Question about Dishwashers
Message error 43 on GE Washing machine model 9220. What is it? Is it something that I can reset or do I need a service person?
  • 4,323 Answers
Hi
Error code 43 means Inverter control board failure. Try and unplug the washer from power outlet for 30-40 minutes, if you get same error then replacing the inverter ontrol board is only way. You can not reset this error code as this is related to component failure. Check the inverter board for any disconnections
Inverter Access/Removal--
Remove the service panel by removing the 3 Phillips-head screws that hold the
service panel to the cabinet.
Pull the service panel down.
Look for inverter board(part#630&640) and press the 4 tabs inward and remove the junction
box cover.
Make sure the wiring connections to the motor harness and Junction box cover are fine.
Note: The motor wire harness is soldered to the inverter. Any fault in the inverter or motor wire harness requires inverter replacement.Hope this helps... Please post back if you need more information.
Daniel
Posted on Jan 03, 2011
GE washer won't agitate or spin. Error code says "locked rotor". When I reset motor by opening and closing lid, error code returns to normal. But machine still won't agitate or spin. HELP!
the only solution is to find the nearest repair person and ask for a quote for the job, as it seems the control board has died please do not try to replace it on your own as only a qualified person should attempt this kind or work eric
Dec 31, 2017 | GE Washing Machines
My machine shows F:43 . What is the problem?
try to run test program if it won't help - service. F:43 is a fatal error. it could be short-circuit rotor broken engine etc...
it won't dissapear on it's own.
Oct 20, 2015 | Washing Machines
My washer error message unit detect a problem
The most common solution for this message is to turn the machine OFF and then ON. If the error resets, you are done.
However, this message will sometimes cause the control to stop the machine from working. With this type of error, the control panel will need to be reset. The following steps will allow you to reset your control.
Solution:
  1. Clear the ERROR from the screen: Press and hold the MY CYCLES and BACK buttons simultaneously for 3 seconds. The control will display any recorded errors. Please write down what error codes are shown on your screen in case service is needed. If a MORE icon is displayed on the screen, press MORE to list additional errors. When the EXIT button appears, press EXIT.
  2. Remove Power: Follow the onscreen instructions to remove power (unplug unit) and then immediately plug unit back in.
  3. Clear Setup Mode: After power is restored, a setup screen that begins with "Congratulations..." will be shown. DO NOT PRESS the OK button shown at the bottom of the screen. Press the START/STOP and POWER buttons simultaneously until the Home Screen is displayed. Your unit is ready to function normally.
Mar 02, 2015 | GE Profile WPRE6100G Top Load Washer
Washing machine - 261/2 x 43 x 28
Outside dimensions don't account for cubic ft because inner tubs are round. You need the model number and input it into google search or look it up on GE.com. GE uses same cabinet on most washers but has different inside capacity on top loaders.
Feb 20, 2015 | GE Washing Machines
Zanussi washing machine ZWF 14581 error code 43 is showing up. How can I reset the machine so that it works normally?
Zanussi code 43 states 'problem with the door interlock triac', sorry- likely service call ;-0(
Good luck
John C.
Oct 08, 2011 | Zanussi ZWF1430W Front Load Washer
F43
Hi.
If you have Bosch, Baumatic, or any other machine built by Bosch, then F43 is a motor issue:
Error F43 : Motor fault: do an emergency drain through the drain access in the front bottom side (see manual). Open door and check ig the drum rotates free when spin by hand. Disconnect power before performing maintenance.
Regards.
Ginko
Sep 14, 2011 | Washing Machines
My ge profile harmony washing machine has a message that says "a problem has been detected with this unit."
Washers - Harmony Washer Error Message or Code
The Harmony washer electronics can automatically determine if problems exist with the machine. Sometimes an error code can also be present because of things the machine cannot control: like changes in house voltage, water pressure, or temperature.
"A problem has been detected with this unit" will be displayed on the screen.
The most common solution for this message is to turn the machine OFF and then ON. However, this message will sometimes cause the control to stop the machine from working. With this type of error, the control panel will need to be reset. The following steps will allow you to reset your control.
Solution:
GOOD LUCK. TIMOTHY DO 714-334-1998
Aug 04, 2010 | GE Washing Machines
Error code 43 on F& P washing machine
The micro switch or the lever that activates it seems to have been the cause of the Error Code 43. Have re-seated the switch in its holder and ensured the activating (out of balance) lever is moving freely. The switch appears to be OK and now it is all re-assembled, the Error Code 43 is gone. Machine is operating normally again.
Out of Balance Switch was located below the right hand side of the computer board (module).
Rgdz John T
Mar 23, 2008 | Fisher Paykel Eco IWL16
Copier reset procedure.
hi fixya180,
It seems that the error code 541 (which indicates a problem with the heating unit thermistor in the machine), cannot be reset by the user for safety reasons, ref;
http://savin.custhelp.com/cgi-bin/savin.cfg/php/enduser/std_adp.php?p_faqid=7081&p_created=1102093227&p_sid=9TrLDc-i&p_accessibility=0&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PWRmbHQmcF9ncmlkc29ydD0mcF9yb3dfY250PTQzNiZwX3Byb2RzPTI1MTAsMjUxNCZwX2NhdHM9MCZwX3B2PTIuMjUxNCZwX2N2PSZwX3NlYXJjaF90eXBlPWFuc3dlcnMuc2VhcmNoX25sJnBfcGFnZT0xJnBfc2VhcmNoX3RleHQ9ZXJyb3IgY29kZQ**&p_li=&p_topview=1
This error requires service support from your local authorized dealer or original point of purchase. You say that you've verified the functionality of your fuser unit; then a authorized Savin printer technician will probably just have to reset the error code of your copier.
Hope you find this info helpful in solving the problem and thanks for using the FixYa service
Kind regards
Mar 07, 2008 | Computers & Internet
Dishwashers Logo
Top Dishwashers Experts
