Question about Whirlpool Duet GHW9150P Front Load Washer
What does "F6: mean on my front loading washer?
  • 347 Answers
F/6 is a Drive Motor Tachometer Error
The control is unable to properly detect motor speed and the machine will shut down.
If a failure occurs during high-speed spin the door will be unlocked after 3 minutes.
Potential Causes
• Check wire harness connections between the Drive Motor/Tachometer and the
Motor ControlUnit (MCU), and between the MCU and the Central Control Unit
(CCU)
• Check the Drive Motor
• Check the MCU
• Check the Wire Harness
Posted on Jan 03, 2011
What does and F6 error code mean on a whirlpool duette front loading washing machine mean and how do I fix it?
Error code F06 means Drive motor tachometer error.
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin the door will be unlocked after 3 minutes.
Potential Causes
1/ Check wire harness connections between the Drive Motor/Tachometer and the Motor ControlUnit (MCU), and between the MCU and the Central Control Unit (CCU)
2/ Check the Drive Motor
3/ Check the MCU
4/ Check the Wire Harness
Replace failed component or contact an authorized repair agent.
Oct 15, 2014 | Whirlpool Duet GHW9150P Front Load Washer
What does F6 code mean?
F6 code means the control board can not detect the speed of the motor. The failure could be the motor or the MCU does not work.
Oct 10, 2013 | Whirlpool Duet GHW9150P Front Load Washer
Why does the washer stop during a load and "F 06"
The F6 error code means that the computer on the control didnt detect that the motor reached a high speed on the spin cycle, sometimes it thinks the washer didnt spin fast enough because of a loose wire connection either on the motor or the control boards (motor &machine control) if you find that the washer did actually spin at high speed (clothes dont come out sopping wet at the end of cycle) the wire connections or the motor control board will be the potential causes of the F6 error code
GENE
Sep 09, 2011 | Kenmore HE2 Plus Front Load Washer
Whirlpool front load washer getting an error code of "F6"
f 06 is a in issue with the motor control board, check the wiring harness attached to the board.
May 21, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Error "F6" on my Smartwash Quite Pak9
I believe the F6 code is a motor failure. I suggest you call a pro to come out and look at it.
Sep 22, 2009 | Kenmore Elite 45986 Front Load Washer
He 3t error code f6,washer will not spin,door will not open
"f6" error code means that there a miss communication between mcu(motor speed control board) and ccu(central control unit). i recommend you to ohm out the motor. most likely its your motor speed control located at the bottom left of the washer good luck. replace the motor speed control board and you should be all set to go.
May 09, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Kenmore HE3,what F6 means
f6 is a communication error with the motor control board, i would unplug unit , remv eth bottom panel)3 screws across the botom of nit) andthe motor control board is rightthere on the left floor of the unit. check for good non corroded terminal connections, ive also seen extreme humidity/ water in surronding area trip this code
Jan 26, 2009 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Kenmore Elite front load
theres an error between the motor control board and the central control board,,meaning you might have lose connection,,or burnt,wire,,this i would let a technician look at,,,good luck
Jan 03, 2009 | Kenmore Elite 45986 Front Load Washer
F6 CODE
F6 on an asko washer means a fault was detected with the motor. What this means 99% of the time is the brushes in the motor are worn. As long as the armature isn't damaged, (visual inspection while turning motor shaft should identify damage) you'll be fine replacing the brushes.
part # 764414, 2 required, about $40US each (better than $400US plus for a motor).
hope that helps
good luck
May 30, 2008 | Asko W6021 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
484 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
