there it was E1.
So in short, E1 is no water feed.....
Posted on Aug 14, 2010
sodeep
  • 3267 Answers
SOURCE: How do I change or
  • 1 Wait until the dishwasher has completely cooled after use before attempting to clean the filter. Turn the dishwasher off and unplug it from the power supply.
  • 2 Remove the lower dish racks and locate the filter compartment on the bottom of the dishwasher.
  • 3 Unscrew the filter housing and gently pull to lift out the filter.
  • 4 Use a few drops of dishwashing liquid, warm water and a soft-bristled brush to clean the filter and the filter housing.
  • 5 Dry the filter and the housing and reassemble them. Reposition them in the bottom of the dishwasher and turn until locked into place. Replace the racks and close the dishwasher door. Plug back in to the local power supply.
  • Posted on Jul 07, 2011
    ercupa190
    • 12223 Answers
    SOURCE: instruction manual needed for NEFF integrated dishwasher S5433X0GB/13
    go to www.fitness.manualsonline.com and download
    God bless you
    Posted on Sep 27, 2012
    How do I replace a faulty on/0ff button on a lamona integrated dishwasher
    Dishwasher Push Button Switch Replacement - Bosch ...
    ? 1:56
    https://www.youtube.com/watch?v=MSO3nXetiOM
    Oct 8, 2012 - Uploaded by RepairClinic.com
    This video provides step-by-step repair instructions for replacingthe push button switch (or on/off switch ...
    Oct 26, 2015 | Dishwashers
    Lamona hja8630
    How do I remove the integrated door af a lamona hja 8630
    Jan 01, 2014 | Dishwashers
    Dimensions for tecnik 795/2
    This dishwasher was made for tecnik (moben/kitchens direct) by bosch. Any Bosch, Siemens or Neff fully integrated 600mm dishwasher will replace this machine.
    Apr 08, 2013 | Tecnik 24 in. TKD795/3 Built-in Dishwasher
    Lamona (Howdens) dishwasher. Start/Cancel/Pause button is not working.
    Probably a bit late for the original poster, but I found this page after searching with the same problem. You can actually fix this yourself. I had exactly the same problem - if you take the front off the dishwasher, the switch module is inside a grey plastic moulding. If you remove the two cable plugs and remove the two screws holding the moulding in you can then take it out. Carefully open it by pulling back the clips, and inside is a small circuit board that slides out. On one side are the two microswitches. I got mine working again with some switch cleaner. If that doesn't work, you should be able to get a new switch soldered on by any electrical repairer. Obviously, yours may be slightly different as I don't know what model dishwasher you have, but mine is a Howden's/Lamona too, so it's probably very similar. Good luck.
    Oct 07, 2012 | Dishwashers
    Heat/Dry button
    My motto with all electrical systems is: If all else fails reboot. Find the breaker that controls the dishwasher and switch it off for a couple of minutes. this will clear out the electronic buffer. and reset the systems. make sure that the door is not closed, reset the breaker and try to restart your dishwasher.
    May 16, 2010 | Kenmore 13593 Stainless Steel Built-in...
    Feb 21, 2010 | Dishwashers
    No Water in. Will not change wash cycles
    There was soap particles caught under the float valve. Thanks.
    Jim
    Mar 03, 2009 | Jenn-Air 24 in. JDB1100AWS Built-in...
    Dishwashers Logo
    105 people viewed this question
    Top Dishwashers Experts
    Owen Barnes
