Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
MY WASHER LOCK ON DOOR IS BROKEN AND CANT LOCK SO IT WONT WORK
  • 472 Answers
Yes it has to make contact and send a signal to the contro to tell it to continue on with operation...
if you go to www.repairclinic.com or apdepot.com  you can type in your model number and find you a new door lock switch for that model most likely and have them ship it to you....
good luck    please vote
Posted on Jan 03, 2011
Front load duet washer wont start because the door cant lock and we cant open the door.
You need to replace the door lock/switch. It is quite an easy job but is a tight fit behind the front so a bit tricky to get the old one out and the new one in.
Mar 06, 2012 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Washer. door lock wont lock. I hear a click click, like it's locked, but the indicator lock light is not on, then a couple seconds later I hear another click click like it's unlocking and then...
the actual door lock switch inside the wall of your washer where the door clips in has most likely burnt out or a piece has broken out of it i have found the only way to fix this problem is to replace the door lock switch
Jun 07, 2011 | LG WM-2277HW Front Load Washer
Washer wont turn on. code is F dL. any thoughts?
"dl" indicates a door lock error. A Door Lock Error occurs if the door cannot be unlocked. It will try to lock it 6 times before displaying the error.
Check for the following when dl occurs:
  • Door Lock Mechanism broken.
  • Check Door Lock/Switch Assembly for foreign objects
  • Check Wire Harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
  • Door Lock/Switch Assembly Failure
Thank you !!
Jul 07, 2010 | Whirlpool GHW9400SU Front Load Stacked...
The door is locked on my washer/drier and the machine is broken,
If you turn off your machine, remove the top then you should be able to reach inside and open the door.
Feb 19, 2010 | Washing Machines
FDL fault code on kenmore elite washer
F DL
A Door Lock Error occurs if the door cannot be locked. It will try to lock it six times before displaying the error code.
Nov 08, 2009 | Kenmore Elite 45986 Front Load Washer
The door on my washer won't lock!
the door lock has internal relays, if they go bad, the motor control board will not function. Even if you cant physically see anything, and even if the door still locks, the door lock assembly is still the most likely problem and needs replaced. The only way to test it is with a multimeter to know for sure before you buy a new one
Oct 19, 2009 | Frigidaire FTF2140FS Front Load Washer /...
My washer is locked and cant open it at all
Probably door-lock is broken or motherboard crash.
If it not signalize that door are closed propertly it want start taking water to wash.
It's overflow prevention.
See user manual -> possible problems or call local serviser.
Aug 11, 2009 | LG WD-16115FD Front Load Washer
Door lock wont engage
YOU MAY HAVE BROKEN THE BUTTON, A SMALL PIN LIKE PUSH BUTTON THAT PUSHES IN TO LET THE DOOR LOCK KNOW THE DOOR IS SHUT. YOU CAN USUALLY FIND A SMALL DIAMETER OBJECT LIKE WHAT IS IN A RETRACTABLE BALL POINT PEN TO SLIP INTO THE HOLE WHERE THE BROKEN PIN IS AS A TEMPORARY REPLACEMENT AND TO CONFIRM THIS IS ACTUALLY THE PROBLEM. IF IT IS, YOU WILL NEED TO REPLACE THE DOOR LOCK ASSEMBLY FOR PERMANENT REPAIR. DON'T SLAM THE DOOR SHUT BECAUSE THESE PARTS ARE MADE OF PLASTIC AND BREAK EASILY!
Jan 28, 2009 | Frigidaire ATF6000ES Front Load Washer
Kenmore elite he3 - door lock
If sound like a lid switch issue. Open the top of the washer to get an access to the lid switch(located near the doorframe). Look for a loose wire or a broken switch. In case there is no loose wire or broken switch, you should replace the switch. Good luck!
Sep 05, 2007 | Kenmore Elite 45986 Front Load Washer
Door clicks and wont open and washer runs but wont do anything
Potential reasons for it: - Door Lock/Switch Assembly Failure - In this case it should be replaced. - Door Lock unit is broken or removed from the door. - Look for disconnected wires to the door Lock/Switch unit. - Door Lock/Switch unit Failure You should remove machine's top cover and then you will have an access to the door lock unit. Be aware you should discconect machine's power cable first !! Good luck!
Jun 15, 2007 | GE WBVH6240F Front Load Washer
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
37 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
