Question about HP Officejet H470 InkJet Printer
HP H470 - Error message received saying that the USB was not detected. Tried a new USB and still does not work. I think it's the connection for the USB in the printer itself. Is there a way to fix this?
Benimur
  • 6966 Answers
SOURCE: HP LaserJet II p Plus will not print
I am assuming that you are using Vista. Based on your post/description:
1. the HP Compaq 6710b has no parallel port;
2. the HP LaserJet IIP Plus is only capable of either serial or parallel connection;
3. hence you're attempting a USB to Parallel interface;
4. the printer is installed in your notebook and is set to USB port;
5. from the printer a test print can be performed but not from the Printer Properties in your notebook;
6. all printing jobs initiated from the notebook results in an "Error".
With the above in mind, may I point/suggest that:
a. Windows Vista driver will only enable your HP LaserJet IIP Plus' basic functions to work. It is not 100% compatible;
b. alternately, you can try using the XP installation CD/drivers of the printer;
c. the compatibility issue may be compounded by the USB to parallel interface;
d. the USB to parallel interface may be hampered by a known Vista USB issue;
e. you can try patching/updating the Vista USB driver. Since this has been a recognized issue with Vista, Microsoft has posted a fix for this here or here.
f. verify that the printer does not display a 22 or 40 Error.
If the printing concern has not been rectified after completion of the above procedures, you may need to:
i. download and install HP Universal PostScript Print Driver; or
ii. consider using a wireless print server connected to the parallel port of the printer; or
iii.consider replacing your printer. Sorry.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Mar 12, 2008
  • 105 Answers
SOURCE: HP Solution Center cannot detect my 6110 AIO
Hello Buzzland, this error usually occurs when the HP Digital Imaging monitor is not running in the background. HP digital Imaging monitor is a service that invokes the other services when required. If this service is not running, you may not be able to open the HP Solution Center.
You can usually find the icon of HP Digital Imaging Monitor in the systray. To check if the HP Digital Imaging Monitor service is running, open the task manager , and in the process tab, search for the file called "HPQTRA08.exe" . If it is not present , navigate to C:\Program Files\HP\Digital Imaging\Bin\ (assuming that your system drive is c: and the folder maybe HP or Hewlett Packard) and search for an application file named hpqtra08.exe. and double click it. The application will start running in the background. Sometimes it may also happen that you have unchecked some startup programs from the micosoft system configuration utility (msconfig) and this file (hpqtra08.exe) is also included in them. If so, you must check the application to run it on startup. Now , restart the system and open the HP Solution center. If it works, fine. If it does not work out , open "services.msc" from the command prompt and search for the service called "HPZPML" . If it is found, make sure it is started. (Set startup type = automatically). Restart the system and try opening the solution center.
Still if the issue persists uninstall the complete entire software and reinstall it. This will probably work in case all of ther others fail.
Posted on Sep 28, 2008
Riztech
  • 731 Answers
SOURCE: HP Solution Center No HP Devices Detected
Try this
1.Right click on MY computer ->Properties->Hardware->Device manager.
2.You will get Device manager window popping out.
3.Scroll down to "Universal Serial BUS controllers".Click on the (+) sign.
4.Check for the "USB Composite Device" and right click on it, click Uninstall.(IMPORTANT NOTE:wE HAVE TO UNINSTALL THE PRINTER'S USB COMPOSITE DEVICE, TO KNOW WHETHER IS THE PRINTER'S USB COMPOSITE DEVICE, RIGHT CLICK ON USB COMPOSITE DEVICE AND PROPERTIES,look for wat location says, Eg -LOCATION : HP DESKJET F2100
5.Disconnect the USB and reboot the PC.
6.Connect the USB after reboot, you will get popup "Found new hardware".Then the Drivers will be installed Automatically.
Thanks
Riz
Posted on Jan 08, 2009
laxmankumar
  • 191 Answers
SOURCE: message says carriage is stalled
Please Click Here and follow the instructions on the document to resolve this issue.
Posted on May 26, 2009
  • 3278 Answers
SOURCE: The carriage is stalled message on my hp officejet H470 printer
Check the printer again to see if a very small jam is present. If totally clear, press the Resume button. If same result, power the printer Off / On.
Posted on Jun 28, 2009
I received a new printer today, I installed the software and ready to test print page. I get error message that the carriage is stalled. I found a procedure on HP web site that to fix problem, but it...
The printer may be faulty. I suggest you return it to the supplier to have it fixed or replaced under warranty. If you try to fix it yourself you may void your warranty.
Jul 14, 2011 | HP H470 InkJet Photo Printer
Officejet H470 ink light is flashing, even after putting in new cartridge.
do you know about the lights flashing and error saying cartridge stalled
Jul 13, 2009 | HP Officejet H470 InkJet Printer
Message says carriage is stalled
May 26, 2009 | HP DeskJet F380 All-In-One Printer
My HP470 OFFICEJET refuses to print
I did manage to solve the problem in the end.  As it seemed to be a communication problem, I restarted my Mac (as opposed to switching off the printer and on again) and it worked!!
Might need you some time in the future though....
Thanks, S Walsh
May 07, 2009 | HP Officejet H470 InkJet Printer
Computer cannot detect camera, tried different USB cables
is the usb port active still? try wiggling the cable at the camera connection.good luck farr64
Apr 30, 2009 | Cameras
Try this
Thanks
Riz
Jan 03, 2009 | HP Photosmart C8180 All-in-One InkJet...
Problem: Cannot Load Windows/Windows Setup Does Not Detect Hardrive
My Hp Compaq tc4400 Does not load Windows and when i try to install a new one and error Message apears saying that it cannot detect any hardrive, but when i press F9 for boot selection Notebook Hardrive is dected and availble, i tried removing the hardrive and re-insert it also it dint work could somebody help plssss
Feb 01, 2008 | Compaq tc4400 Tablet PC (RL875AW#ABA)
Initialization failed - Unable to acquire TWAIN-compliant device
I have seen your message stating that "Initialization failed - Unable to acquire TWAIN-compliant device" error is received when trying to connect USB-Parallel type to your Laptop.
Well,  Printer  Panasonic UF4100, recommends to use only " Printer/Scanner Interface as Bi-directional Parallel (IEEE1284) " means you need to use Parallel cable to connect Printer to the Computer/Notebook.  You may receive some communication error messages if you are using a  "PORT REPLICATOR CABLE"( USB TO PARALLEL connector).  The error message that you have received is related to the communication error. Futher, if you use same USB- Parallel cable for long time the Printer Hardware functionality might go bad, since Printer memory gets confused and will not read or detect the Cable , since it is not a cable to use  mentioned by Panasonic Manufacturer.
Let me tell you, general functionality of Printer like Printing would work even if you use USB-Parallel cable. But it is not a case with Scanner and Fax functionality.
Hence, I recommend you to use only Parallel cable to connect your Printer to the Laptops.
I hope that this will resolve the issue for you.
You can email me at thumuvikram@rediffmail.com if you need further assistance.
Bye.
Oct 17, 2007 | BafoTech BAFO BF-1284 Parallel Adapter
HP Officejet H470 InkJet Printer Logo
87 people viewed this question
Seeker5211
Seeker5211
