Question about Nokia N70 Cellular Phone
Configuration settings how can i have my configuration setting each time i change network?
  • 16 Answers
Keep "Operator Selection" Automatic.
Posted on Jul 29, 2008
Advanced configuration settings for the Belkin wireless G Plus mimo network adapter
Enable the Wireless Zero Configuration service so it starts up automatically, go to the Start button. Select the Settings option and then select Control Panel. If you are using the Windows XP view, select the Performance and Maintenance category and then select Administrative Tools. If you are using the Classic View, then select Administrative Tools. Click the Services icon in the left pane. Click the Wireless Zero Configuration icon in the right pane and change the Startup Type dropbox to Automatic. This setting will set the service to start automatically at boot time. Then click the Start button to start the Wireless Zero Wireless Zero Configuration service and click the OK button.
Jan 22, 2013 | Belkin F5D9050 Wireless G Plus MIMO USB...
Tip
Configuring Netgear Wireless Routers/Access Points
What do you need to know about configuring routers?
All basic router configuration are almost the same. You can access the router by a specific address. In this case, for NETGEAR router, the default address is 192.168.1.1.
You can access the router configuration page by typing 192.168.1.1 on the address bar of any browsers.
It will then ask for the User name and Password. The
Default UserName is : admin
Default Password : password
Most of the people just want to configure their wireless network and what is the wireless key.
You can check the wireless setting of the router. You will then see the wireless network name or the SSID. You can definitely change that to the wireless network key that you wish to use.
You can also change the wireless key which is your wireless security. There are several types of wireless security. We have WEP, WPA-PSK, WPA-PSK2.
Usually, WEP and WPA wireless encryption are used. For WEP, you can use 10 digits numbers from 0-9 and for WPA-PSK, you can use alpha numeric characters.
It's up to you what to use. You can easily change the wireless key by entering it on the Key1 under the Security Encryption. Just hit apply and you can now use the new wireless network name and key that you just setup..
One tip of advise, don't be afraid to change the settings of the router. Just remember the current settings if you are not that familiar before changing anything. If that doesn't work, just revert the changes. I'm sure, you'll get comfortable on configuring any router in a short time..
Happy configuring.. :)
on Oct 03, 2011 | NetGear Computers & Internet
What is the handset configuration setting?
The Handset Configuration Manager is an OTA Configuration Solution in Telecom Consultancy, for all types of Mobile, enabling Mobile Device Configuration settings to be sent automatically at the right time this ensures that customers have access to Data Services immediately, always, no matter why or when they change Handset.
The Handset Configuration Manager will provision Device settings including GPRS, WAP, MMS and Email, using the industry standard OTA provisioning protocols enabling the delivery of settings for a broad range of Mobile Terminals.
Ensuring End-to-End QoS
Using the Reach server Subscriber Capability Management rules, Handset Configuration settings can be sent automatically based on the history of the Handset observed on the network. e.g. only when the Handset is used for the first time. The Reach Server checks to ensure all corresponding Network Services based on the capabilities of the used Handset are also activated.
May 04, 2011 | Computers & Internet
Hi i am using the pc sony vaio i have the problem on wireless adabter it was in desable mode and difficutl to active it ,while i am useing the bottom in front of pc on and off of wirless adabtor but i i on...
In Vista, you can either go to control panel, device manager and right click on it and click "eneble"
or go to control panel > network sharing and set up wireless network connection
or
go to task manager (press and hold ctrl . alt . delete for a couple of seconds), until task manager comes up. Then click on the services tab, scroll down till you see "Plug Play or Plug and Play and make sure it's running. If it's not, right click on it then click "enable"
In XP
Open Network Connections
Right-click Wireless Network Connection, and then click Properties.
On the Wireless Networks tab, do one of the following: •
To enable automatic wireless network configuration, select the Use Windows to configure my wireless network settings check box. This check box is selected by default. For information about what happens when you enable automatic wireless network configuration, see Notes.
To disable automatic wireless network configuration, clear the Use Windows to configure my wireless network settings check box.
To connect to an existing wireless network, do one of the following:
Access point (infrastructure)
To connect to an existing access point (infrastructure) network, under Available networks, click the network name, and then click Configure.
In Wireless Network Properties, specify the wireless network key (Wired Equivalent Privacy) settings, or, if the network key is automatically provided for you (for example, the key is stored on the wireless network adapter given to you by your administrator), select the The key is provided for me automatically check box. If you are unsure about whether a network key is needed or which settings you need to enter, contact your network administrator or the wireless network adapter manufacturer.
Important
If a network does not broadcast its network name, it will not appear under Available networks. To connect to an access point (infrastructure) network that you know is available but that does not appear under Available networks, under Preferred networks, click Add. In Wireless Network Properties, specify the network name (Service Set Identifier) and, if needed, the wireless network key settings.
Computer-to-computer (ad hoc)
To connect to an existing computer-to-computer (ad hoc) network, under Available networks, click the network name, and then click Configure.
If you want to connect to a computer-to-computer (ad hoc) network and both computer-to-computer and access point (infrastructure) networks are within range of your computer, click Advanced, and then click Computer-to-computer (ad hoc) networks only.
To configure a new wireless network connection, click Add, and then do the following: •
If the network connection that you are configuring is to a computer-to-computer (ad hoc) network, select the This is a computer-to-computer (ad hoc) network; wireless access points are not used check box.
To change the order in which connection attempts to preferred networks are made, under Preferred networks, click the wireless network that you want to move to a new position on the list, and then click Move up or Move down.
To change the wireless network connection settings for a network that is listed in Preferred networks, click the wireless network for which you want to change settings, click Properties, and then change the settings as needed.
To remove a wireless network from the list of preferred networks, under Preferred networks, click the wireless network that you want to remove, and then click Remove.
To update the list of available networks that are within range of your computer, click Refresh.
To automatically connect to available networks that do not appear in the Preferred networks list, click Advanced, and then select the Automatically connect to non-preferred networks check box.
To open Network Connections, click Start, click Control Panel, click Network and Internet Connections, and then click Network Connections.
When you enable automatic wireless network configuration, you can connect to an existing wireless network, change wireless network connection settings, configure a new wireless network connection, and specify preferred wireless networks. You will be notified when new wireless networks are available. After you select a wireless network, your wireless network adapter will be automatically configured to match the settings of that network, and a network connection attempt will be made.
To configure settings on the Wireless Networks tab, you must be logged on as an administrator, and you must use a wireless network adapter that supports the Wireless Zero Configuration service. If you are unsure whether your wireless network adapter supports the Wireless Zero Configuration service, contact your network administrator or the wireless network adapter manufacturer. For more information about automatic wireless network configuration, see Related Topics.
If you are using third-party wireless networking software, clear the Use Windows to configure my wireless network settings check box.
If you are unable to connect to an existing wireless network and the name of the network that you want to connect to appears under the Preferred networks list, click the preferred network name, and then click Properties. In Wireless Network Properties, review the settings to ensure that they are correct. If you are unsure whether the settings are correct, contact your network administrator or the wireless network adapter manufacturer.
If the Preferred networks list includes both access point (infrastructure) and computer-to-computer (ad hoc) networks, you cannot move a computer-to-computer network to a position in the list that is higher than the position of an access point network.
To provide enhanced security for 802.11 wireless networks and for wired Ethernet networks, IEEE 802.1x authentication is enabled by default. For more information about how to set up 802.1x authentication.
Hope this helps
Dec 12, 2010 | HP Broadcom NetXtreme Network Adapter
Ip address wrong, showing 192.168.254.1
Solution Overview
This article explains how you can avoid having to run the Wireless Configuration Utility or Wireless Setup Assistant (Macintosh) after making changes to the router's security settings. The need to change these settings can arise if users forget their network key/passphrase or router web server password or if you have security concerns.
Printer response to security settings changes
The printer will respond with a flashing orange (pattlnk_6172008_1844-orgblksml.gif) Wi-Fi indicator light after the following actions are performed on the network or router/access point (AP):
  • -A change to the Service Set Identifier (SSID) or network name.
  • -A change to the security type (none, WEP, WPA, or WPA2 personal).
  • -A change to the security network key/passphrase.
  • -A hard reset of the router followed by entry of security values that are different from the original values.
  • -The printer is moved to a network (AP) that has different security values but already has installed drivers and created ports. NOTE: Port reconfiguration may be required in this case. Click here for instructions.
In order to rejoin (associate and authenticate) the wireless network (WLAN), the wireless client (printer) has to be reconfigured with the router's new SSID, security type, and network key. This requires connecting the USB configuration cable to the host computer and running the Wireless Configuration Utility or Wireless Setup Assistant to apply the new security settings on the printer's wireless network adapter.
Solution: Change the printer settings first
Change the security settings on the printer while it is still communicating on the network before making the changes on the router. Understand that this will cause a temporary change in the Wi-Fi indicator light from pattlnk_6172008_1952-tn_grnsolproof.jpg to pattlnk_6172008_1844-orgblksml.gif. After you have made equivalent changes on the router, the printer's Wi-Fi indicator light will return to pattlnk_6172008_1952-tn_grnsolproof.jpg.
Procedure: How to change security settings via the embedded web server
If you change your AP security settings frequently, this procedure is for you.
  1. Open your web browser application and enter the printer IP address into the web address field, i.e. http://ip_address.
  2. Click on Configuration.
  3. Click on Wireless.
  4. Enter the SSID, security type/encryption, and network key that will be used to configure the router.
  5. Click Submit.
Jan 16, 2010 | Lexmark X6650 4-In-One Wireless InkJet...
Cannot re-set network configuration.
Try 6482 or MITA as password
Try leaving password box blank
Try entering the IP address in the web browser and configure there. The firmware will have to flashed if this doesn't work.
Kyocera is pretty picky about resets. You might have to phone them.
1800-GET-MITA
Feb 24, 2009 | Kyocera Mita FS-1920 Laser Printer
Wireless security
Hello sir,
GETTING STARTED How to Physically Connect the D-Link
1. Plug an Ethernet cable into the DSL modem. Plug the other end of the cable into the "WAN" port on the D-Link.
2. Using an Ethernet cable, plug any wired computers into any of the 4 Ethernet ports on the D-Link.
How to Access the D-Link Configuration Screen
The D-Link is configured using a Web browser. After you have connected your computer to the D-Link router, follow these steps:
1. Launch your Web browser. Enter "http://192.168.0.1" into the address bar and press the "Enter" or "Return" key.
2. A logon pop-up screen will appear. Type "admin" for the username and leave the password field blank.
3. Click "OK". A D-Link configuration screen will appear. All changes to the D-Link configuration are made here.
GENERAL SECURITY MEASURES
Change the Admin password
Leaving the password blank is not a good idea. It should be changed to something more secure. To change the password, go to the D-Link configuration screen and:
1. Click the "Tools" tab.
2. Click the "Admin" button.
3. Under the "Administrator" heading, enter the new password, and a second time to confirm.
4. Click "Apply".
5. The next time you access the D-Link configuration screen, you will need to enter the new Admin password.
Disable the Wireless LAN
If wireless access is not necessary, you should disable the wireless part of the D-Link. This will prevent anyone from accessing the network wirelessly. (If you are using the wireless features, please skip down to "Wireless Security Measures".) From the D-Link configuration screen:
1. Click the "Home" tab.
2. Click the "Wireless" button.
3. Click the "Disabled" button next to "Wireless Radio".
4. Click "Apply".
5. You are done securing your wired network. No further action is required.
WIRELESS SECURITY MEASURES
Enable WEP
Enabling WEP* (Wired Equivalent Privacy) will require anyone wishing to access the Internet through your wireless network to enter a password. After the correct password is entered, a connection is established, and all data sent from the D-Link to the computer and back is encrypted. From the D-Link configuration screen:
3. Click the "Open System" button next to "Authentication".
4. Set the "WEP Encryption" to "128 bit".
5. Set the "Key Type" to "ASCII".
6. Type a 13 digit password into "Key 1".
7. Click "Apply".
8. When you connect to your wireless network from a computer, you will need to enter the 13 digit password.
*Note: If your computer's operating system supports it, enabling WPA-PSK is more secure than WEP. The steps above can be modified to set up WPA-PSK.
Change the SSID
By default, the D-Link is set to advertise the existence of your wireless network to computers. It does this by broadcasting an SSID (Service Set Identifier), also called a "network name" because it identifies your wireless network. Changing the SSID makes it easier for you to distinguish your network from surrounding networks. From the D-Link configuration screen:
3. Change the "SSID" from "default" to an SSID of your choice.
4. Click "Apply".
Please don't forget to comment this
Good luck
Cheers!!!!!!!!!!
Oct 26, 2007 | D-Link Securicam Network DCS-950G Wireless...
Macintoshes and the RP614 Router Gateway
You need a Macintosh computer running MacOS 8.6, 9.x, or 10.x. (Netgear products are not supported for versions of MacOS before 8.6.) You can use the RP614 with an eMac, iBook, iMac, PowerBook, PowerMac, or PowerPC as long as they are running one of these versions of MacOS. You also need a few Ethernet cables to make the connections between the router to your modem for internet connection and from the router to your computers or peripherals. Topic 2. How do I prevent my Network configuration from being lost when I restart my computer? When making configuration changes for MacOS it is best to use Configurations (MacOS 8.x or 9. x) or Network Location (MacOS 10. x) settings instead of just changing settings for each category (TCP/IP, AppleTalk, AirPort, etc.). If you just make changes to your settings, they may be lost when you restart your computer unless you have saved them in a Configuration or Network Location. To create a Configuration in MacOS 8.x or 9.x: 1. Open AppleTalk (or TCP/IP) from the Apple Menu in the upper left-hand corner of the screen. 2. From the pull-down File menu select the Configurations option. 3. Choose New Configuration. 4. Type in a name for your new configuration (Netgear Router). 5. Make your changes to the AppleTalk (or TCP/IP) settings. 6. When you close AppleTalk (or TCP/IP) choose Save Changes. Whenever you make Configuration changes for settings in MacOS 8.x or 9.x, open Configurations from the File menu or by pressing Command-K. Saving your changes in Configurations means that they will not be lost when you reboot your computer. To create a Network Location in MacOS 10.x: 1. Open the Apple Menu by clicking on the Apple icon in the upper left-hand corner of the screen. 2. Select System Preferences. The System Preferences window displays. 3. From the System Preferences window click Network under Internet & Network. The Network settings window displays. 4. Click the Lock icon (if necessary) in the lower left-hand corner of the window to unlock the Network window so you can make changes. (You may be asked to type in your User Name and Password.) 5. Click the pull-down menu next to Location at the top of the Network window. 6. Select the New Location option. 7. Type in a name for your new Location and click OK. 8. Make your changes to the TCP/IP, AppleTalk, and AirPort settings. 9. Click the Lock icon in the lower left-hand corner to prevent further changes. The Apply configuration changes? Window displays. 10. Click Apply to apply the configuration changes for the newly-created Location. 11. Close the Network window. Topic 3. How do I connect a Macintosh to the RP614 Router Gateway? MacOS 8.6, 9.x, and 10.x 1. Set up your system for installation. 2. First make sure your ISP connection is working. Try testing your computer with the ISP directly to make sure you can successfully make a connection to the internet. 3. Connect your DSL or cable modem to the Netgear Router. 4. Log on as Administrator (if required for your system to make configuration changes). 5. Quit all other applications. It's best when configuring MacOS 8.6 and 9.x to use the Configurations settings for AppleTalk and TCP/IP because they should then retain their settings when you reboot. (Use Network Locations to save your settings changes in Mac OS 10.x.) If you just change the settings but don't use a Configuration or Network Location to save your settings changes, you may lose those changes when you restart your computer.
Feb 19, 2006 | NetGear RP614 Router
"File not found" error message when I try to use a saved network settings file to
CAUSE This issue may occur if you change the file name from the default file name "Networksettings.xml". RESOLUTION To resolve this issue, do not click My settings are on a floppy on the Where are your network settings located? page in the Microsoft Broadband Networking Setup Wizard. Instead, click My settings are in a file available from this computer, locate the floppy disk drive, and then click your configuration file.
Feb 16, 2006 | Microsoft Broadband Networking MN-500...
"File not found" error message when I try to use a saved network settings file to configure my Microsoft Broadband Networking hardware
Feb 16, 2006 | Microsoft Broadband Networking MN-100...
Nokia N70 Cellular Phone Logo
23 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
