Question about American Standard Heating & Cooling
My furnace is flashing 21 green and then it flashes red ...the furance will not run . I have replaced the thermostat and cleaned tha condensate drain
  • 472 Answers
Not sure what 21 is ,but if you are getting acode normally the code comments are on the door or the manufacture lable to tell you what they are...
i can tell you the operation and maybe that will help you out...
the unit should start off with the enducer draft motor small motor in furnace that pulls all the stale air out..then the negative pressure switch activates which should have a hose coming from the enducer draft moto to the pressure switch..once the pressure switch closes it sends power to the ignitor and the ignitor should glow once it gets hot a milivolt current is sent back to the gas valve and it opens up and fires...after it fires you should have a flame sensor small metal rod in the direct path of flame that keep sensing the flame and sends signal back to board.... unplug unit and watch it start where is it failing or in what part of the operation does it flash a code....
Posted on Jan 03, 2011
Ever limit switch i changed in my Weatherking furnace, it breaks the switch, what could cause this?
You need the model number of the furnace to determine what the flashing light is telling you. Many times the part that looks to be at fault is not the true fault in the furnace. A slow running blower could cause the limit switch to trip. The circuit board tells you that the limit tripped, but the real cause is the motor or clogged filter.
Jan 02, 2016 | FACTORY AC PARTS Limit Switch Double Pole...
My totaline thermostat model #p474-0100-a the backlight is staying on and when the furance is running after only a couple of minutes it shuts off and my furance shuts down .
Multiple issues that are not related. If the pilot light goes out then the thermocouple might be bad. If the pilot ignites the gas and everything shuts off, it sounds like the over temperature sensors are detecting heat in excess of what is allowed in the firebox. The thermostat issue has nothing to do with this.
Nov 19, 2014 | Heating & Cooling
I have Omega EHE 100S ducted heating when I switch it on there is no response at all. Can you help me out?
If your green light flashes a normal 1 second flash continuously, it means your furnace has a normal heartbeat. If your green lite flashes so many times then stops and then flashes that many times again, then stops again, and repeats again, count the number of flashes, write down that number, then remove the fan door the schematic will tell you the trouble. If your furnace has a normal heartbeat, the thermostat or wiring from the thermostat to the furnace is opoen or faulty.
Nov 04, 2014 | Heating & Cooling
I have goodman GMP series furance the furnance and gas comes on and fires up then goes out flame sensor is good what else could be wrong
Improper ground from control to burner.
Incorrect electrical wiring, check polarity.
Tubing partially clogged between inducer and proving switch.
A sampling of various failure codes on a furnace:
Read one LED flash that stays on continuously to mean your furnace has no signal coming from the thermostat and will not operate. Turn the power off and check the thermostat for improper settings or connections.
Interpret one LED flash that blinks on and off to mean your furnace has locked out because it could not ignite after three tries, and must be reset. Interrupt power to your furnace for 20 seconds or lower the thermostat so your furnace does not try to heat, then reset the thermostat to the previous setting. After one hour of lockout, your furnace will automatically reset itself and try to operate as usual.
Decipher two LED flashes to mean the draft blower is not working, or your furnace has a short in the pressure switch circuit. Turn off the furnace power and repair a short or replace the pressure switch.
Read three LED flashes to mean your furnace has an open pressure switch circuit or it has an induced draft blower operating. Check the pressure switch hose of your furnace for blocks or an improper connection. Also, look for blockages in the flue, and tighten any loose wiring.
Translate four LED flashes to mean your furnace has a primary limit circuit open, possibly from loose wiring or blocked filters. Check and clean filters, tighten wiring and check the flue for blockages.
Interpret five LED flashes to mean your furnace senses a flame without a call for heat. This could be from a gas valve closing slowly or a burner flame lingering.
Read seven LED flashes as a warning of a low flame sense microamp signal. This could happen with a coated flame sensor or a lazy flame from poor gas pressure. Turn off the power and adjust the gas pressure according to the information on the rating plate.
See eight LED flashes as meaning an igniter circuit problem due to a bad igniter or an igniter connected improperly. Replace the bad igniter or check the ground wiring, making necessary corrections.
Decipher nine LED flashes to mean the high-stage pressure switch circuit will not close during a high-stage-induced draft blower operation. Your furnace may have a pinched or blocked pressure switch hose, a blocked flue or loose wiring.
Read continuous flashing on the LED to mean your furnace has a reversed polarity of 115 volts. Turn off the power and correct the wiring polarity after reviewing the wiring diagram.
Oct 18, 2011 | Goodman GMS90703BXA Heater
AC IS TURNING ON BY IT SELF AFTER I SWITICH IT OFF, HOW TO SOLVE THIS PROBLEM
Sounds like a problem with the furances circuit board. With the furance powered off, disconnect the two wires at the circuit boards thermostat terminal strip. These are probably red and white wires connected to the "Y" and "C" thermostat terminal strip on the circuit board. These two wires send 24 volts to the outside A.C. condenser unit when the thermstat is se tinto the cooling mode. With the thermostst in the "off: postion measure across the "Y" & "C" terminals at the furances thermostat terminal strip. If you have voltaged than either the board or thermostst has failed. The next step to determine which has failed is this. Disconnect all the thermostat wires at the furance. To check the heating circuit jumper across the "R" & "W" terminals, the furance should fire off for the heating circuit and run non stop beacause the thermostat is no longer controlling it and is isolated from the furance. Now remove the jumper and jumper across the "R" &"Y" terminals, the blower should run at your furance for the cooling mode and you should have 24 volts across the "Y" & "C" terminals for the outside A.C. condenser compresor contactor.Next check for blower operation by jumpering across the "R" & "G" terminals. If everything checks outs than the thermostst is the problem. Tou may also want to check the control wiring at the thermostts , furance & out side condenser unit. If the wiring has connnected somewhwre between these points or at the terminal connection this may also be bring on the A.C. when the thermostat is in the "off position.
Feb 13, 2011 | Hitachi Heating & Cooling
Renting a house and there is a green flashing light on honewell furnace. Thermostat set at 70 but the temp is 54. Should I press the reset button or just call and bother the owners. Used to living in a...
Clean the flame sensor at the furance burner compartment. This is found left hand end farthest burner tube from ignitor, Make sure your filter is clean. Turn powwer off at furance and then turn back on to reset.
Jan 26, 2011 | Heating & Cooling
Unless we set the thermostat very high, like 80 degrees, the heater will blow cold air. When the heat does blow, it will eventually stop blowing heat and the fan will continue to blow cold air.
Check and make sure the filter is clean. This sounds like a restriction in the system. If the unit has central cooling make sure ther indoor evaporator coil is clean at the furance.The unit may be cycling the burners on and off at the high heat limit , fan/limit control. You can also eliminate the thermostst from the furance. Turn power off at the furnace and disconnect the wiring from the thermostat. Jumper the red and white wire together. Turn the furnace back on. The furance should run in the heating mode. Try this and see if the problem is still there.
Jan 25, 2011 | Heating & Cooling
How to connect a thermostat to a bryant 80+ furance.
First thing is to turn off the switch on the side of the furnace, next remove the old thermostat and the wires from it. On the new thermostat you should have y, c,w,g,r therminals. The yellow wire goes to the Y terminal, the white wire goes to the W terminal, the red wire goes to the R terminal, the green wire goes to the G terminal and the C is comonly not used.
Jan 01, 2011 | Bryant Heating & Cooling
From the Isolator panel, how do I connect the condenser, and the blower?
MOST UNITS NOT HEAT PUMPS  WIRE UP WITH 2 WIRES TO CONDENSER RED WIRE AND WHITE . WHITE GOES TO COMMON C ON FURNACE AND RED TO Y TERMINAL OF FURNACE Y ALSO GOES TO Y ON TSTAT. BOTH YELLOW WIRES MUST MEET AT Y OF FURNACE.  WHITE FROM STAT TO W   GREEN FROM TSTAT TO G AT FURNACE IF YOU HAVE C ON TSTAT HOOK UP BROWN WIRE OR BLUE FROM COMMON TERMINAL WHERE YOU HOOKED UP CONDENSER WHITE WIRE AT FURNACE TO TSTAT , MOST THERMOSTATS DONT NEED C RUN FROM FURNACE. THE TWO WIRES GOING TO CONDENSER IS -  AND + TO ACTAVATE CONTACTOR IN OUTSIDE UNIT
Apr 19, 2010 | Ruud Central System Air Conditioner
York Furnace and Honeywell Thermostat Problems...
run the red wire to rc and run a jumper between rc and rh tape off the brown
Feb 10, 2010 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
292 people viewed this question
Top American Standard Heating & Cooling Experts
Tim Whalen
Mack Baxter
Pete Norton
Are you an American Standard Heating and Cooling Expert? Answer questions, earn points and help others
