Question about Compaq (CDD480172) CD-RW Burner
Ok so my compaq presario windows xp home edition service pack 3 cd burner was working fine till just a few minutes ago Windows Media Player said Connect a burner. I unistalled wmp and reinstalled still had the same problem went to many websites to find the problem. I even installed realplayer still said connect a cd burner. I went to device manager and it said "Windows cannot load the device driver for this hardware. The driver may be corrupted or missing". I unistalled the burner and restarted my computer. It reinstalled it but it still had the same problem with not working or not popping up under my computer. Whats wrong and what should I do?
  • Compaq Master
  • 27,725 Answers
Make sure that the cd burner is getting enough power test all leads that are attached to the cd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd/dvd burner then plug them back in or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
hope this helps
if this does not fix the problem it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Posted on Jan 03, 2011
My windows xp startup disk with the os an drivers is no good microsoft says i need contack manufactures copy do have one
You should not have contact the manufacturer (microsoft)
one of these will help you
SP3 is the third and final service pack released for Microsoft Windows XP, and it eliminates many of the security holes that previously affected XP. While Microsoft recommends that users download SP3 using Windows Update, some users are unable to do so. However, it's easy to create a Windows XP SP3 installation CD; it requires only that you download the pack from the website and burn it to a CD-R/DVD-R using an ISO burner program.
Download the SP3 installation ISO by visiting the first link listed in the "Resources" section of this article. Save it to your Desktop. Download ImgBurn and save it to your Desktop. Double-click the installation executable for ImgBurn and click "Next." Follow the remaining onscreen prompts and click "Finish" to complete installation of ImgBurn. Insert a blank CD-R/DVD-R into your DVD drive. Open ImgBurn by going to "Start," "Programs" and "ImgBurn." Click "File," then "Browse for a source file." Navigate to your Desktop and select the SP3 ISO file. Click "Open." Click the blue "ISO to CD" button located on the bottom left of ImgBurn. The program will begin creating the Windows XP SP3 installation CD. This process may take anywhere from 10 to 20 minutes to complete depending on the speed at which the CD-R/DVD-R is being burned. Click "OK" once the CD-R/DVD-R has finished burning. You've successfully created a Windows XP SP3 installation CD.
http://www.microsoft.com/downloads/details.aspx?FamilyID=2fcde6ce-b5fb-4488-8c50-fe22559d164e&displaylang=en XP PRO SP3 ISO Download the iso also download the imageburn http://www.imgburn.com/
http://windows-xp-pro-startup-disk.soft32.com/ http://support.microsoft.com/kb/322389 http://windows-xp-pro-startup-disk.soft32.com/free-download?gclid windows xp pro start up disc
post a reply if you need more help with this
Mar 12, 2013 | Compaq Presario sr1403wm AMD Sempron 3000+...
I HAVE A ZING WINDOW CE LAPTOP .AND I HAVE A NOKIA N73 AND ITS PC SUITE CD .I COPY CD INTO PENDRIVE .WHEN I INSTALL PC SUIT IN MY WINDOW CE THERE IS CAME THIS MASSAGE -SOFTWARE NOT VALID FOR WINDOW CE. HOW...
You may not be able to. Windows CE is a very small Windows operating system. That is, there are just basic components used to run your laptop.
From the website PDF manual:
To install and run Nokia PC Suite:
At least 300 MB of free disk space
- One of the following operating systems:
- Windows 7 32-bit and 64-bit editions
- Windows Vista 32-bit and 64-bit editions (Service Pack 1)
- Windows XP Professional x64 edition (Service Pack 2)
- Windows XP (Professional or Home Edition) (Service Pack 2 or later)
- Administrator rights to the PC to install software on it
Note: To transfer music between your phone and a PC using USB cable connection in the Media Transfer mode, you need to have Windows Media Player 10 (or newer) installed on your PC. Windows Media Player includes an MTP driver, which is required for transferring music in the Media Transfer mode.
Feb 25, 2011 | Computers & Internet
Lost SP3 windows xp home edition version 2002 how do i get it back or do i need to I have automatic updates turned on when I look at programs beside it ,there no file size? also how do I fix error...
If you mean no file size showing up in "Add / Remove Programs"
thats because it's integrated / uninstallable but registered.
Error: 0x80070005, is that when you access "Microsoft Update"?
As for repairing SP3 Read more here:
http://windows.microsoft.com/en-us/windows/help/learn-how-to-install-windows-xp-service-pack-3-sp3
and you probably have to go for option:
"Manually installing SP3 using the Microsoft Download Center or a CD"
Good Luck
Jul 18, 2010 | HP Compaq Presario SR1620NX...
Rewriteable disc will not burn.
well try to burn the music using the nero software
Jan 06, 2010 | NEC ND-3500A DVD±RW Dual Layer Burner
Disc Burner Not Working
8 or 9 months?
Just take it back to the store , they will repair/replace for you as its stll under warranty
Jul 08, 2009 | Compaq Computers & Internet
Not playing DVD CDs
Considering the fact that the dvd gets detected since you are able to see presentations,
it might me the problem of codecs..
Go to the following link and download the codec pack
codecs.com/download/K_lite_codec_pack.htm">http://www.free-codecs.com/download/K_lite_codec_pack.htm
make sure your windows media player is set as your default player in control panel > default programs > set computer access and defaults.
Hope this helps..
Regards,
Anup
Apr 07, 2009 | HP Compaq Presario V2000z Notebook
SP3 nightmare install
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph07159&lc=en&dlc=en&cc=us&product=1127351&rule=24868&lang=en#
This should help you also
On March 6, 2008 Microsoft released Service Pack 3 (SP3) for Windows XP. Service Pack 3 contains all of the important Windows updates from previous service packs as well as additional updates that were released after Service Pack 2. To install Windows XP Service Pack 3 from the Internet on a home desktop computer use the Windows Update feature. CAUTION: If you have an HP Pavilion, HP Media Center or Compaq Presario desktop computer that has an AMD processor, your PC might encounter a startup problem after installing SP3 (or SP3 will not download from Windows Update). Before attempting to install SP3, install sp37394 - Microsoft Windows XP SP3 Upgrade Utility for systems with AMD processors . For more information, the following support articles from the Microsoft Web site can help: 322389 - How to obtain the latest Windows XP service pack (in English) 936929 - Release notes for Windows XP Service Pack 3 (in English) NOTE: One or more of the links above will take you outside the Hewlett-Packard Web site. HP does not control and is not responsible for information outside of the HP Web site.
Jan 25, 2009 | HP Compaq Presario SR1620NX...
How do I start fresh with my used Compaq Presario 2538CL?
stick in windows xp cd got keys i hope then boot to it from bios set cd player to boot 1st in that order then when u boot up ask u boot from cd from ther follow on screen ins ok easy then update it ect get latest drivers in do windows custum scan
Oct 06, 2008 | Compaq Presario 2538CL Notebook
Compaq presario V2000 power off unexpectedly.
There are quite a few laptops and towers (my e-machine) that is not compatible with service pack 2. However, they are compatible with service pack 3 release candidate 2. Down towards bottom of page, choose which language.
Apr 05, 2008 | HP Compaq Presario V2000 Notebook
DvD Player on PC
try and install decoder from updates of windows media player,and search for windows xp decoder ,and update ur windows
Mar 15, 2008 | Computers & Internet
Compaq (CDD480172) CD-RW Burner Logo
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
